Need help with Seymour Duncan PU assembly/repair.
Discussion in 'Just Pickups' started by Dfree, Apr 15, 2019.
  1. Dfree
    Dfree TDPRI Member
    South Lyon MI
    Well, after a year plus of gathering parts and info for my first build, I get everything around for a first fit up, and find that my Seymour Duncan PU is not assembled correctly. It had been about 14 months since I purchased it and Stratosphere said they couldn't do anything to help. The problem is that the cover isn't fully seated or seated crooked and the tabs aren't folded over. Cover is solid where its at and can't be pushed down to fasten the tabs. Is there any advice or instruction you guys could offer before I explore prying this thing apart?
  2. Crafty Fox
    Crafty Fox Tele-Afflicted
    Perth Australia
    Would it be worth emailing Seymour Duncan? The Stratosphere are SD retailers aren't they? So this would be a new pickup, not one of their cannibalised ones? SD may be more understanding and helpful.
    Like you, I tend to gather all the components prior to starting a build. I had a similar problem with another Ebay trader a few years ago with a dead Fender Tele pickup. I didn't any satisfaction from them either so have never purchased from them since.
    I hope you can get it sorted ok.
  3. Dfree
    Dfree TDPRI Member
    South Lyon MI
    I just today did contact Seymour Duncan but being over a year I'm not holding my breath. I did inspect the clear plastic box for damage when it arrived, but in the interest of not losing small parts or fingering up the shiny finish I left it sealed up.
  4. Mincer
    Mincer Tele-Meister
    Tampa Bay Area
    I am sure they will make it right. If you don't hear from SD in a few days, just call.
  5. Antigua Tele
    Antigua Tele Friend of Leo's
    west coast
    Supposing Seymour Duncan doesn't get back to you, try carefully removing the cover, if you have to pry at it, maybe use a soft edged tool that wont rip the coil if you happen to nick it. Once off, see if there is a build up of wax on the bobbin or in the cover that it preventing it was seating all the way. If not, it must be that the bobbin is a little too big, or the cover to small. Judging from the picture, the cover seems to have a strange bell-like shape to it, making me think it's too narrow towards the top of the cover. You could but a new cover and try slipping it over the pickup.
  6. Wally
    The Quarteounder is a tall pickup, and the cover does not come all,of the way down to the bobbin. You can see this in the picture.
    https://www.seymourduncan.com/pickup/quarter-pound-tele-neck
    It does appear that the cover on your pickup was not installed properly, though. Note that those cover tabs are not visible in the sales literature pictures. Ime, SD will probably be understanding if you can send them pics that show an unused pickup.
    Out of curiosity, what does the cover look like on the bridge side of the pickup?
    Tuxedo Poly and telemnemonics like this.
  7. telemnemonics
    There are three tabs and you only picture two of them.
    Is the third tab soldered to the bottom flatwork for ground?
    If the cover is both soldered and secure, maybe it is not in need of fixing.
    Many pickups are held together with wax and a blob of solder.
    Not sure exactly what's up here though.
    Wally likes this.
  8. Antigua Tele
    west coast
    I didn't notice that was a QP neck pickup. Mine is the same way, the cover is even a little crooked like OP's. It worked fine while it was installed. It's a very dark pickup, the cover is made of brass.
    Dfree and Wally like this.
  9. Wally
    I figured there was a situation like that. DarK...any pickup that is wound to a large resistance rolls some high end off.
    Keeping the pickup farther from the strings will yield more articulation, ime, in such a pickup on the neck.
  10. Dfree
    Dfree TDPRI Member
    South Lyon MI
    Yes the third tab protrudes through the base and is soldered. That's mostly what I don't want to mess with in removing the cover.
  11. Dfree
    Dfree TDPRI Member
    South Lyon MI
    Hmmm, if its likely to work just fine like it is, I might just install it that way, but"Jeez o Pete's" all the neurotic attention to details that goes into this project! Its gonna drive me nuts every time I look at it!
  12. Dfree
    Dfree TDPRI Member
    South Lyon MI
    The bridge PU doesn't use a cover. Pole faces are exposed.
  13. Dfree
    Dfree TDPRI Member
    South Lyon MI
    This pic better shows what I'm trying to fix.
  14. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    I don't generally have bad things to say about Duncan, but this wouldn't be the first time I have seen a shoddily constructed Duncan pickup. I have had even worse that that from MJ herself in the Custom Shop (they fixed it, of course, but jeez, she's one of the only pickup winders in the world that is widely known by name and viewed as almost mythical).
    It looks like someone just pushed down the other side too far before soldering. It's likely to work fine as is, but I myself would try to fix it, just because.
    Have you tried judicious use of a vise with cork cauls, or have you just tried leveling it by hand?
    I'd probably put the thing in my vise and carefully adjust it while applying heat from a heat gun. Then let it fully cool to room temperature (I'd play it safe and just leave the room for at least half an hour) before releasing the vise.
    If it is indeed a 1/4 Lb., the tabs don't get folded under.
    We need to see the other side of the pickup, to see how deeply the factory set the tab on that side.
  15. Wally
    Then what does Seymour Duncan and company say???? There is a full refund on any SD pickup within some time frame.
    A bit of heat might allow one to straighten that cover...but those tabs may be in the way.
    However, I just noticed something. Looking at the Quarterpounder in the link I provided above has a different cover. I might guess that they did not have a tall, gold cover an duse a cover for a regular height Tele neck pick...and that shorter type of cover does fit the bill????
  16. Mincer
    Mincer Tele-Meister
    Tampa Bay Area
  17. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    That is badly assembled. It should look like this.
    Dfree likes this.
  18. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Put a wedge under the pickup when you mount it to level the appearance surface at the angle you wish to see.
    Dfree likes this.
  19. Rob DiStefano
    Rob DiStefano Poster Extraordinaire Vendor Member
    NJ via TX
    there is absolutely NO need to bend the cover tabs as long as the bobbin and cover were properly potted.
    better yet if the cover was grounded with a separate wire off the single tab that fits into the pickup's base wiring hole. all tele covered neck pickups should come that way.
    Bruxist likes this.
  20. Antigua Tele
    west coast
    I don't think there is anything wrong with their making the pickup this way. The QP Tele neck has probably been made this way for years. If there is a problem, they would have done something different.
    That being said, Fender has a tall bobbin for the Twisted Tele, and IIRC they have a specially made tall cover for it. I think it would have been preferable for SD to do have done that as well.
