Neck pocket gap(not on sides!)
Discussion in 'Tele-Technical' started by theDST, Dec 8, 2018.
  1. The Ballzz
    The Ballzz Tele-Afflicted
    Las Vegas, NV
    That pic was for an example. StewMac has them available in multiple angles, can be stacked and/or reversed, depending which end of the pocket needs shimming. I did not intend to open the "can of worms" discussion over the wisdom or not of shimming, simply pointing out the best method! A skilled woodworker could make their own, but I suspect their time is worth more than what StewMac charges!
    https://www.stewmac.com/Materials_a...itar_Necks/StewMac_Neck_Shims_for_Guitar.html
    And here's a dramatization of what CAN happen (and I've seen it) with a shim as in the OP's @theDST guitar!
    Just Sayin'
    Gene
    jfgesquire likes this.
  2. jfgesquire
    jfgesquire Tele-Meister
    Lake View
    I was giving an example of why I'm using a shim, was just making discussion, no problems with your post. I agree with you.
    Mine is an unusual situation where both the neck and body are a little out of spec. On any other body the neck would be fine and with any other neck the body would be fine.
    It's not buzzing like a sitar and the saddles are not flat on the bridge, but I would prefer a little more down-force . . . It's a vintage 6 saddle.
    On my other Tele, the tops of the saddles are too far above the bridge for my tastes.. Hmm, maybe I should switch the necks?
    Sent from my LG-H830 using Tapatalk
  3. TimTam
    TimTam Tele-Holic
    Melbourne
    In Excel ....
    Shim degrees in A1
    Distance from front of neck pocket to saddles in A2
    Formula for bridge saddle height change in A3 ...
    =TAN(RADIANS(A1))*A2
    eg
    0.5 deg shim
    240mm from front of pocket to saddles
    Height change = 2.1mm (0.08")
    There are probably a few assumptions here (eg that the string line changes by the same angle as the undersurface of the neck heel in the pocket), so regard the answer as approximate.
