New Design Proto Build - Lyra
Discussion in 'Tele Home Depot' started by preeb, May 16, 2019.
  1. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    Neck joint needs to be very tight and void free for best tone and jointing strength.
    I make sure the tenon is sitting tight in the mortise and that all surfaces are flat and gap free all around by carefully and slowly chiseling the area
    Neck should be snug even without gluing
    cutaway edges are marked for sanding
    and most of the excess material is sanded off
    Once everything is checked including fit and neck angle for bridge clearance the board is ready to be glued.
    I'll be using hide glue
    nut slot is wiped clean
    and necks are set aside overnight
    Zepfan, Random1643, ponce and 2 others like this.
  2. Barncaster
    Northern California
    What’s for pickups Gil?
  3. Norris Vulcan
    Norris Vulcan Tele-Holic
    Somerset, UK, Europe
    Reminds me a bit of this, which happens to be one of my favourite designs:
  4. preeb
    Sonoran Desert
    Something you have never seen before (-;
    Jim_in_PA likes this.
  5. preeb
    Sonoran Desert
    One of my dream guitars as a kid.
    Designed in the 70's by Fujigen Gakki who also built guitars for Ibanez, Greco, Roland (GR-303) and others...
    I admit I had this in the back of my mind when deciding to go for both a double cut arched top and the round-over edges.
    Killer design except for the "so so" tone and boat anchor weight unfortunately... so I hope I'm doing some kind of justice by making the Lyra sound great (emphasizing "hope") (-;
  6. ponce
    ponce Tele-Holic
    Croatia
    Knowing your experience in building first - class guitars, do you think that "so so' tone is due to bad wood choice or a pickup option?
  7. preeb
    Sonoran Desert
    Usually wood. A great guitar with a bad PU sounds good, a bad guitar with the best PU still sounds bad
    Sterling Sound, Zepfan and ponce like this.
  8. ponce
    ponce Tele-Holic
    Croatia
    Deleted
  9. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    Some guitars just ring without being plugged in. Good wood and solid joints do that. Beautiful work preeb.
    Barncaster likes this.
  10. Barncaster
    Northern California
    Such a tease.....
    Zepfan likes this.
  11. preeb
    Sonoran Desert
    It is easier to tune the top before the neck is glued to the body but I need the neck for tuning.. so here's what I do
    tops are sanded
    I will use a thick scraper to thin the re-curve perimeter
    and deepen the recurve a little at a time
    before tapping I insert the neck to get a true tapping tone of the assembled instrument
    I try to do it little by little because it is very easy to miss the sweet spot and overdo this..
    Once I get a rich big bell tone I stop and measure the recurve all around to make sure it is more or less even
    If all is OK I rough sand the scraping marks and blend the new recurve surface to the top
    done
    The maple top build ended up with slightly deeper recurve for its sweet spot
    Both will get the neck glued once the necks are shaped and ready to be glued in a couple of days since I have to let the necks completely acclimate after the board hide gluing.
    If any of the necks warp due to the introducing of water (in the hide glue) they will be discarded and it is better to catch this before gluing the necks to the bodies... (-;
    Here are the final tap tones. Very good level and timbre for both but note the difference..
    Jim_in_PA, Mxk116 and Zepfan like this.
  12. preeb
    Sonoran Desert
    Thank you.
    Yep.. but wood matching is above all.
    Most wood blanks sound ok and the main reason for failing to fulfill the full potential is the mismatch
  13. preeb
    Sonoran Desert
    Not trying to tease.. it is still in development and testing.
    Waiting for Teoni to finish the winding so I can test them... it will take a while and I may not like it so I'd rather shut up about it for now until I get some satisfactory results from a very wild design idea I have in mind.
    CFFF, Barncaster and Zepfan like this.
  14. telechadster
    telechadster Tele-Meister
    Vancouver
    Wow what a beauty! Love the design!!
  15. preeb
    Sonoran Desert
    Some last body drills left to be done.
    Template is used to mark the input jack and strap buttons locations
    With special attention to the top horn drill. It is always a pain to put a strap button on a non flat surface not to mention a pointy horn edge...
    I opted to install it against the bottom flat of the horn. It is nicely angled and sits flat.
    The large strap locking system I'm using will look nice this way too
    5/16" from the edge to have enough room for the button
    since the body is hollow in that area I will drill through the wall as shown
    done..
    rear strap button drill is centered
    input jack drill is done with a leveled drill
    like this
    Zepfan and BluesBlooded like this.
  16. preeb
    Sonoran Desert
    48 after gluing the board the neck is checked for any movement or warping..
    Using a flat steel straight edge on the flat back of the neck is a great way to verify there is no warpage
    All is good! I will check it again after shaping the back of the neck and before gluing to the body tomorrow
    Zepfan, Barncaster, Mxk116 and 2 others like this.
  17. Greg M
    Greg M Tele-Holic
    Virginia
    How will the truss rod be adjusted? And great design btw ;)
  18. preeb
    Sonoran Desert
    Thanks.
    Trussrod will adjust from the body end of the neck. I will post it shortly
  19. DrASATele
    North of Boston
    Very inspiring Gil!
    Are you teaching any classes in your shop?
  20. preeb
    Sonoran Desert
    Thanks.
    Classes? No. My shop is my quiet asylum from this world (-;
