New Design Proto Build - Lyra
Discussion in 'Tele Home Depot' started by preeb, May 16, 2019.
  1. Mars Hall
    Mars Hall TDPRI Member
    Winfield Indiana
    It seems you're taking Ted McCarty's ES-3X5 design to logical next level. I already want one! I'm trying to gather how you'll tune the top, from the outside of the body or do you plan to tune it from the inside through the vent holes?
  2. matmosphere
    matmosphere Tele-Meister
    District of Columbia
    My thoughts exactly.
    Or did you already tune the top before glueing?
  3. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    One of the reasons the Lyra body can only be machined on a cnc is the top tuning process. Top carve profile is fixed but the top thickness will be used to tune it like it's done on classical and flamenco guitar tops. I will run the same carving program again and again while changing the depth of cut and tapping to test the tune until I get to the desired Timbre
    BB likes this.
  4. Freeman Keller
    Freeman Keller Tele-Afflicted
    Having built a few acoustic and arched topped instruments (by hand) I will be watching this with interest.
  5. preeb
    Sonoran Desert
    You might be interested in the Bone Voyage build as well which is a 13" arched top build
    Here: http://www.tdpri.com/threads/bone-voyage.530380/
  6. Kinghat
    Kinghat Tele-Meister
    Texarkana, AR
    It may be obvious, but could you describe the differences in the Bone Voyage and this new design?
  7. preeb
    Sonoran Desert
    Fully hollowed arched top
    Too many to count. in a few words... semi hollow vs fully hollowed arch top.
    I suggest you visit the Bone Voyage build thread to see what it's all about and then wait for this thread to end. At that point you will have your answer.
    Kinghat likes this.
  8. preeb
    Sonoran Desert
    I will not get into detail about the neck as it is mostly similar to my Bone line in design...
    Here's a few shots from the process
    pixeljammer and BluesBlooded like this.
  9. preeb
    Sonoran Desert
    Tops need to be carved now in order to tune them along with the backs.
    Initial height set with this template. This is the max size and I will continue to thin the top multiple times until I hit the desired tone as previously mentioned
    Tops are cut
    Drills and Vent holes are also cut prior to tuning
    I repeat the top carving until I get to the desired note and then thickness the back down to match it
    BluesBlooded likes this.
  10. preeb
    Sonoran Desert
    To isolate the top and back I lay a small cloth rag on the table and set the body on top of it so what I hear is just the top or just the back tapping
    Here's the final tuning vids:
    The Mahogany top/back
    And the maple
    Even though the tap volume is about the same between the models, the Maple top timbre is still noticeably different than the Mahogany in both note and color
    CFFF likes this.
  11. deytookerjaabs
    deytookerjaabs Friend of Leo's
    Nashville
    Awesome!
    Think you'll ever spec one like the early Gibson electric doublenecks (only with one neck, lol)? think they had a hollowed out maple body with a carved spruce top, no top holes/vents though.
  12. preeb
    Sonoran Desert
    It's a little funny to see the body almost complete but kept in the rectangular blank shape..
    The reason for this is the need to have a flat base on the top side to set the body for the back cavities routing
    Done
    You can now view the floating top from the inside
    The STP insert drill is deeper than standard with the opening on the top only being slightly larger to allow the top to freely vibrate while the STP is still anchored to the mahogany core.
    This is an important part of the Lyra's design where the strings are anchored like on a solid body but the bridge itself is connected to the floating top to vibrate it properly.
  13. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    Awesome Gil! Nice to have you back!
  14. Fretnot
    Fretnot TDPRI Member
    PA
    Love it!
  15. preeb
    Sonoran Desert
    Worth mentioning... I have an old original Kalamazoo 335 top I use for templates..etc.. and comparing the thickness I found it to be identical after sanding to the Lyra's sweet spot thickness. Does it mean anything? I don't know but it is interesting.
    DrASATele likes this.
  16. preeb
    Sonoran Desert
    Mortise is cut to accommodate the neck tenon at a low 3.8° angle. I'm using triangular jigs for different angles
    Cut
    Outline is cut
    and the rims are sanded to remove any routing marks to a smooth clean surface
    I_build_my_own likes this.
  17. preeb
    Sonoran Desert
    The Lyra body will not get any binding. I want a super comfy round-over on the top and back edges.
    Plus.. I believe it will look awesome with the deep top re-curves (-;
    I will use this dome jig to run the top edge rounding manually
    This is a two hand delicate operation so no photos...
    but it looks like that when done..
    and the back is done normally on a flat table
    I stopped the rounding in the middle of the cutaways and will blend them in with a file after the neck is glued and the heel is carved...
    rojo412 and Freekmagnet like this.
  18. preeb
    Sonoran Desert
    A few more shots..
    The top is floating half way through the tenon
  19. BluesBlooded
    BluesBlooded Friend of Leo's
    Sherbrooke, Qc, Canada
    Superb work Gil.
    I like the idea of the triangle shim under the body for the angle neck pocket. I use a 3D cut in this circumstance, but will keep this technique in the back of my mind.
  20. preeb
    Sonoran Desert
    Boards are dark Brazilian Rosewood with MOP dots and kept as simple and classic as possible to fit the earthy clean look I'm going for... the Lyra is all about tone and comfort so no real need for fancy stuff (-;
    Slotted
    Dry fretted with a hammer
    and checked for zero bowing after frets are installed
    I now inject thin CA glue under the frets
    and let it get sucked up to the board surface under the frets
    Edges are squared along with the fret ends
    Like that
    Even though I opted for no binding on the body I still want them on the board but with a very subtle look... as if they are not there.
    Here's a beautiful Italian brown celluloid that matches the Brazilian Rosewood color perfectly
    Start with the board end edge using clear acetone glue
    Trimmed
    and sanded flush
    Sides follow..
    and set aside to cure for a couple of hours
    Neck headstocks are widened for the wider Lyra's headstock outline
