New Design Proto Build - Lyra
Discussion in 'Tele Home Depot' started by preeb, May 16, 2019.
  1. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    I like those because I use the same 2D program for all angles
    Jim_in_PA likes this.
  2. preeb
    Sonoran Desert
    Thx. Never left
  3. preeb
    Sonoran Desert
    Thank you (-;
  4. doug
    doug TDPRI Member Silver Supporter
    Boston,MA USA
    Do you use stainless steel fret material?
  5. Fretnot
    Fretnot TDPRI Member
    PA
    This build is lifting my spirits. :)
  6. preeb
    Sonoran Desert
    I do not. Don't like the harsh tone.
  7. preeb
    Sonoran Desert
    Holly headstock veneer is cut about 0.1" oversized
    MOP inlays located and locked with tape on the rear
    Black filler applied
    those will sit for 24 hours to cure
  8. preeb
    Sonoran Desert
    fingerboard binding are downsized on this jig.
    Front
    Back
    and front end
    like this
    further trimmed and cleaned with a file to create the nibs
    Back is scraped flat to remove any glue leftovers..etc..
    and the side dot marker holes are marked and drilled on this jig
    Like that
    Dots are punched out of celluloid acetate sheets, cream for the Lyra and red tortoise for the Bone.
    Glued in with acetone glue
    I make sure the relaxed dry fit is 100% tight before gluing
    I will let both the necks and the boards to relax for 24 hours before final fitting and gluing
  9. preeb
    Sonoran Desert
  10. pmjennin
    pmjennin TDPRI Member
    Seoul/Indiana
    Always inspiring, Gil. Thanks for sharing.
  11. KingKara
    KingKara TDPRI Member
    Tricity
    Hello preeb ! And everybody here as this is my first post :)
    My name is Filip and I’m from Poland.
    For many years I was working as accountant and for last few years as RPA developer. Recently my company - Sony Pictures- has closed its offices here in Poland and I found myself unemployed for the first time in 15 years...
    I was always inspired by your work and was thinking that one day I could do something remotely close to what you’re doing.
    So I thought that it’s the sign from above and decided to start a new adventure in my life and build guitars for a living :)
    With all that I don’t know what future holds but just wanted to say THANK YOU! for the inspiration.
    CFFF and CraigB like this.
  12. preeb
    Sonoran Desert
    E
    You are very welcome.
    Why "remotely close"? Do better.
    CFFF and KingKara like this.
  13. preeb
    Sonoran Desert
    Birch wood dowels are cut to be used as indexing pins for the fingerboard. This will ensure accurate board location over the neck during the gluing of the headstock veneer and the board itsalf later on..
    Veneer is aligned over the headstock and marked for trimming
    Trimmed and chamfered to fit the nut at the 17° headstock angle
    UF glue
    and clamping. Nut is only used for correct placement of the veneer and is not glued at this stage
    24 hour curing
    pixeljammer and BluesBlooded like this.
  14. preeb
    Sonoran Desert
    veneer glue cured
    I made a headstock (without a neck) to play with the tuner locations and see how things look before finalizing the cutting template
    Looking nice and balanced
    Headstock outline and tuner holes are cut on this jig
    Tenon sized and shaped
    Headstock face and sides are sanded smooth before I glue the board
    and board is placed to verify the nut slot width is 100%
  15. Luthi3rz
    Luthi3rz Tele-Meister
    AZ
    Why UF Glue and not Hide Glue?
  16. BluesBlooded
    BluesBlooded Friend of Leo's
    Sherbrooke, Qc, Canada
    Your work process is very inspiring.
    Thanks for sharing, I learn something in every post.
  17. ndcaster
    ndcaster Poster Extraordinaire Silver Supporter
    Indiana
    um, WOW
    Gil, what a pleasure to see someone with so much care for craft and in such a modern way. Thanks for letting us have a look.
  18. preeb
    Sonoran Desert
    UF is just as hard as hide glue and has a longer open time. It is more stable in humid/hot conditions.
    I use hide glue only for joints that may possibly need to be disassembled for repair down the road such as neck/body and fingerboard.
    Luthi3rz likes this.
  19. preeb
    Sonoran Desert
    Thank you, pleasure is all mine
  20. preeb
    Sonoran Desert
    Thanks! Glad to share
