Join TDPRI Today
Nashville Tele Wiring
Discussion in 'Tele-Technical' started by chrisdk, Mar 3, 2008.
  1. chrisdk
    chrisdk TDPRI Member
    47
    Feb 13, 2008
    Denmark
    Hello everyone!
    Is there an "easy" way to wire the Nashville Tele, so that I keep the original five positions, while also adding the bridge+neck pickups in series and in parallel??
    By the way I don't REALLY need the middle position alone if that makes it easier.
    Thanks...
    - Christoffer
  2. newey
    newey TDPRI Member
    96
    Feb 19, 2008
    Nearby Akron, OH
    Chris-
    Well, "easy" is a loaded term here. For starters, I don't know what kind of a switch you have on that from the factory, but you'll need more than the std 5-way "strat-style" switch to do series/parallel combos. You need a switch like the Fender "superswitch" for that.
    Or, you can use a push/pull pot to do this as well.
  3. chrisdk
    47
    Feb 13, 2008
    Denmark
    Well yes it is a standard 5-way Fender Switch, with the standard wiring.
    Does anyone have a suitable wiring diagram, perhaps for the suggested Superswitch or P/P Pot?
  5. robt57
    robt57 Telefied
    Feb 29, 2004
    Portland, OR
    Buy the Super Start switch from Deaf Eddie's site and I'll bet ya a bucket of old strings he will have the wiring scheme you want, or will figure it out in his head in 10 seconds. ;)
  6. Deaf Eddie
    Deaf Eddie Friend of Leo's
    Sunny San Diego, CA
    AFAIK, IF you want to KEEP the stock five combos, you will have to add TWO push/pulls or toggles.
    One switch can easily be wired to give you the bridge (or neck) pup ON all the time, so you can play the bridge+neck or all-three-pups combos.
    A second switch can be wired to give you the bridge and neck in series, but it DOES get a little messy.
    A Superswitch can be wired to get the two "new" combos you want, but it wouldn't ADD them to the stock five - you'd still only get FIVE combos - you'd have to pick your favorite five. I can draw that up for you, once you pick 'em.
    SO, there's no "easy" way to do it - you just have to grit yer teeth and do it!
    BTW, I don't sell the Superswitch on my site, only my rotary mods for Strats (the Chromacaster and FAT-O-Casters). But, thanks for the plug!
  7. robt57
    robt57 Telefied
    Feb 29, 2004
    Portland, OR
    I didn't even know you were here. ;) I got my 4 way in my Tele a while back, courtesy of ya'll. [at least I thought I had.]
    I should show you the SyKoStrat I did on my Shecter VS Strat one day.
    It is my R&D platform git. ;) 6 position Rotary on one HB that does coil splits and phase reversals, a Mini switch on the other HB for a split, and the center SC I left alone ala stock Strat [in switch position and lineage] Although I string wrapped the coil, put copper tape over the string/coil and grounded it. ;)
    I had a dream one night afer spending a few hours looking at your schems on the site, and woke up with the soldering iron in my hand over the VS on the bench. [I think I hd swallowed my pillow too] :twisted:
  8. chrisdk
    47
    Feb 13, 2008
    Denmark
    Okay thank you...
    Sounds a bit difficult to me :)
    What if I give up on the middle pickup alone setting - would that make it a smaller operation? I would like to keep it down to resoldering the switch and adding 1 P/P Pot as maximum if possible...
  9. Deaf Eddie
    Sunny San Diego, CA
    Because of the switch that Fender uses, you can NOT just "give up" one combo - rewiring the switch affects the adjacent tones as well (except on the B-Bender models, which use the single-wafer Superswitch).
    If you want to try something SIMPLE that will get you part-way there, just swap the mid and neck pup leads on the 5-way. That will give you these tones:
    1 - bridge
    2 - bridge+neck
    3 - neck
    4 - neck+mid
    5 - mid
    ... AND, let us know how you like that.
  10. chrisdk
    47
    Feb 13, 2008
    Denmark
    Hi Deaf-Eddie!
    You are right, that would get me part-way there. But one of my favorite tones is the bridge+mid for the Strat-like tone.
    I guess another option would be to wire it with bridge+neck (in parallel) instead of the mid?
    Then I would of cause be missing the middle alone position, and bridge+neck in series which I do like for a fatter tone...
    Could another option be to install a 4-way switch, and wire the middle pickup to a P/P Pot, which could be activated in the bridge only and neck only position, for those in between sounds??
