Need some help, 5E3 build
Discussion in 'Shock Brother's DIY Amps' started by Paul G., Apr 25, 2019.
  1. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    Finished up the build, go to test voltages, all pretty good -- a little high, but probably my wall voltage --except for pin 2 on the 12AX7. Should be 160, getting 281. There is a 100k Ohm resistor supposed to be dropping from 252 (I get 285) to 160 Vdc, but it just drops from 285 to 281.
    With the pin end disconnected, I get the same drop over the resistor, so I say -- aha! I'm not drawing any current. Checked the socket, and swapped out the tube - no difference. Tried a different 100k Ohm resistor - no difference. Put in a 1Meg resistor for S&G, voltage barely dropped.
    The Pin 6 with a 56k dropping resistor from the same spot works fine dropping to 210Vdc (s.b 198, pretty good). Likewise the voltages for the 12AY7, all dropping from the same place (preamp filter cap).
    Amp make a light hum, and tapping on 2 & 6 on the 12AX7 makes healthy pops, but not getting much out of 12AY7. Plugged in, signal is very low, rattley and distorted.
    Not my first amp, but this is beyond me. Triple checked circuit, joints all good. Freaking out.
    Voltages (Voltage in parentheses are target):
    B+ at pin 8 rectifier - 383 (386)
    V4 (6v6): Pin 4 - 340 (342): Pin 8 - 23 (22)
    V3 (6v6): Pin 4 - 348 (342): Pin 8 - 22 (22)
    V2 (12AX7) Pin 1 - 281 (160): Pin 3 - 5.2 (1.4): Pin 6 - 210 (198): Pin 7 - 19 (19): Pin 8 - 51 (53)
    V1 (12AY7) Pin 1 - 132 (125): Pin 6 - 135 (125): Pin 8 - 2.2 (1.9)
    It's just weird to me that the same voltage from the filter cap drops nice-nice everywhere but there.
    Any ideas?
  2. muswell_hillbilly
    muswell_hillbilly Tele-Meister
    Greenfield, WI
    Do you have another 12AX7 you can try in that position?
    Edit: Sorry - I see now that you already said you swapped out the tube :(
  3. Snfoilhat
    Snfoilhat Tele-Holic
    Oakland, CA
    V2 cathode resistor too high a value, biases the triode too cold. Very little current flows, very little voltage drop across the plate load resistor. The resistor that is connected to pin 3. See how high the voltage is? Without more info, that's my guess.
    King Fan, Paul-T, D'tar and 2 others like this.
  4. corliss1
    Lansing, MI
    What @Snfoilhat said - measure resistance from pin 3 to ground. You could have accidentally put the wrong resistor there - don't worry, we've all done it.
  5. Paul G.
    Rhode Island
    That was what I felt, not enough current going through,due to low bias so not enough current to drop voltage. I had some wine with supper, so no more work tonight, I'll give it a go in the morning.
  6. Paul G.
    Rhode Island
    That was it. When I bolted the board into the chassis I must have nudged the 1.5K bias resistor -- even though it looked like it was still making contact, it wasn't. Fixed that, and everything worked perfectly. Can't crank it at 11:30, but all the controls work, got good volume, nice and sweet.
    Thanks for helping steer me in the right direction.
