Novice First Build: The Jawbone
Discussion in 'Tele Home Depot' started by Slowtwitch, Jan 1, 2019.
  1. Slowtwitch
    Slowtwitch Tele-Meister
    South Africa
    I've also been prepping my home made Bone nut
    Getting the thing to seat properly in the nut slot was frustrating, making sure the slot was perfectly level and square ain't easy!!!
    Got it to work eventually
    After researching, I found there isn't a standard for string spacing and it really is personal preference, considering nut width, fret bevelling angle and preferred spacing, I decided to go with a slightly wider spacing, even though my nut is narrower - I'll bevel the frets accordingly
    MIA modern strat spacing will work for me :)
    Without nut files, I found guys using these really cheap gas jet cleaning tools (sold on ebay as Lutherer's nut files! o_O)
    It worked great so far to pre-slot the string spacing
    Treadplatedual and eallen like this.
  2. Slowtwitch
    South Africa
    Getting closer and closer...
    Following the advise from Ron on levelling frets: http://www.tdpri.com/threads/fret-leveling-yer-tele-101.201556/, I got a 6mm thick piece of glass cut glued to a piece of melamine for a levelling beam - longer than the fretboard so that all the frets gets sanded equally.
    permanent marker (sharpie) the fret tops, 220 grit paper glued on and using a figure of 8, up and down, and across motions, it went well I hope :)
    Crowning the frets I used a small file (edges grinded off) and a small piece of wood cut at 45 deg with 2 grits sandpaper to crown the frets. marked the frets again and filed/ sanded away till only a thin line is left. This went surprisingly easy and well without a crowning tool
    Treadplatedual likes this.
  3. Freeman Keller
    Freeman Keller Tele-Holic
    Slow, string spacing is really kind of the preference of the player. Offset from the edge of the f/b can range from about 0.100 to 0.125 and depends on how you fret, how you bend, whether you thumb fret the low E and to a small extent, bridge spacing. The individual strings can be spaced on equal centers or with equal gaps between the strings. I prefer the second and that little StewMac string spacing gauge makes it dead simple.
    The welding tip cleaners will get you by for one nut (I have a set and never use them) but a good set of gauged nut files makes the job easy also. If you do any work at all on guitars that purchase will pay for itself in a short time.
    Treadplatedual and Slowtwitch like this.
  4. Slowtwitch
    South Africa
    Time for electronics.
    The soldering iron I got (40W) is not quite hot enough for the job and made life difficult, producing a
    not-so-top class looking soldering job, but all is secure and will work fine :rolleyes:
    I found what seamed like the correct wiring from an old internet/ modem cable (multi strands)
    I realise it won't be the neatest ever wiring job ever, but neither will I call it a crow's nest
    500k pots, .22 cap
  5. Slowtwitch
    South Africa
    Decided on oil to finish the neck
    Sanded to 800grit and started oiling using Teak Oil (we don't get shellac or some of the other oils here).
    Sanded with oil to 2000 grit. couple more layers by cloth and finally rubbed the oil in on my leg till there were some heat. Really liked how the darker colour started to come out
    The result is a silky smooth, velvet feeling neck.
    Very pleased indeed
    brandonh and Jupiter like this.
  6. Slowtwitch
    South Africa
    After having to sand down the backside of the body and respray, I got onto sanding and polishing.
    There are a few imperfections and I sanded through in the inside of the bottom horn due to a paint run I had to sand down, but all in all I'm very pleased with my first paint job. It does look like a professional finished guitar
    Finishing with rubbing compound, floor polish and wax to give it a glossy satin look
    Jupiter likes this.
  7. Luthi3rz
    Luthi3rz Tele-Meister
    AZ
    You mean Gasoline?
    I wouldn't use that
    Use Food Grade Hydrogen Peroxide 12% (Derived from 35%) .
  8. Slowtwitch
    South Africa
    No Not gasoline,that's oily. White Gas I believe is what it's called in the US
  9. Luthi3rz
    AZ
    Oh like Alcohol / Moonshine / Firewater / Camping Fuel.
    Denatured Alcohol.
  10. guitarbuilder
