New Design Proto Build - Bone
Discussion in 'Tele Home Depot' started by preeb, Mar 28, 2013.
  1. Tezuka27
    Tezuka27 Tele-Holic
    539
    Apr 11, 2011
    Eastern Iowa
    Subscribed. Looking forward to this.
    john
  2. Nick JD
    I take the rout all the way up to the end of the tenon. If you place the neck pickup a slight way back from the end of the fretboard it's possible to wiggle a hex key in there ... if the nut is placed relative to the length of the average L-shaped hex key. But I find the neck pickup needs to be hard up against the fretboard end in most cases (22 fret, 25" scale) for tonal reasons - pickup placement is possibly more important than pickup construction where you have the choice of their positions.
    To adjust, I undo the 4 screws (one more than a truss rod cover) of the neck pickup, detune the strings and have at it. TBH, with a martin-style trussrod, glued correctly, I only have ever adjusted the rod once after all the wood settles in.
    Although I don't live in a wildly fluctuating humidity place.
  3. Ben the Tradie
    Ben the Tradie TDPRI Member
    8
    Mar 8, 2013
    Sunny Qld
    Reading stuff like this really gives me the itch... I cant wait for my 1st build... A pleasure to read, I hope you achieve what you set out for and more.
    Happy Passover
    Ben
  4. newtwanger
    newtwanger Blackguardian. Ad Free + Supporter
    Feb 11, 2007
    Quebec, Canada
    I do mine like that. You pop out the bridge pickup (at least that's what I do.)
    I was curious if he had a different approach like using a wagonwheel trussrod adjuster.
  5. blueruins
    blueruins TDPRI Member
    24
    Jan 23, 2010
    Honokaa, Hawaii
    Been eagerly awaiting this thread...looking great! I really like the revised cutaway, seems to give her more classic "automotive" style curves which is always a good thing in my book.
  6. preeb
    preeb Poster Extraordinaire Vendor Member
    Sep 10, 2008
    Sonoran Desert
    Top joint is dry after being over night under pressure.
    Maple top is flush routed with the Mahogany
    Template is attached
    and the control markers are drilled
    Like this
    Input jack location and drill angle are marked
    and drilled
    Back cavities pin router template is set
    I use a higher pin height for the main cavities
    and rout away
    The lower pin is used for the covers routs
    and routed
    done
    Next step is defining the dish carve shape for the duplicarver.
    I'm going after a fluent round dish with deep recurve towards the edges.
    I start the operation by routing the perimeter with a 3/4" round nose using the outline template as a guide for the pin router. From here on it's a slow hand operation that takes quite a few hours. When done I smooth everything and use my hand to feel for any high spots.
    I cover the HDF with thin CA glue and sand smooth. This will be the Master template and I might be able to change it a bit if needed. The working template will be copied on the duplicarver when I'm happy with the results.
  7. Ekphrastic
    Ekphrastic TDPRI Member
    43
    Feb 22, 2010
    Hattiesburg, MS
    Argh! I'd forgotten what it's like to wait for Preeb updates! I'm going to wear out my mouse, clicking the "Refresh" button...
  8. Bruiser74
    Bruiser74 NEW MEMBER!
    2
    Mar 28, 2013
    For sure! So many builds, so little time.
    This one is worth it for sure. Awesome stuff.
  9. preeb
    Sep 10, 2008
    Sonoran Desert
    Here's a few more photos after sanding and buffing the cured CA.
    The surface needs to be very hard and smooth for the duplicarver pilot to move fluently.
    Shabat Shalom!
  10. LC100
    LC100 Tele-Meister
    184
    Dec 8, 2010
    florida
    Neat insert trick, Gil. Curious - have you considered hidden chambers in the Paulownia? Not sure if it would be tonally shaped like you want that way but the weight reduction might be interesting.
  11. maumari
    maumari Tele-Meister
    445
    Mar 6, 2008
    Rome, Italy
    DJENIUS unchained!!!
    Unusual as usual...
    thank you Gil, I'll be staring :eek:
    Ciao
    Mauro
  12. dennyman
    dennyman Tele-Meister
    137
    Dec 22, 2006
    Hello Gil,
    I'm enjoying this thread and build.
    What do you think the guitar would sound like with just the hollowed mahogany body and the maple cap (without the Paulownia insert)?
    Thank you!
    denny
  13. preeb
    Sep 10, 2008
    Sonoran Desert
    I offer chambering on my LP builds and I guess I can do the same here if it ever goes into production in the future, but I have a strong feeling it doesn't need this. I tapped the body today against a premium LP body and it looks like I'm on the right direction to say the least (-; We'll have to wait until it's done and well tested by players and see what they have to say.
  14. preeb
    Sep 10, 2008
    Sonoran Desert
    It will be neck heavy and probably sound like a small sized ES-330 on steroids (-;
  15. teleben
    teleben TDPRI Member
    66
    Sep 12, 2003
    NYC
    Others have used balsa cores and inserts before (notably Gibson and Parker), but I doubt they used a freezer and a mallet!
  16. emoney
    emoney Tele-Afflicted
    Can't wait to "hear" this one, along with seeing the finished product!
  17. Fretnot
    Fretnot TDPRI Member
    41
    Jul 5, 2012
    PA
  18. Scooby Snax
    Scooby Snax Friend of Leo's Silver Supporter
    Apr 26, 2009
    Toronto
    It's all about precision, and violins! :D
  19. Palladio
    Palladio TDPRI Member
    6
    Jun 12, 2012
    New York City
    What a great thread, thanks for sharing this with us Gil! I've admired your guitars for years, and am really excited to see that you are going in this new direction.
    That piece of mahogany is as beautiful as I've ever seen on a guitar. I've got a few 50's Gibsons that have a similar pattern and have always wondered what type of cut produces that swirl in the middle. Can you describe more about what a "center slabbed" cut means? Maybe it's just a coincidence but my guitars that have this pattern are the most acoustically resonant solid bodied mahogany guitars that I own.
    Also, do you have an idea yet of what this guitar will weigh?
  20. Barncaster
    Hey Gil,
    As far as being neck heavy, have you considered some of the light weight tuner offerings such as the Gotohs? Also, a steel Callaham bridge in conjunction with light tuners may help cure your imbalance. ;-)
    Rob
