My small the Pin Router
Discussion in 'The DIY Tool Shed' started by Deneb, Mar 17, 2017.
Tags:
  1. Deneb
    Deneb Tele-Afflicted Vendor Member
    Feb 16, 2011
    Ukraine, Dnipro
    Dave, you will not believe me, I also can not wait for this!:eek::D
    Zepfan likes this.
  2. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Here a cross tubes, with process plates.
    I'm looking for the right position before welding.
    20171202_134507.jpg 20171202_135213.jpg I calculate the necessary position and make an adjustment. Is fixed, slightly welding.
    20171202_151621.jpg Trying on.. I counted everything correctly. The pin router entered 1.5mm below the level of the table top.
    20171202_153017.jpg It's time to turn on the lights:)
  3. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Well, now I can fix fixed it by welding
    20171202_161307.jpg 20171202_161738.jpg 20171202_161750.jpg Done
    But, this is not the end:).
    Zepfan and n__B like this.
  4. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    By the way, I received a shaft (dia 16mm/ 5/8'') with fixatives today. This is the details for a Inverted Pin Router.
    Now I can design a drawing for a turner.
    Zepfan likes this.
  5. Davecam48
    Davecam48 Friend of Leo's Gold Supporter
    Queensland Australia
    Great craftsmanship as usual Vlad!
    But .....this worried me!!!! The working base and the table top MUST be perfectly level without any height difference, otherwise it causes MAJOR problems when actually in use. The template hits the raised edge and can't go anywhere due to the pressure from the above cutter and will ruin your job. I speak from experience :oops: On the other hand, knowing you, I suspect you already knew that and you have some devious plan in mind to eliminate this problem. (Like a sheet of 1.5mm super slip stainless steel or plastic?)
    DC
    magic smoke likes this.
  6. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Thank you, Dave, for your kind words!!!
    :):)Yes, I did it deliberately! Since the table is made of a square tube, this represents a non tuned acoustical system. I can not adjust such "acoustic systems". And to reduce the roar of this "Himalayan eagle", I'll put rubber gaskets.:);)
  7. Davecam48
    That's a very good idea!! Those damned Himalayan Eagles can sure roar loudly...............a pity they are never in tune with each other!
    DC:lol:
    Deneb likes this.
  8. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    So, me need make two a hinge for lifting the Pin Router:
    I'm Getting Started:
    nickhofen likes this.
  9. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    20171209_144144.jpg 20171209_144338.jpg 20171209_144734.jpg 20171209_144806.jpg 20171209_144917.jpg 20171209_145148.jpg 20171209_150549.jpg 20171209_150633.jpg
    While the first hinge cools, I make a elements for the second hinge
  10. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
  11. Davecam48
    Looks more like a pocket knife rather than a hinge! Amazing ideas and workmanship!
    DC
    Deneb and Mat UK like this.
  12. Mat UK
    Mat UK Tele-Afflicted Silver Supporter
    Feb 17, 2009
    London, UK
    I don't really have a clue what's going on here, but I like it! I always find this thread intriguing!
    Deneb likes this.
  13. Davecam48
    Same here Mat. I think Vlad has plans to make a huge machine where you throw in some wood and wire in one end and 10 minutes later a fully finished guitar comes out the other end. I'm waiting for the pics of the control dial.................you know the one that says
    Fender..Strat/Tele
    Gibson...Les Paul/335
    etc.etc. ;)
    DC
    awasson, Mat UK, Deneb and 1 other person like this.
  14. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Yes, I agree with you!:)
    Thank you so much Dave, for your appreciation!
    Welcome and Thank you very much, Mat UK!
  15. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Yes, I'm on my way to this!:);)
  16. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    This is the second hinge, it is also made as the first hinge.
    20171210_091226.jpg 20171210_091232.jpg 20171210_100734.jpg 20171210_101001.jpg
    Now the next step:
  17. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    Now the second hinge:
    20171210_112000.jpg 20171210_112058.jpg 20171210_112406.jpg 20171210_112655.jpg 20171210_112826.jpg 20171210_113221.jpg 20171210_113232.jpg 20171210_113238.jpg 20171210_113351.jpg
  18. Deneb
    Feb 16, 2011
    Ukraine, Dnipro
    We turn on the telescopes to find the brothers by reason::)
    20171210_113523.jpg 20171210_113533.jpg 20171210_113554.jpg 20171210_113601.jpg 20171210_113607.jpg
    We turn off the telescopes...
    Now I need to drill a larger diameter hole and put an axes
    nickhofen and Zepfan like this.
  19. Zepfan
    Zepfan Poster Extraordinaire
    Nov 30, 2013
    Horn Lake, MS
    Excellent design of hinges. They look very durable.
    Deneb likes this.
  20. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    I am a little worried about the welds, whether you got enough penetration into the steel before you grinded the weld back smooth on the sides. The hinge knife to plate would benefit from a weld to the sides instead of only 2 small button welds. I realize that would be difficult to do and have good operating travel all the way to the base.
