New Design Proto Build - Bone
Discussion in 'Tele Home Depot' started by preeb, Mar 28, 2013.
  1. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    Thank you Palladio.
    Slab cut means that the log has been sliced the usual flat way.
    Center Slab board is a board that is closer to the center of the log so the arcs or the end grain are rounder and the edges of the board are closer to rift.
    Those boards allow more control of the high frequencies depending which side is selected to be facing up (top). The down side is that they tend to move more in the drying process so I have to start with a 2" initial thickness and lose some material when final truing then. Those bodies usually sound a little brighter and open and the wavy pattern on the sides (by the waist area) is more dramatic and beautiful. I use this cut for all my LP builds as well.
    The weight will be ~7 lbs.
  2. preeb
    Sonoran Desert
    I believe Gibson used the more common featherwight Balsa as a center block for the semi hollow designs (totally different than the Bone model) and the idea was to save weight and not necessarily control tone. I only assume so and I might be wrong.
  3. preeb
    Sonoran Desert
    Same here (-;
  4. preeb
    Sonoran Desert
    Thanks. What did you like in particular?
  5. preeb
    Sonoran Desert
    I'll be using normal weight tuners but Steel for the bridge is not an option here.
    The bridge needs to be light and the bridge inserts need to be deep and heavy.
    This has a lot to do with the tone and the dynamics of the instrument.
  6. rapfohl09
    rapfohl09 Tele-Meister
    New York
    This is gonna be so great! I love watching you work!
  7. JohnnyAtomic
    JohnnyAtomic Tele-Afflicted
    Little Rock, AR
    Subscribed to another great GY thread
  8. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    Happy birthday Gil!
    This is great as always!
  9. Glen Smith
    Glen Smith RIP
    Happy Birthday Gil !
  10. preeb
    Sonoran Desert
    Thank you!
  11. Mark Grant
    Mark Grant Tele-Afflicted
    Northern California
    Can't wait Gil! Great ideas here. You're so inspirational to me. I hope to someday do something nice for you to return the favor. We have our truss rod jig built and I'm about to really get moving on the one piece maple neck for my flying t. Thank you so much for all the help!!! Happy Birthday, hope it's a great year for you.
  12. preeb
    Sonoran Desert
    Thank you so much Mark!
    Good luck with the neck.
  13. daddyopapa
    daddyopapa Tele-Afflicted
    BC Canada
    Subscribed for coolness.
  14. joe desperado
    joe desperado Tele-Meister
    Chicago
    Les Paul Studio lite (91-ish) is a hollowed out LP with Chromite ( balsa wood) filled in a similar fashion as this build. Mine sounds amazing and saves about 2 pounds.
  15. Revv23
    Revv23 Friend of Leo's
    Michigan
    I've been wondering where The LP updates went. Congrats Gil, this is a great new chapter. Can't wait to see it come to life... :)
  16. Bentley
    Bentley Friend of Leo's
    Kelowna B.C, Canada
    Looking great!
  17. koolaide
    koolaide Tele-Holic
    south carolina
    Another thread from the original:)
    Happy birthday Gil!
    Jim
  18. preeb
    Sonoran Desert
    I carve the top on the duplicarving jig but for the proto I will go in tiny 3mm depth steps.
    This way I will be able to measure the symmetry of the cuts as I move along and make changes to the master carve template if needed.
    Jig is set up
    Symmetry measurements
    Until it's done.
    I now smooth it until all the carving marks are gone
    Pot holes drilled
    and the body is set on the secondary control rout jig and routed
    to get the bottom roughly perpendicular to the top dish
    It stays in the same jig for the pot diameter cleanup
    I try my best to avoid the side wall damages as seen on the original bursts...
    Done
    Thickness in all 4 pot drills is about the same
    Neck angle is checked for a low 4°. I like the lower neck angle but need to make sure it's not too low (-;
  19. crazydave911
    East Tennessee
    Sweet! :D
  20. preeb
    Sonoran Desert
    Time to cut the binding channel. Not sure yet if I go with 0.100" single ply or 0.080/0.020/0.040 W/B/W multi ply... I'll decide later but for now I'll cut a 0.100" channel, have a look at it with a piece of single ply creme and see how I like it. If I'll go for the W/B/W I will cut it deeper.
    I set the channel jig for the right width and depth
    and run it manually the old school way trying to keep my fingers intact (-;
    Done
    and inspected. if I missed a point I just run it again real quick
    Here's the jig from a side view
    Checking the channel size again with the proper binding sample
    I think I'll go with the W/B/W to match the pickguard. The larger round tip at the cutaway will accept a wide binding easily and will look nicer TMHO.
