new project
Discussion in 'Stratocaster Discussion Forum' started by wired to go, Jan 24, 2013.
  1. wired to go
    wired to go Tele-Meister
    371
    Aug 22, 2010
    Bridgeport,NY
    strat4.jpg Here is my newest project. It's a Squire Afinity Strat. I'm in the process of gutting it. I'm putting 2 lipsticks and a full size rail humbucker in a white pearloid pickguard. I'll be using a 5 way, coil split (push pull pot), a master volume , master tone and a volume for the humbucker. My question is Should I use the original neck and trem? Are the mounting screw holes the same as the Mexican or American Trem? I would really rather have a better trem block than the original cast one.
  2. michlgasser
    michlgasser TDPRI Member
    15
    Feb 20, 2012
    AUSTRIA
    Good morning! (at least at my place)
    I would definitely keep the neck as long as it feels good for you.
    The affinity necks are very well made, as far as I can tell.
    The trem screw placing is usually the same.
    Have fun with it!
    Greetings
    Michl
  3. wired to go
    371
    Aug 22, 2010
    Bridgeport,NY
    Guitar Fetish has a replacement bridge with a brass block. I'm going to order it and my pickups from them. I am also going to eventually replace the neck with a Warmoth fatback neck, probably an Warhead model, Using the original for a while. I like fat necks.
  4. Twang Factor 10
    Twang Factor 10 Tele-Meister
    251
    Jun 26, 2011
    Leoma TN
    This is just a hunch, and I haven't experienced this personally, but the trem screws on the Squier maybe on a metric screw spacing. I have put a USA pick guard on a MIJ strat. Screw holes did not line up nor did it fit like the MIJ guard. A little tweaking and we made it work though.
  5. thumbpick
    thumbpick Tele-Afflicted
    Nov 22, 2012
    somewhereville
  6. wired to go
    371
    Aug 22, 2010
    Bridgeport,NY
    I got a metric spaced trem from GFS.
  7. wired to go
    371
    Aug 22, 2010
    Bridgeport,NY
    Almost done. I'm waiting for the neck I bought on E-bay. It's a Mighty Mite in gloss clear with a roller nut. Just couldn't afford the Warmoth neck. Can't wait to play it. I'm thinkin' I'll be able to get a lot of different sounds mixing that rail 'bucker with the lipsticks. The rail has it's own volume and a coil cut; I set the push/pull to be single coil in normal position. I also added a push/pull neck pickup on.
    [/ATTACH]
