My Les paul sounds terrible thru Blues jr while my Strat and Tele sound great
Discussion in 'Music to Your Ears' started by stepvan, May 4, 2019.
  1. stepvan
    stepvan TDPRI Member Ad Free Member
    amherst
    Just was wondering does anyone else have an issue trying to coax good tone from a Gibby Les Paul and Blues jr combo? Mine has 490r 498t pickups which of course sound great thru my valve king or Marshall. Any suggestions?
  2. nojazzhere
    Foat Wuth, Texas
    In what way does it not "sound good"? Some guitar/amp combinations just don't "click". The only guitars I've played through my Blues Junior III are my Telecaster and PRS SE One, with one P-90 and a hot rails-style humbucker in the neck.....and both guitars sound good.
  3. bftfender
    bftfender Friend of Leo's
    York PA
    lets hear the clips
  4. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    Fat switch off?
    RoscoeElegante likes this.
  5. muscmp
    muscmp Tele-Afflicted
    california
    tweak the amp and the guitar. you'll find it.
    play music!
    nojazzhere and 3-Chord-Genius like this.
  6. nojazzhere
    Foat Wuth, Texas
    Do you play with Fat switch ON? I only rarely use that as a boost for a lead.
  7. whoanelly15
    whoanelly15 Tele-Holic
    It’s not the amp. It’s just that strats and Teles are far superior to all other guitars. ;)
    Sorry. Someone had to say it. And sadly, I have no experience with that amp, so I have nothing to offer.
    swany and Dismalhead like this.
  8. 24 track
    kamloops bc
    more likely that the higher output of the LP pushes the JR in to early clipping and the weaker fender pickup give it that warm sound because you can push the amp without issue, you can dial down the amp to zero and introduce the LP till it sounds good , or use it to run your fenders,
    but that is most likely the main culprit
    Dismalhead and thunderbyrd like this.
  9. GoldieLocks
    GoldieLocks Tele-Afflicted
    Abbotsford B.C.
    I think Blues Jr.'s generally sound Tubby. (fat flubby low end and cardboard box midrange). Volume dependent and speaker options as a variable. A thin sounding guitar will clean that up a bit. A general Les Paul will make it worse.
    I was testing Fuzz pedals through a Blues Jr. at the music store today (With a Gibson S.G. $2500.00). Not bad. Just about my least favorite amp. the right speaker might tighten all that up. (and speaker box).
    Mad Kiwi, blowtorch and Chunkocaster like this.
  10. Milspec
    Milspec Friend of Leo's
    Nebraska
    Fenders sound best through Fenders and Gibsons through Gibsons.
    The builders design it that way, they make an amp using their own branded instruments in development, so it only makes sense that mixing may not sound as good. That is not to say that you can't dial them in to sound good, but they will take more effort to do it. My old Gibson Skylark would make your ears bleed with ice-pick highs using Fender instruments with single coils, but plug in a somewhat dark humbucker and it sounded great.
  11. Chunkocaster
    In space with Ziggy
    I own a blues junior and brighter guitars do sound better through it.
    blowtorch and DonM like this.
  12. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    Not enough headroom on that amp for your typical guitar with humbuckers – especially a hot humbucker like a 498T.
    I have the same issue with any humbucker equipped guitar through my lower wattage amps. Even typical PAF winds combined with low output magnets like A3 and A2 need some rather extreme massaging to get the clarity. Since I mostly play low headroom amps, I have taken to running neck winds in the bridge position, and getting either an underwound, or under-magnetted, neck pickup. E.g. A5 or A4 bridge magnet combined with an A3 or A2 neck magnet.
    That said, if you push the amp and/or the guitar less, the 490R should be able to get some sweet tones through that amp. You must set your knobs the right way. Try setting it up for less gain/breakup, more treble, and turn the bass knob way down – all the way down if you have to. Try just slightly backing off the volumes on the guitar, e.g. put them at 9 or 8, while putting your tones on 10. That will result in a thinner, plinkier sound, not as saturated with low end.
    Bottom line, you just have to run the Blues Jr. more mildly in order to get some clarity from that combination of hot pickups, short scale length, and a low headroom amp.
    blowtorch likes this.
  13. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Back the treble, mid and bass off. Yes, all three.
    On an old Fender you'd plug into the 'low' input.
    Back off the bass side of the pickups 1/2 turn. In fact 1/2 on the treble and 1 on the bass side
    These are all easy changed..
    When playing the guitar set the amp to 'lead or solo' level. Back off your guitar volumes for rythym.
    The next requires a mod.
    If you don't have treble bleeds or vintage wiring (my personal recommendation) you may get mud. So a minor change is a good idea.
    kellybluz and rangercaster like this.
  14. stratoman1
    stratoman1 Tele-Afflicted
    Virginia Beach, Va
    As said above, start turning knobs. You'll get there
    rangercaster likes this.
  15. Nick Fanis
    Nick Fanis Friend of Leo's Ad Free Member
    Athens-GREECE
    You need more headroom than a BJ in order to sound great with the high output humbuckers of your Les Paul.
  16. Guitarteach
  17. cousinpaul
    Nashville TN
    I've read about some high profile players shutting off the the bass control and using the mid control to dial in the lows. It works because of the interactional nature of the Fender tonestack. These are guys who play their Supers on 8 or so. All the same, it might be a fun experiment.
    Also, try less preamp volume and more master. The idea is to attenuate the input to get a similar response to your other guitars that work well.
    Jerry_Mountains likes this.
  18. rangercaster
    rangercaster Friend of Leo's
    portland, or
    A Les Paul should sound great w/ a Fender amp ... I once saw Les at a recording session/concert and he used a Fender amp ... He was using his Recording model guitar he favored ... It sounded incredible ...
  19. Tonemaster
    Tonemaster Tele-Afflicted
    Ontario
    To my ear, nothing sounds good through a Blues Jr. Worst. Amp. Ever.
  20. mexicanyella
    mexicanyella Tele-Holic
    Troy, MO
    You might also try a compressor pedal in front of the amp, set to compress lightly and with slow enough attack that your pick transients aren’t squashed...then play with the compressor’s output level (starting with a slight overall gain reduction to simulate lower-output pickups).
    Taming the signal spikes can help in some cases.
