Novice First Build: The Jawbone
Discussion in 'Tele Home Depot' started by Slowtwitch, Jan 1, 2019.
  1. guitarbuilder
    In case you want to bypass the gross part...well sort of, pet stores sell bleached bones for dogs.
    https://www.pawstruck.com/products/...MIvKiH3YD94AIVj4vICh2Hkg5xEAQYBSABEgKC4_D_BwE
    I've been rolling my own for over a decade now.
    Slowtwitch likes this.
  2. GPlo
    GPlo Tele-Meister
    Netherlands
    Cool stuff man. I like all the little detours you’re taking while building a guitar (and learning along the way). How much time are you able to spend on all this?
  3. Slowtwitch
    Slowtwitch Tele-Meister
    South Africa
    Currently I do have some time at hand, but the main thing is to think things through, test run them make sure I know what I'm doing before ruining something.
    Kinda measure twice, cut once principle;)
    Lake Placid Blue likes this.
  4. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Your plan for the flexible saw with wood depth stops plus stiffeners is what I do too. I have a 'flush cut saw' used for cutting dowels off at the surface, I hammered the kerf narrower then ran a strip of double-sided tape and a wood strip to set the depth plus keeps the blade straight. Works great.
  5. Slowtwitch
    South Africa
    I'm not following, can you explain bit more?
    So far my trials hasn't been so successful as planned. With the stiffners glued to the flush cut blade, and with only 2mm of teeth sticking out at the bottom, I can't see the line I need to cut. I did start the stiffners 1 tooth back from the leading edge so I can see the line, but can't see at the back (handle side) so the blade wonders a bit and I tend to scratch the surface a bit all over before there's an actual groove forming - even with a side fence in place
    This is of course on test pieces
    I'm now thinking of making a small MDF mitter box to suit this thin blade i.e. purpose built mitter box that'll take a fretboard blank(with square edge to cut perpendicular) and cut the blade slot with the actual blade so it fits tight and keeps the blade in place and vertical
    I could still do a depth stop with pieces clamped at the top to stop against the box sides
  6. Slowtwitch
    South Africa
    Here it is... and happy with the results so far!
  7. Slowtwitch
    South Africa
    I managed to borrow a friend's drill press!:D
    And with my neck pate having arrived, it's time to drill a few holes quickly....
    NOT!!!!!
    First mark neck bolt positions on body No.2
    Clamping the wood down with a backing board (to prevent breakout) ain't that easy or quick
    Drilling lesson: move the backing board after every hole drilled. Doing 4 holes will eventually cause breakout, as can be seen here - hole no.4 bottom right, not too major, but still could have been prevented
    Good fit
    On to body No. 1
    This little exercise took a few hours
  8. Slowtwitch
    South Africa
    While I'm at it, I drilled a few holes for my templates
    Not that easy to drill accurately I learnt today, but taking my time, I'm happy with the result
    Pick guard screw holes
    I'm really not happy with the pup cavity, I'm thinking to take those cuts to CNC
  9. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    For future reference drill the neck holes from the back before routing the neck pocket then blowout won't matter. Great looking bulid!
    Lake Placid Blue and Slowtwitch like this.
  10. Slowtwitch
    South Africa
    Thx for the advise
  11. Slowtwitch
    South Africa
    Slowly but surely the pieces are starting to come together
    Remember the completely wrong drilled holes when I bought this neck?
    Well time to set it right! Note the 2 x 12" profiles used from my soon to be radius block to seat the neck properly.
    Fitted the neck to body, aligned properly, clamped down and marked the neck holes through the body drilled holes
    Body was drilled @ 5mm dia. so the bolts don't screw into the body only the neck. Neck holes I'm drilling 2.5mm dia.
    Happy with the fit
    And happy with the alignment! Remember to wax those neck bolts before screwing in. I use candle wax
    I still haven't received my bridge. Also the machine heads I ordered arrived but they sent me LEFT hand tuners :confused::confused::confused:
    Without those pieces I can't drill the final holes, and I don't want to paint the body before all the holes are not drilled and I've checked intonation etc.
    So I can't go much further on the body for now
    PATIENCE
    Treadplatedual likes this.
  12. TRexF16
    Tucson
    Regarding your bone nut blanks, one of the advantages of real bone for a nut is the very small amount of natural grease that remains in the bone providing a natural lubricant for the strings. You might consider not leaching out 100% of the grease from the bone. A little bit remaining may not hurt.
    Your build is coming along nice and you are doing a great job of problem-solving and thinking through you steps before taking them!
    Cheers,
    Rex
  13. Slowtwitch
    South Africa
    Thank you so much Rex!;)
    The nuts are in Benzine (white gas) right now
    Any idea for how long to leave them then?
  14. Davecam48
    Queensland Australia
    That must be a very small kitchen or a HUGE bottle!:lol:
    DC
  15. TRexF16
    Tucson
    Unfortunately no, I've no idea at all. I'd pull them out after a week and let them dry thoroughly, then see if they feel right. Just a hint of natural slickness. Repeat as needed?
    Just my two cents. I've never cut nuts from bone that fresh myself.
  16. Slowtwitch
    South Africa
    I finally received fret wire, truss rod and pick guard blank! :cool:
    BUT, they sent me one 2ft piece of fret wire. Enough to fit in 12 frets - half a neck. Who sells half a neck's fret wire????? Well ALLparts do!!!!! What are they thinking????:confused::confused::confused::confused:
  17. Slowtwitch
    South Africa
    Drilling some holes now that I've received strap buttons and input jack plate. The side of the hole just touching the side of the cavity to route wires. The bubbling you see is the sanding sealer top layer, so no biggy, just smooth it out
  18. Slowtwitch
    South Africa
    Surfboards??? You must be kidd'n
    A mate of mine said I'm welcome to use his shaping bay to spray, so this is part of my learning curve.
    I've never used a spray gun before, so decided to learn on an old longboard of mine :)
    My mate was surprised to hear it's my first time ever using spray equipment :D
    Technique done, spray job.... o my word what a mess!!!! He didn't realise the primer we used didn't need hardener, so it's a total stuff up with the primer not sticking :mad:. O well sand all off and start again for more practice time I guess :confused:
  19. Slowtwitch
    South Africa
    Now that I've received the Allparts double action truss rod (same as Bitterroot rods), I can start with the neck :)
    Following Fletcher's steps, I start with the truss rod route while I have a jointed edge.
    My table router's nut thread is stuffed (cross threaded) from all the changing of the collar between the 2 routers, so while I wait for a fix (hopefully!!!!), I decided to do this using the hand held router.
    One or 2 places the router wondered slightly, but nothing too serious and afterwards felt it was a good choice to use the hand held
    Following the advise from this thread http://www.tdpri.com/threads/truss-rod-installation-headstock-adjust.915489/ I decided to go with Rex's method for access to the peghead adjuser.
    The nut is at 20 with the truss rod end set back 3mm. In hindsight, I'd rather stop the access route 3mm shorter, now that I've tried the allen key
  20. Slowtwitch
    South Africa
    Rough cut
