My CNC build.
Discussion in 'The DIY Tool Shed' started by nickhofen, Dec 15, 2017.
  1. GunsOfBrixton
    GunsOfBrixton Tele-Afflicted
    Dec 9, 2011
    Rochester, NY
    Didn't think you did Nick! Just wanted to make sure it was clear to anyone reading this. A well constructed CNC using aluminum extrusion is more than up to the task for most of our needs in the guitar building world.
  2. nickhofen
    nickhofen Friend of Leo's
    Thanks Robert, just keep watching because more disinformation might come up!:D
  3. nickhofen
    I want to say again that I am not a cnc expert, I am more rookie than the rookies!
    What info you see here is gathered from forums and discussions from people thru pm or face to face.
    Please for your own good-money and time saving double check everything you read or wait till my machine start to cut before you do anything like that!!!:D
  4. jvin248
    jvin248 Friend of Leo's
    Apr 18, 2014
    Near Detroit, MI
    A T-body won't reveal the time savings but a Les Paul or PRS type carve-top will. The CNC will accurately repeat your shape part after part.
    You can listen to the machine and know it's cutting right or if there is a problem, so while you 'walk away' you are right near by. No different than if you hired the kid down the street to template router bodies out so you can carve some necks. You're listening to that cutter run.
    Your CNC job setup is crucial to get good output quality and that is where the craftsman skill remains.
    Deneb and nickhofen like this.
  5. nickhofen
    I use the end mill chamfering with sunk to prepare the holes,then screw the aluminium angle in place, the axis weight now 8.7 kilos.
    26197372_2013634538917868_273040787_n.jpg 26197372_2013634538917868_273040787_n.jpg 26135297_2013634435584545_1872782504_n.jpg
    adirondak5 and GunsOfBrixton like this.
  6. nickhofen
    We expect some visitors in about one hour but I manage to paint the CNC bench today black and the sides where the Y axis extrusions are going to rest yellow.:)
    adirondak5 likes this.
  7. nickhofen
    Now I see that the cnc is going to much with my bandsaw and the thickness planner!!!Lol!
  8. adirondak5
    adirondak5 Wood Hoarder Extraordinaire Ad Free + Supporter
    Oct 24, 2009
    Long Island NY
    Nice work Nick , a two tone paint job eh ? That's just getting fancy .
  9. nickhofen
    Thanks Herb,I try to make it look professional job,haha!!!
  10. sergiomajluf
    sergiomajluf Tele-Meister
    329
    Sep 26, 2015
    Santiago, Chile
    My mini version of a CNC,hahaha
    Will follow your updates closely, maybe I’ll take the plunge on a big one like yours
    nickhofen likes this.
  11. nickhofen
    Nice ,is this a CNC kit?
    How big is it and what are planning to cut with it?
  12. sergiomajluf
    329
    Sep 26, 2015
    Santiago, Chile
    Yes, it's a $300 kit from China. The bed is 91/2 x 7 inches (24x18cm), it can route and laser etch. I´m planing on doing PCBs and maybe invent some contraption to cut frets. Or I could do model 1:4 scale guitars heheh. Maybe I'll open another thread so I don't highjack this one
  13. nickhofen
    Since is is an open bed cnc you can try radius, make drills for the dots and cut slots at fretboards, usind slow feed and speed.
    You are not hijacking but it will be interesting to see the the full building of this cnc at a thread.
    Welcome to the cnc fever!
    sergiomajluf likes this.
  14. sergiomajluf
    329
    Sep 26, 2015
    Santiago, Chile
    Dangerous and infectious fever indeed.
    This was my first foray into CNC, at work.
  15. nickhofen
    I start assembling the X axis ball screw.
    First problem, all the allen head screws I have bought is about 3mm (1/8 of an inch) longer, because when I measure the depth of the holes with my depth meter I forgot to subtract some of the length since the tapping tool cannot tap the whole length of a blind hole.
    The fix was easy!
    26694359_2019087078372614_1705850816_n.jpg 26694039_2019087041705951_1004071929_n.jpg 26694226_2019087118372610_893579321_n.jpg
    sergiomajluf and adirondak5 like this.
  16. nickhofen
    I start the leveling.
    Weld one bolt under each bench leg so I can level the machine, I have to grind the sharp edges.
    26794113_2020905781524077_1229197517_n.jpg 26856830_2020905734857415_1658481701_n (1).jpg 26754711_2020915281523127_955502036_n.jpg 26794260_2022308588050463_1018075560_n.jpg
    guitarbuilder and sergiomajluf like this.
  17. adirondak5
    Oct 24, 2009
    Long Island NY
  18. nickhofen
    26914199_2022308798050442_542165486_n.jpg After the first leveling I pull out from his wooden box, the secret weapon!
  19. nickhofen
    This thing is very old, although very accurate because I trade it with care , it wasn't possible to get a better photo that is why I have mark where the babble is , I am going to continue and get a better result.
