Asher Guitars WD Music Products Amplified Parts Mod Kits DIY Nordstarnd Pickups
Need a pedal for the Twin Reverb sound!
Discussion in 'The Stomp Box' started by sjturbo, Sep 7, 2017.
  1. sjturbo
    sjturbo Tele-Meister
    Dec 3, 2008
    Tucson, Az
    (Sorry I needed to edit this thread because I was not clear). I am actually looking for a pedal that sound like a Twin Reverb. Any suggestions? Playing through a MMRD50. Can the Fender Deluxe Reverb pedal actually sound like a Twin?
  2. bparnell57
    bparnell57 Poster Extraordinaire
    Feb 10, 2014
    Philadelphia, PA
    Boss makes a Fender Deluxe Reverb pedal that works great for the entire tone of the amp. Not sure if it has trem.
    A Strymon Flint would give you any type of fender trem you would want.
  3. bakersfield2014
    bakersfield2014 Tele-Meister
    Nov 1, 2014
    Helena Montana
  4. tatittle
    tatittle Tele-Meister
    Jun 27, 2010
    North NJ
    If you mean pedal to get you the CLEAN tone of a twin I don't know if that is really possible; other than a basic EQ pedal set-up properly. I think Twins BFace have lots of highs and lows and less mids EQ wise. Much easier to start with a basic clean tone from the amp and add pedals for dirtier/effects etc.
    An American voiced speaker would also help but you couldn't turn it off with your foot (unless you used a cab switcher) I see you have a MusicMan so you are close already...what speaker is in it? Speaker swaps make a huge difference.
  5. Tootone
    Tootone Tele-Meister
    Sep 4, 2015
    Perth WA
    If you could find such a pedal, wouldn't it just ultimately sound like the MMRD50?
    Edit: it just occurred to me you might be looking for a "reverb pedal" that sounds like a Twin's reverb?
    MMRD50... already has a good clean tone? I am confused.
  6. wrathfuldeity
    wrathfuldeity Tele-Holic
    Apr 25, 2011
    Turdcaster, WA
    Award/Morley JD 10 (or 20) Session Master ... and then a reverb pedal...which I use a tech21 rvb...presuming you are wanting clean
    but idk anything about your amp
  7. Bones
    Bones Doctor of Teleocity Ad Free Member
    Dec 31, 2005
    Luddite Island, NY
    I have have the Boss Fender Deluxe FDR-1 pedal and love it. It has Reverb and Vibrato. Does it nail the Fender Twin Reverb sound? I don't know, never had them both in the same room to try, but it's a very good sounding pedal, one of my favorites, I use it all the time. Good luck finding one. They discontinued them years ago
  8. jklotz
    jklotz Tele-Afflicted
    Jan 10, 2012
    Atlanta, GA
    Sonic Blue Twanger
  9. SolidSteak
    SolidSteak Tele-Afflicted
    Apr 27, 2016
    This guy just posted a question about his Shift Line Twin MKII, which from the looks of it is supposed to sound like a Twin and act like a DI. Has a cab simulator you can switch on or off. No reverb, but has an effects loop:
  10. Ira7
    Ira7 Poster Extraordinaire
    Jan 8, 2008
    Coral Springs, FL
    Keep torturing me with that FRV-1, why don't you?
  11. FerruleCat
    FerruleCat Tele-Meister Gold Supporter
    May 2, 2017
    Tulsa, OK
    The AMT Electronics F1 is supposed to emulate the Twin, but I don't have any experience with it.
    With the right settings, a Joyo American Sound can blackface another amp to a degree.
    Of course your amp will have the final say on your tone, regardless of what you run into it.
  12. brbadg
    brbadg Tele-Afflicted
    Mar 11, 2008
  13. sjturbo
    Dec 3, 2008
    Tucson, Az
    Thanks for the replies! The MM has an original EVM12L. I'll look into the Fender pedal as well as the AMT and Shift Line. I would likely need to set the MM side by with the Twin to tweak the tone. The MM does not have a Mid control but that may not factor in so much.
  14. Bones
    Dec 31, 2005
    Luddite Island, NY
    I can send you high def photos of the box and paperwork if you want :)
  15. Ed Boyd
    Ed Boyd Tele-Afflicted
    Mar 25, 2009
    No. The sound is the high headroom amp, preamp, open back twin 12s, verb, ect...
    Electrode makes a preamp that emulates a blackface twin. It's expensive but its a small company and quality parts needed for tube electronics like transformers are expensive. Still won't sound like a Twin.
  16. JayDee
    JayDee Tele-Meister
    Apr 7, 2009
    A Tech 21 Blonde ( I'd get the 2nd version) or a Wampler Black '65 should help get you in the ballpark. You'll have to search for a used Wampler because that one is out of production.
    JustABluesGuy likes this.
  17. JD0x0
    JD0x0 Poster Extraordinaire
    Feb 22, 2009
    New York
    What do you want from the pedal? IMO, A twin reverb has...
    -Loud cleans
    They're not really known for their overdriven tone, so I dont see much use in getting a 'dirt' pedal going for a twin tone.
    Twins have a large mid 'scoop', along with most blackface fenders. This is part of the sound. An EQ pedal might help you here. You can also increase 'treble' and 'bass' at the tonestack of the amp to create a larger mid 'scoop'
    Iago likes this.
  18. JustABluesGuy
    JustABluesGuy Tele-Afflicted
    Sep 2, 2016
    Houston, TX
    I'm still unclear what you are looking for, but if you are looking for an "amp in box" type foundation pedal that will make your amp sound like a twin, you will probably want to look at the the Tech 21 Blonde or it's inexpensive clone, the Joyo American Sound.
  19. NiceTele
    NiceTele Tele-Afflicted
    Dec 20, 2012
    Very hard to simulate a Twin Reverb- two 12" speakers with a big clear tone. I have a Zoom MG-50 multi FX stomp that does a Twin Reverb amp sim, and I sometimes go direct into a mixer with no amp and it sounds pretty good, but nothing replicates the tone you get plugging your guitar into a Twin Reverb and playing.
  20. Sparky2
    Sparky2 Tele-Holic
    Apr 15, 2017
    Harvest, Alabama
    I used to own an early 1970's Fender Twin, and foolishly sold it when I joined the Army in late 1977.
    The fellow I sold it to owned it for many years, but later blew it up somehow, during his most out-of-control substance abuse days, (so he reports) and it went off to the scrap-heap.
    I have learned a lot over the years, regarding both the longing for that old amp, the regret, and everything I have come to know from the dozens of guitars and dozens of amps I have owned ever since I let that Twin go.
    The reality is that most of the tone that you seek is in the hands of the player.
    If all the videos that have been posted to date (in this thread alone, ostensibly enticing you to buy this or that really nice effects pedal) have taught us anything, it's that the tone you seek is in the hands of the player.
    Joe Walsh recorded Funk 49 on a Fender Telecaster, thru a Fender Champ amplifier featuring an 8-inch speaker.
    Billy Gibbons could pick up a Walmart guitar made by First Act, plug it into a cheap, used, solid-state (non-tube) amp, and he would still sound like Billy Gibbons.
    My advice is to get out there and explore everything that you can get your hands on.
    Play it all, and play thru it all.
    But first and foremost?
    Work on your guitar playing.
    Work on your chops and your feel.
    Okay, I'm gonna shut up now.
