Novice First Build: The Jawbone
Discussion in 'Tele Home Depot' started by Slowtwitch, Jan 1, 2019.
  1. Slowtwitch
    Slowtwitch Tele-Meister
    South Africa
    Stuck the neck template to the neck and routered the neck with my now fixed (phew!;)) router table.
    The result is okay, but not great, will require some sanding to get a smooth edge
    Located and drilled holes
    had some blow out with the first hole which was surprising since I did have a backing board.
    With the rest I started the holes from the back (using the 1mm holes for location) just to break the surface, but still drilled the holes from the top surface. This worked perfectly on the rest
    super close up before superglue repair
    after repair - sorted:cool:
  2. Slowtwitch
    South Africa
    On to thinning the headstock
    Checking drawings, and my various Strats, the thickness varies from 0.5inch/ 13mm (US) to 14mm to almost 15mm. I decided I like the bit thicker look so around 14.7mm (or a hair under 15mm)
    Cutting a flush line 32mm from the nut face - this will be the start to the transition curve
    Happy with the thinning
    Check the heel fit to Body No.2 which has a Tele heel. Pretty pleased with the nice tight, but not overly tight fit (neck sticks by itself but can be removed without too much effort)
  3. fsone
    fsone TDPRI Member
    Beautiful work you are doing on this axe! Looking forward to seeing the finished product.
    Slowtwitch likes this.
  4. Slowtwitch
    South Africa
    Thx fsone, I'm really enjoying the process and I'm especially glad I decided to take on a neck build as well.
  5. Slowtwitch
    South Africa
    Also tested to see how the pickguard will fit under the fretboard overhang (I'm doing 22 frets), and it should work sweet with not much free board but enough to slip in the guard.
    This means I nailed the neck pocket depth and neck thickness :cool:
    Treadplatedual likes this.
  6. mrz80
    mrz80 Tele-Meister
    Gainesville,FL
    Marvelous work so far, and that was DARNED clever with the way you put the logo on that headstock. Looks screen-printed. Might have to try that on a future build.
  7. Slowtwitch
    South Africa
    Taking stock, but still a long way to go
    Macrogats likes this.
  8. Slowtwitch
    South Africa
    Yeah thx, the only issue would be if you'd prefer a oil wood finish as oppose to a varnish finish it won't work, since the ink requires to be sealed
    Cheshiergrin likes this.
  9. Slowtwitch
    South Africa
    I realised saw cutting an accurate cut is not easy!!!!
    It took me THREE attempts at making a reliable mitre box and I think I now will be able to cut accurate fret slots
  10. Slowtwitch
    South Africa
    More precise work, this time cutting the cavities for the pickguard.
    This wasn't easy either!!!!:confused:
    Ended cutting it first in Masonite, filing the corners which I was concerned wouldn't look great, but turned out fine and happy with a good fit.
    Then I cut the cavities in the MDF router template i.e. so didn't file the corners, since this will be done by hand on the actual guard
    I decided to move the neck pup slightly further back from what a Tele HH position is, so had to router the cavities by a few mm on both Body No.1 and 2. They don't look that eloquent any more, but it will be hidden ;). I wanted to make sure the pups have sufficient space now that I've finalised the pickguard layout.
  11. Slowtwitch
    South Africa
    Looking at the cavities and with the weight of the body still on my mind, I decided to try cut down on some weight, so deepen the cavities and increase cavity under the pickguard in areas where one won't notice it (like a press point for little finger or control knobs are)
    I managed to shed about 400grams and it def helped
  12. Slowtwitch
    South Africa
    So FINALLY the day has dawned!!
    Time to cut the frets :cool:
    I tried to print a fret layout drawing to scale without success.:mad:
    I used 3 different sources to generate the drawings, the last being CAD and a few different printers, but non of them could print out spot on. The only thing I didn't try is a plotter (my mate's plotter needs servicing), so I'm still keen to see how accurate the plotter prints.
    I decided then to rather take the fretboard to scribe the lines using CNC. Sourcing the correct bit for a CNC router and to cut the slots is not easy and most recommended not going that route, hence me only scribing the board to mark.
    My mitre box at work :). So far so good
    The nut slot
    All done and very pleased:cool:
    I didn't cut too accurately the slot depths, since I still need to radius the board and reckoned I'd finalise the cuts once the board is radiused
  13. Slowtwitch
    South Africa
    Next is dot inlays
    Making sure I mark the correct frets - I've heard many reports of guys accidentally marking the wrong fret. Don't want that to happen with me!
  14. Slowtwitch
    South Africa
    Various stages from test on the actual board off-cut to filing dots
    I got some Loctite Gel superglue, not the cheapest around, but it worked very well for the inlays, even overrunning onto the fretboard didn't seep into the voids and grooves too much like the runny/ watery superglue I used during testing :)
    "Filing" out the nut slot using a thinnnnn piece of 150 grit when you don't own nut files
  15. Slowtwitch
    South Africa
    On to radiusing the board using my not-so-fantastic-looking-but-servicable 12" radius beam with depth stop sides
    Lets find out how it works in practice :)
    Getting there but more needed
  16. guitarbuilder
    I did my first radius block like that in the 80's and it wasn't half the size of that. Maybe about 1/3 the length of yours. Not too many people venture into that glue up territory...LOL.
  17. Slowtwitch
    South Africa
    Router bits are short, which is my only means, so gotta use what I got and make do :).
    I see there's a few low spots in the beam and only some areas make contact with the board, but slowly it's getting done. I started with 150 grit but were having to change twice already. So I changed to 80 grit, which doesn't seem to scratch the surface too much that I'm concerned
  18. Slowtwitch
    South Africa
    So this took waaaaay longer than anticipated!! :confused:
    But it is the first time and eventually I got there.
    Just final sanding required, maybe 320 grit to "polish" out some fine lines and double checking levels all round, but it seems pretty even
    Got tired using the big block and having to change taped down paper all the time, so I decided stuff it and cut the beam short and no longer using double sided tape but now I could rap a piece of paper and change paper quicker
    Lessons learnt:
    - You don't need a long beam from Stew Mac
    -the depth stop design does help to keep the sides even both sides
    -2 fences is a must to guide the beam
    -change sand paper often
    -I used 80 grit which worked, but to be safe maybe 120 is a good call - not all 80 grits are equel and some may leave deep scratches, mine didn't
  19. guitarbuilder
    After you do enough necks, you'll see why people go nuts for the long metal radius beam....:).
  20. Slowtwitch
    South Africa
    Borrowing a calliper to be as accurate as possible
    Pretty pleased with a consistent thickness at 6.60mm which is slightly more than the design 6.4mm, but at least it's consistent :)
    On my way there
    As I'm sanding down, the fret markers are looking much better, and I'm also pleased how they look close up with no oversized holes, or irregularities showing. I give it about a 9/10 :cool:
