Neck pickup swap to p 90?
Discussion in 'Telecaster Discussion Forum' started by tweed58blues, Nov 5, 2017.
  1. tweed58blues
    tweed58blues TDPRI Member
    16
    Sep 29, 2017
    lake forest IL
    I was thinking about swapping out the neck pickup on my 58 AVRI to a p 90, but since I’d have to get it routed, I’m on the fence. I’ve always liked the look of a p 90 on a tele, I just want multiple opinions
  2. LP26
    LP26 Tele-Meister Ad Free Member
    269
    Nov 5, 2017
    Earth (Part-Time)
    You might consider TV Jones Starwood Tele pickups.
    No, they are not P90's, but they do produce a good deal of that P90 thickness, growl and grit.
    They are drop in replacements, so no routing retired.
    I put them in my 2017 Tele Pro along with an Emerson 4-way switch (you have to lift the ground on the neck pickup for the 4-way to work) and am getting fantastic tone in all positions.
    cabra velha, Piggy Stu and Tootle like this.
  3. AxemanVR
    AxemanVR Tele-Afflicted
    Dec 27, 2011
    Minnesota USA
    P-90 style pickups can be much hotter and fatter sounding than a typical Tele neck pickup, so it may not be a good match with a typical Tele bridge pickup - especially one with a "vintage" output.
    Then again, not all P-90s are the same, unfortunately the only way to find out is to try them.
    Anyway, adding a P-90 pickup to a Tele isn't something I'd personally be interested in doing (since I already own a couple P-90 guitars), but if I were, I would only do it if I had a spare project guitar but not on something like an AVRI, but that's just me...
    Piggy Stu likes this.
  4. jvin248
    jvin248 Poster Extraordinaire
    Apr 18, 2014
    Near Detroit, MI
    I have a PRS SE Single-cut with dual P90s and I use both of the pickups. If I only had a neck pickup it would be a lot less fun.
    I do have a Strat-like-object that I modded for dual P90s (it's my $15 test mule) and that convinced me to watch for the PRS.
    If you route the body for the P90 and decide later to go with something else you are only a pickguard change away. Maybe route it for more adventure, I have a Jazzmaster pickup in the neck of my test mule right now ;)
  5. tweed58blues
    16
    Sep 29, 2017
    lake forest IL
    Yea, I know what you mean, it’s a pretty big decision, I was also considering a Humbucker in the neck, really the only thing I’ve been heasitating towards is having the body routed- I know a really good shop near me that would do an amazing job with it- I just wanted some feedback on p 90s as an option, because I played a tele from 68’ with a p 90 in the neck and it sounded amazing-
  6. dmoss74
    dmoss74 Tele-Holic
    790
    Mar 28, 2010
    usa
    if you're going to keep a standard tele bridge pickup, then i'd talk to a reputable pickup winder about getting an underwound p 90. i had david plummer from zhangbucker pickups wind me a nice p 90 to go with a tele. i think (i sold the guitar a while ago) that it read in the 4.5 to 5 range.
    what i'd also suggest is getting a dual concentric pot, so you can have two separate pot values for the pickups. but a p90 in a tele neck slot sounds very nice indeed.
  7. Fiesta Red
    Fiesta Red Tele-Afflicted
    Nov 15, 2010
    Piggy Stu and Crobbins like this.
  8. dogmeat
    dogmeat Tele-Meister
    401
    Oct 12, 2017
    Alaska
    I've been foolin' with the P-Rails lately.... single coil, P90, Bucker all in one. havn't put one in a Tele, but lots of good sounds
  9. absurdocaster
    absurdocaster Tele-Meister
    206
    Oct 10, 2013
    Calgary, Canada
    Porter Pickups make a p90 flavoured tele pick up set that are made in standard tele shapes and size. Check out there website as they might check your boxes.
  10. sergiomajluf
    sergiomajluf Tele-Meister
    371
    Sep 26, 2015
    Santiago, Chile
    I have only one tele (a thinline I built myself if I may add) and it’s my only guitar with a P90. A Mighty Mite. I’m completely in love with it
    Here’s the first clip I recorded with it
    link:
    Science then I changed the neck to a Baritone and the p90 loves the extra low end
  11. littlebadboy
    littlebadboy Tele-Holic
    909
    Jun 25, 2016
    Midwest, USA
    I tried GFS overwound single coils. It sounds amazing! Fat and loud!
  12. etype
    etype Tele-Holic
    890
    Sep 23, 2014
    Dallas
    I have a set of these Porter 9Ts. Worth checking out.
  13. RnBtele
    RnBtele TDPRI Member
    41
    Jun 17, 2017
    Starkville, Mississippi
    I have a p90 in my classic vibe tele. Its a Seymour Duncan vintage p90 neck pickup. At first I had a few problems getting it to balance well with the stock bridge pickup. However I was able to solve that problem by swapping out the a5 magnets for a3's and lowering the pickup flush with the pickguard. For me the a5's were too boomy for the neck. The a3's really sweetened it up... Oh since I have the vintage blonde model, my stock bridge pickup is supposed to be wound a little hotter than vintage. I'd compare its output to being a smidgen higher than the nocaster bridge pickup in my other tele since it can make my practice amp distort a little easier.... An underwound p90 would probably be the safest bet though since I don't know how much output the stock 58 bridge pickup has.
  14. trev333
    trev333 Doctor of Teleocity Ad Free Member
    P90's usually work better in pairs..with 500K pots.... IMHO... :)
  15. Clifton C
    Clifton C Tele-Holic
    861
    Aug 26, 2010
    Houston
    I think you mean "rout."
  16. AxemanVR
    Dec 27, 2011
    Minnesota USA
    Just a cautionary note:
    There have been countless cases where people have regretted hacking up their beloved instruments (Eddie Van Halen and myself included), so one should give it much serious consideration before firing up that power tool and removing chunks of wood, since you can't go back once the deed is done.
    Don't be one of "those" guys...
  17. MMARSH
    MMARSH Tele-Meister
    385
    Jun 21, 2015
    CA
    Yes, these are great pickups! I have a MIM Strat with these, great guitar, great pups. I have mine wired to do Humbucker/Parallel (my favorite)/rail/P90. Sweet tones!
  18. SPUDCASTER
    SPUDCASTER Poster Extraordinaire Platinum Supporter
  19. The Blood
    The Blood Tele-Meister
    166
    Dec 31, 2014
    Healdsburg, CA
    Changing pick ups is one thing but when it comes to taking chunks of wood out of your guitar it seems to make more sense to me to explore what’s available cheaply in the used market in your neighborhood that might already have room for p90’s.
    I love my my neck P90 for playing around the house. it’s mellow but has enough drive to make the pedals work well. I just put a quarter pounder in the bridge position as recommended by Seymour Duncan and it’s almost as strong as the tonerider P90 I’m using, but not quite though.
  20. Papa Joe
    Papa Joe Friend of Leo's Silver Supporter
    Jun 30, 2007
    Swanton Ohio
    The Rose Freedom T90 will drop right in with zero mods to the body or pick guard..
    I have a set of Freedoms T 90s. P90 sound in a Tele..
