My small the Pin Router
Discussion in 'The DIY Tool Shed' started by Deneb, Mar 17, 2017.
Tags:
  1. Deneb
    Deneb Tele-Afflicted Vendor Member
    Feb 16, 2011
    Ukraine, Dnipro
    Thank you!
  2. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Thank you for your thinks. I can not say for sure. But, I think the power load that will fall on the hinges is not so big. Approximately max 9 kg/20 lb of weight (in total).
  3. Zepfan
    Zepfan Poster Extraordinaire
    Nov 30, 2013
    Horn Lake, MS
    I was thinking about the weight and vibration. Your weight load is small, so maybe not a problem then.
    Deneb likes this.
  4. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    I think that too!
    On to my sensations, weld seams are strong enough.
  5. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    When I wore parts for welding to a welder (in 2015-2016) he told me:
    - I do not know what device you are doing, but judging by the matching of the details it will fly into space.
    But I can say with certainty: This will not be launched into space.:):);)
    If necessary, I will make repairs on the Earth.:lol:
    Zepfan likes this.
  6. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    Overengineering is a mark of intelligence! Who needs elegance ( except maybe in women?). Bigger, thicker, stronger, that's the ticket. Beautiful work as usual, Vlad.
    Deneb likes this.
  7. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Many thanks to you Rick, for your appreciation and kind words!!! It's nice to hear from the man who has a lot of experience!!!
  8. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    I mounted an axles in the hinges and fixing the hinges
    20171216_133634.jpg 20171216_135311.jpg 20171216_135832.jpg 20171216_135435.jpg 20171216_140119.jpg 20171216_140820.jpg 20171216_143640.jpg 20171216_144640.jpg
    Looking bottom up. I need to embed the hinges in the frame of the table. Because of an error in measuring the size of the countertop of the pin router. According to my data, I should have the distance from the hinge to the frame of the table about 1.5 inches. In fact, I have the distance of 0.4 inches.
  9. Davecam48
    Queensland Australia
    I hope you know how this should work Vlad because you just lost me! :confused:
    DC
    Deneb likes this.
  10. nickhofen
    nickhofen Friend of Leo's
    Deneb likes this.
  11. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Do not be afraid, Dave)))). To the work of the PIN router this has an indirect relationship. This is for a service. More precisely to establish the alignment of a pin and a mill.
  12. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Many thanks, Nick!!!
    nickhofen likes this.
  13. Davecam48
    Ahh........................I align my pin and milling bits with a round shaft with a slightly off centre pin which is held in the chuck of the table mounted router which can usually be turned to precisely coincide with the router bit centre above, but, I bow to your superior engineering knowledge and look forward to it's completion. :D
    DC
    Deneb likes this.
  14. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Dave, can you show your centering mechanism for a pin?
  15. Davecam48
    Hi Vlad. Its a bit hard as most of my templates work with a 3mm pin. In my o/head routers, the frame is mounted on the router table with the large table mounted router still in place. The 1/2" chuck holds a variety of home made pins, some with centered pins of sizes to match the top cutter others deliberately made slightly off centre to accommodate slight differences in placement of the over head frame which is removed to use the router table as a router table. The in table router is height adjusted with a scissor jack. Sometimes the top routers (trimmer routers) are removed for other functions and slight misalignments can occur when refitted into the holder on the vertical carriage. These discrepancies are usually only in the order of around 1mm or so and easily compensated by giving the underneath chuck a slight turn to change the position of the pin to correctly align to the cutting bit.
    Have a look here from when I built my amateur version of your metallic masterpiece! :lol:
    http://www.tdpri.com/forum/tele-home-depot/288873-overhead-router-system.html#post3536069
    Love your engineering mate!
    DC
  16. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Hi Dave! I liked your idea !!! :cool:You killed two birds with one stone!
  17. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    Dave has quite a number of dead birds laying around his shop! :lol::lol:
  18. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Dave is probably a good shooter!:);)
  19. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Today I continued my work. Fit in chipboard.
    and in metal
    Next up i'm try
    R. Stratenstein, nickhofen and Zepfan like this.
  20. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    This is for the second part of the hinges.
    I'm getting a little warm)
    Now I take off the top surface and I will use the technological holes to fix the Pin Router on a pins.
    Zepfan likes this.
