Need build ideas / OD
Discussion in 'Burnt Fingers DIY Effects' started by tacomamc, May 19, 2017.
  1. tacomamc
    tacomamc Tele-Afflicted
    Jul 2, 2009
    Northeast Pa
    I've built a DOD OD 250, the MXR distortion Plus, Devi Ever Sodameiser, and a Triangle Muff. The Muff was on a purchased PCB, the rest are veroboard. I'd like to build another OD, maybe something to replace my tube screamer. What's a good choice here? Could the OD 250/ Distortion + be modified for a mid boost, or is there another circuit I should be looking at? I'd prefer to build something with the components I've got, but certainly can make an order if I need a particular chip, or different value caps.
  2. luckett
    luckett Friend of Leo's
    Jun 14, 2011
    Take a look at how the high pass/low pass filtering and gain are done in a TS and Rat and try some similar things in the OD250.
  3. tubejockey
    tubejockey Tele-Meister
    256
    Nov 25, 2015
    the bozone
    For lower gain, try a Barber LTD Silver. For higher gain, try a Fulltone Plimsoul. Both have lovely mids.
  4. JeffBlue
    JeffBlue Tele-Holic
    970
    Oct 24, 2012
    Southern California
    If I were to build from scratch, I believe I'd want a 3 channel low volt tube pedal that afforded me 3 distinct and accurate tones.......1. Blackface clean 2. Tweed 3. high gain Marshall.
  5. tacomamc
    Jul 2, 2009
    Northeast Pa
    I listened to some plimsoul demos..... that's the one. Thanks guys, I'll be building that one. I have most of what I need.
