My small the Pin Router
Discussion in 'The DIY Tool Shed' started by Deneb, Mar 17, 2017.
Tags:
  1. Deneb
    Deneb Tele-Afflicted Silver Supporter
    Feb 16, 2011
    Ukraine, Dnipro
  2. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    I make a second clamping jaw:
    And try on a shank.
    LeftFinger likes this.
  3. RogerC
    RogerC Poster Extraordinaire Vendor Member
    Mar 30, 2011
    Oklamerica
    That's ingenious, Deneb! You've got some serious skills, man, especially between the ears! :)
  4. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Many thank you, Roger! I will answer you with the words that belong to Golda Meir: " We had a secret weapon - no alternative."
  5. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    I bought a drill bit for wood:
    I fixed this a drill bit in the jig
  6. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Next up welding:
    Turned 180 degrees
    Done
    Next up marking for cut of a drill bit.
  7. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    I sanding excess metal
    I cut off the drill bit so that I have two a drill bit
    RollingBender and awasson like this.
  8. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Now I check it on a drilling press.
    The result is this: this is a very good jig for lengthening a drill bit.
  9. thyratron
    thyratron TDPRI Member
    Nov 1, 2016
    Wakefield England
    Nicely done, no sign of wobble.
    Paul.
  10. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Many thanks, Paul!
    Yes, it works.
    Deneb
  11. Davecam48
    Davecam48 Friend of Leo's Gold Supporter
    Queensland Australia
    So clever!!!! What a great work-around, as Roger said, you have some serious skills!
    DC
  12. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Dave, many thanks to you for your high appreciation of my work!
    Now this method is available for all forum member:)
    Deneb
  13. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Today I returned to work with Pin Router. I kept wondering which handwheel to use for the lifting mechanism. And then I remembered the motor that was in my reserve. Having weighed all the pros and cons, I decided to use an electric motor:
    Next steps in the photo:
  14. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Approximately it will look like this:
    I also installed a screw for a solid fixing in this part:
    Mat UK likes this.
  15. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Also I made a video about the work of an electric motor:
  16. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    Looks like a good speed, relatively fast, but slow enough to "bump" into perfect position. Do you plan to put limit switches on it, so it can't be accidentally run too far on the shaft?
  17. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Yes Rick, for non-professional use is acceptable variant.
    I thought about it ... but I never saw it. Can you show me what limit switches I can apply in my case?
  18. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    IMG_0436.JPG I'm thinking about 2 simple micro switches, one at the top of the screw, one at the bottom. Mount switches in brackets, so as the traveler reaches the end of the screw, it pushes the lever on the switch, opening the circuit for that direction of travel, stopping the motor. It could be run in the opposite direction, and would restore to normal operation when the lever of the switch is no longer pushed. Same operation top and bottom.
  19. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Thank you very much sir!
    For this reason it has three contacts?
  20. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    No, when I said "it", I meant the traveler, of the lift mechanism. In other words, the machine would be wired so that once the lift mechanism reached the maximum travel--top or bottom, and pushed the switch lever, the lift mechanism motor would not turn in that direction, but it would turn in the opposite direction, to move the traveler of the lift mechanism away from the maximum travel stop point.
    Most microswitches have terminals for Normally Open, Normally Closed, and Common, which accounts for the 3 terminals.