    Sorry if I am being difficult :)
  11. Deaf Eddie
    Sunny San Diego, CA
    Here you go...
    That can NOT be done with the stock Strat-style 5-way, or we would have suggested it.
    Almost... That has been discussed here before. You'd just use the p/p to add the mid pup to whatever the 4-way had selected. That scheme gives you all the stock Nashville tones but one (you lose the mid-pup-only), the two new tones you've asked for, PLUS two more combos (all three parallel, mid parallel to the neck-series-bridge.
    With the p/p down, the 4-way gives you the normal (two-pup) 4-way combos; pull the p/p and it adds the middle pup to whatever you've got on the 4-way.
    Don't forget to un-ground/re-ground the neck pup's cover...
  12. rlivin
    rlivin TDPRI Member
    8
    Sep 27, 2007
    North Alabama
    I used a push pull without the superswitch and it works great. Pull up to get the neck/bridge combo.
  13. blacklinefish
    blacklinefish Tele-Afflicted
    Jun 19, 2006
    Northwest Missouri
    I have a toggle switch, but only for a series/parallel option. (It almost doubles the volume, like a humbucker, by grounding the bridge pickup through the neck pickup.) I used one-half of the Fender superswitch.
    Here is a wiring diagram: PDF
    Cut switch in half:
    --gh
  14. newey
    newey TDPRI Member
    96
    Feb 19, 2008
    Nearby Akron, OH
    Chris-
    I think you mean Bridge+mid, since you already have bridge+neck in position 2 on the switch?:confused:
    As a matter of convention, BTW, parallel combos should use the "+" sign, series should use the "*", since electrically that's what's happening. Thus "Neck+mid" implies a parallel connection; "neck*mid" means series.
  15. chrisdk
    47
    Feb 13, 2008
    Denmark
    No. Right now I have:
    1 - bridge
    2 - bridge+mid
    3 - mid
    4 - mid+neck
    5 - neck
    Thanks for all the other suggestions by the way.
  16. chrisdk
    47
    Feb 13, 2008
    Denmark
    I'm not sure I fully understand you. What switch do you have, and which combinations do you get?
  17. Deaf Eddie
    Sunny San Diego, CA
    LIKE THIS...
    He's saying (I @SSume) that he's using the stock "Strat-style" 5-way like you (Chris) have, and has added a single push/pull to get the bridge+neck combo that you wanted. That is an easy one to do, but it gives you NO SERIES combos, the combos are all parallel.
    You simply wire the p/p with its common lug jumpered neck (or bridge) pickup's lug on the 5-way (along with the pickup's hot) , and its "pulled" lug jumpered to the volume pot.
    You would PULL the p/p to have the neck (or bridge) pickup ON all the time, regardless of where the 5-way is.
    P/P down, you have the normal five combos; p/p PULLED gives you the neck+bridge combo, as well as all-three-pups. Again, the combos are all parallel - NO SERIES. To get a series combo would require an additional switch.
    Whether you select to have the bridge or neck pup on all the time will determine at which end of the 5-way the neck+bridge combo will appear, at the bridge-end or the neck-end. A jumper to the neck pickup to put it at the bridge-end of the 5-way (as shown in the drawing); or, a jumper to the bridge pickup will put it at the neck-end of the 5-way. You pick.
  18. rlivin
    rlivin TDPRI Member
    8
    Sep 27, 2007
    North Alabama
    Yep, Thats what i did. Thanks Deaf Eddie for explaining it.
  19. chrisdk
    47
    Feb 13, 2008
    Denmark
    Thanks guys!
    So I could wire it like this (like a B-bender) if I replaced the Fender Switch with a SuperSwitch?
    So I would have:
    bridge, bridge+mid, brige+neck, mid+neck, neck.
    That would be the 3 classic tele tones, with my 2 favorite Strat in-between tones...
  20. Deaf Eddie
    Sunny San Diego, CA
    Yup, with a Superswitch (Fender uses the "half superswitch" in the B-Bender model) you get individual lugs for each throw, not the "shared lugs" in throws #2 and #4 of a Strat-style 5-way.
    You could "mix and match," and put your favorite five combos on it - and, in any order.
  21. chrisdk
    47
    Feb 13, 2008
    Denmark
    That sounds great. Do you have a wiring diagram for the positions I mentioned above with such a superswitch - or know where I can find it?
    Also, will a Tele Barrel Style Switch fit, or will I have to live with a strat tip?
