New Build: 5F11 Vibrolux
Discussion in 'Amp Central Station' started by Bob Arbogast, May 9, 2019.
  1. Bob Arbogast
    Bob Arbogast Tele-Afflicted
    Lowell, Michigan USA
    I just finished this amp the other day. I used a Mojotone kit and made just a few substitutions. I also added a couple of components to the bias circuit to reset the bias adjustment range and to quiet the tremolo circuit.
    I intend to use this amp for gigs at very small venues. It sounds great, though I will soon swap in a Copperhead speaker. I'm looking for more low-mids and less highs.
    I saw the color scheme on the Gear Page (user: ripple). It's VOX fawn tolex and Bluesbreaker grill cloth.
  2. Blue Monster 65
    Blue Monster 65 TDPRI Member
    South Central Michigan
    Nice work! I’d like to hear it.
  3. theprofessor
    theprofessor Friend of Leo's
    Chattanooga, TN
    Um... WOW! That's off the hook! Congratulations on a very fine new build. If it sounds half as good as it looks, you're in business!
    King Fan likes this.
  4. Mark the Moose
    Mark the Moose Tele-Meister
    Erie, CO
    I dig the fawn tolex.
  5. dannyh
    dannyh Tele-Afflicted
    North Texas
    Looks great, bet it sounds great too..,congrats!
  6. AlbertaGriff
    AlbertaGriff Tele-Holic
    Awesome, looks fantastic inside and out. I'd like to do a mojotone 5f11 kit as well some day.
  7. dragonfly66
    dragonfly66 Friend of Leo's Silver Supporter
    Nice, nice, nice!!
  8. gridlock
    gridlock Friend of Leo's
    Tampa, Fl
    Excellent job and a beautiful amp.
    Congrats.
  9. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    Beautiful! I built one of those a while ago, and I love it.
    Can you elaborate a bit on what you altered in the bias circuit?
  10. Uncle Daddy
    Uncle Daddy Tele-Holic
    Maldon, England
    Nicely done. Do you get much trem whump creeping through?
  11. Bob Arbogast
    Thanks, all!
    The way Mojo lays out the bias circuit, it has a very limited adjustment range. In fact with the stock values, the 6V6s were running too hot. So I experimented with the value of the first resistor in the bias string. I added a 33k to the stock 10k and that put the bias adjustment in the right range.
    Yes, there is some of that. It's not too noticeable when playing. I added a second 25uF/50V cap in parallel with the bias cap. It helped. Right now the workaround is to use the footswitch to turn off the trem oscillator.
    jhundt likes this.
  12. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    Nice!
  13. charlie chitlin
    Spring City, Pa
    Very sanitary.
  14. jhundt
    Netherlands
    thanks for the info. One more question, if I may: What amount of bias do you use?
  15. kookaburra
    kookaburra Tele-Afflicted
    Phoenix, AZ, USA
    Hi Bob, why a Copperhead instead of the Ragin' Cajun? I'm only familiar with the speakers from discussions regarding Allen amps.
  16. King Fan
    Salt Lake City
    Agree, a beautiful build. Re trem thump, assuming the 5F11 trem array is quite close the 6G2's, I recall where our friend @theprofessor took a page from Jim Nickelson's LilDawg book using 47pf silver mica caps. I was so impressed I stole and marked up his photo:
    theprofessor likes this.
  17. schmee
    schmee Poster Extraordinaire
    Love the look of that amp.
  18. Bob Arbogast
    Here are some numbers:
    Line voltage: 122Vac
    Plate voltage: 405Vdc
    Screen voltage: 408Vdc
    Cathode current: 21mA
    Screen current: ~1mA
    Bias voltage: -37Vdc
    Frequency response charts and my memory tell me that the Copperhead is not as bright as the RCajun. That's a key goal.
    Thanks for that. The trem thump is not so bad. What I do have is some low-level hum.
    I'm confident that the first part of the hum is magnetically coupled from the PT to the OT. The hum comes through the speaker even with no tubes installed. (I had the same issue years ago with RI JTM45 heads.)
    The second part of the hum seems to come from the bias or trem circuits. The hum decreases as the I turn up the Depth control.
    It's all quite minor. Not something you hear when you're playing. And certainly nothing you would hear in a live setting, even when you stop playing!
    kingofdogs1950 and kookaburra like this.
  19. Mike Eskimo
    Mike Eskimo Doctor of Teleocity Ad Free Member
    Detroit
    Celestion vintage 10 (if you need a 10)
    Great speaker that I bet would work great in there.
    Nice choice on the tolex and grill
  20. kingofdogs1950
    kingofdogs1950 Tele-Holic
    Franklin, Texas
    Nice looking amp.
    I have the same 5f11 built by Mojotone. Mine is unmodified.
    Mark
