NGD handmade thinline tele
Discussion in 'Tele Home Depot' started by morky, Aug 8, 2018.
  1. morky
    morky Tele-Meister
    182
    Jun 23, 2016
    Athens, Greece
    I agree but that's happening because the saddles are too far back. I can't see why a shim would help with that. Can you explain further?
    Also the angle in the picture looks much more exaggerated than in reality. It's not more than 90 degrees. It's actually less than 90
  2. esetter
    esetter Friend of Leo's
    Sep 1, 2011
    MI
    Great looking build. Wenge is a great wood for a neck.
  3. Ira7
    Ira7 Doctor of Teleocity
    Jan 8, 2008
    Coral Springs, FL
    I'm not qualified to explain it any better.
    And on the mathematical side, the break can't be less than 90. It would have to be more! And it should be.
  4. Ira7
    Jan 8, 2008
    Coral Springs, FL
    Okay:
    A shim in the BOTTOM half of the neck pocket brings the strings down, in the way it angles the neck. So you can now lower those saddles.
    And by a shim, we're talking VERY thin material.
    In many cases, people just a business card! But in more extreme cases, you would need two.
    For my builds, I use a wood veneer. It's like paper thin, but maybe a little bit thicker than a business card.
    Of course, the way your nut is cut and placed matters too, but first things first.
  5. morky
    morky Tele-Meister
    182
    Jun 23, 2016
    Athens, Greece
    You are completely right. The angle is bigger than 90 degrees. I confused things for a bit there
  6. Ira7
    Jan 8, 2008
    Coral Springs, FL
    Wait until you get my age:
    Confusion becomes your friend, because it helps you forget how old you are.
  7. morky
    morky Tele-Meister
    182
    Jun 23, 2016
    Athens, Greece
    Oh I get it now. I already have installed a shim in another guitar I have but that was mostly because I couldn't get the action right now matter what.
    Maybe I need to do that with this guitar too
  8. morky
    morky Tele-Meister
    182
    Jun 23, 2016
    Athens, Greece
    I also need to add a bit info about the nut. There are definitely flaws with it, some slots are crooked, the slot size is a tiny bit bigger than needed in a few slots and I used a variety of saws, files and sandpaper I had to cut the slots and make them smooth. But I believe the slot depth is correct in all strings and the slot is cut at the correct angle following the path of the string thus making contact with the nut smoothly and mostly on the end of the slot. It definitely isn't perfect but I believe it's good enough for a first timer. I will replace it though sometime in the future.
  9. Ira7
    Jan 8, 2008
    Coral Springs, FL
    It's not just the slots:
    It's how the neck was carved to sit the nut. Too shallow? Too deep?
    This is way beyond my building experience. I buy necks with installed nuts.
  10. Macrogats
    Macrogats Tele-Afflicted
    May 15, 2017
    Auckland, New Zealand
    That's a great looking body, and you guys did a great job on that neck. Very nice looking guitar!
  11. ponce
    ponce Tele-Holic
    627
    Dec 21, 2011
    Croatia
    Nice! Is there any kind of truss rod in the neck?
    Now you need a headstock logo in a bouzoki style (artificial) ivory inlay!
  12. cleanheadsteve
    cleanheadsteve Tele-Meister
    164
    Mar 4, 2010
    Arkansas
  13. SoulstormTX
    SoulstormTX Tele-Meister
    313
    Jul 14, 2017
    San Antonio, Tx
    Insanely slick guitar youve got there buddy. Congrats.
  14. sothoth
    sothoth Tele-Holic Platinum Supporter
    607
    Nov 24, 2010
    Kepler-186f
    Really beautiful work!!
  15. caliban335
    caliban335 Tele-Afflicted Silver Supporter
    May 4, 2007
    Cleveland, Ohio
    Very nice. A different take on a Tele. Well done.
  16. morky
    morky Tele-Meister
    182
    Jun 23, 2016
    Athens, Greece
    Thanks a lot! I'm glad all the work actually payed off and that there are people that like the guitar!
  17. Wrighty
    Wrighty Tele-Afflicted
    Aug 17, 2013
    Essex UK
