new mystery import three~way wiring question
Discussion in 'Tele-Technical' started by Pierce, Jun 12, 2019.
  1. Pierce
    Pierce Tele-Holic
    skull island
    center is "out".. I have neck/bridge figured out. nothing for the middle.
    Am I jumping wires somewhere?​
  2. Deaf Eddie
    Deaf Eddie Friend of Leo's Silver Supporter
    Beautiful Idyllwild, CA
    Unless that has five stops, it's gonna suck on a three-pickup installation. It APPEARS to be a single-pole three-way, with two lugs at each pole. For a two-pickup setup, this would work fine to get the regular neck / neck+bridge / bridge combos. For three-pickup setup, you'd have to decide what you wanted for the middle throw: middle alone; middle plus neck; or middle plus bridge.
  3. Pierce
    Pierce Tele-Holic
    skull island
    standard tele.. I can get a continuity for the neck position/bridge position.. but not in the center position
  4. guitarbuilder
  5. tessting1two
    tessting1two Tele-Meister
    Southern California
    Since we both have no more hair to lose I would put it this way: it's a question of whether the time and effort you're investing into this oddball switch is worth more than the $15 it would cost to get a CRL switch that would last for decades. Just measure the existing switch's depth and mounting screw spacing and compare to the CRL specs to ensure fitment.
  6. Pierce
    Pierce Tele-Holic
    skull island
    I need the shallow draft.. aka the crl is too deep.. and I have a dozen of those so, I would be using them if I could
  7. tessting1two
    Southern California
  8. Pierce
    Pierce Tele-Holic
    skull island
    got that too... . That is heavy duty compared to the others.
    Thats why I posted the question on that specific switch as the others are too deep
  9. Deaf Eddie
    So... in other words, the middle lug of the (two) rows of three has no continuity with anything, ever?
    I would think that the center lug of the switch is the common, and the other two rows duplicate each other but in reverse order, for example:
    ..1 ………….… 1
    2 ……..C...…. .. 2
    ..3 ……………. 3
    throw 1; Lug 1 on the left has continuity with the center lug and lug 3 on the right;
    throw 2: Lug 2 on the left has continuity with the center lug and lug 2 on the right;
    throw 3: Lug 3 on the left has continuity with the center lug and lug 1 on the right.
    If that IS the case, then the neck could go on lugs 1 & 2 on the left, and the bridge on 1 & 2 on the right, center lug to volume pot.
    If that's not the case, then I don't know what...
    LutherBurger likes this.
  10. Pierce
    Pierce Tele-Holic
    skull island
    thanks for your help// I will do a dry run outside the guiatr before I do the snake charmer part
  11. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    Hi Pierce
    The answer can be found in your post over at Strat Talk courtesy sjtalon.
  12. Pierce
    Pierce Tele-Holic
    skull island
