My 6G3 Brown Deluxe Build
Discussion in 'Shock Brother's DIY Amps' started by flyswatter, Jan 11, 2019 at 10:28 PM.
  1. flyswatter
    flyswatter Friend of Leo's
    Jan 12, 2013
    Quebec
    Here's the amp I completed over the holidays, a replica of an early 1960s brown Deluxe 6G3 amp. I've built tweed Deluxes in the past and have repaired/ restored a few blonde and brown-era original Fenders in recent years, plus repaired a nice 65 blackface Deluxe a few months ago, so it felt like the right time to do a 6G3 build.
    I'll post a few photos of the finished amp, then come back and post up some of the play-by-play pictures of the build. I encountered a few troubleshooting issues along the way, all of which were eventually solved, so I'll mention some of those in case others encounter them in the future.
    BTW: In case you're wondering, I make my own eyelet boards, tolexed cabinets, and machine the chassis. The chassis was provided blank by a custom maker and the face plate for the amp was provided by the friend who commissioned it (it appears to be a Mojotone plate). My starting point was the original 6G3 schematic. I'd encourage anyone building an amp to get to know the schematic and to work the build out on paper before you start cutting and drilling.
    jtcnj, robrob, Wally and 7 others like this.
  2. flyswatter
    Jan 12, 2013
    Quebec
    Some photos of the build process.
    First thing I do is draw up a layout to scale on 11x17 graph paper. I do one drawing for the components, then a transparency with the wiring laid over the top.
    This might seem like a lot of hassle when one can simply download a readymade layout online, but it makes the build easier when you have a scale layout to measure from and can plan out all the component placement and wire lengths in advance. I think of this as "building the amp on paper first" and it helps me to anticipate problems and avoid mistakes with the actual build.
    BTW: There are a few mistakes in these drawings that I fixed later, but this is where I started.
    Wally and Uncle Daddy like this.
  3. flyswatter
    Jan 12, 2013
    Quebec
    Circuit board:
    I used blank phenolic board (the stuff that looks pale beige) that I cut to size then paint with heat resistant enamel so it looks better.
    I place a photocopy of the layout over the board to situate the eyelets, then drill and stake the eyelets.
    Once the 3 boards (main circuit board, bias board, doghouse filter cap board) are made, I dry mount all the components and solder them from underneath... the way it was done in a lot of vintage Fenders.
    One really key thing I do is photograph the underside of the board before mounting it in the chassis. Anyone who's ever had to pry up a vintage Fender circuit board to sort out wiring and track down shorts will appreciate why.
  4. flyswatter
    Jan 12, 2013
    Quebec
    Building the chassis:
    Getting the holes drilled exactly to match the face plate saved me a lot of headaches later on. A sixteenth inch misalignment can stop a jack or pot from fitting through.
    Same goes for getting all the main components and boards situated properly. I definitely see the advantages of buying pre-punched chassis for builds, but up here in the Great White North it's simply cost prohibitive.
  5. flyswatter
    Jan 12, 2013
    Quebec
    Wiring up the amp is my favourite part of any build.
    ... which brings me to the first troubleshooting problem. See that extra hole to the right of the V1 socket? I should have waited to drill the holes for the chassis mounting bolts until I'd finished the cabinet. I winged it and drilled them while doing the rest of the chassis... then found later the chassis bolts wouldn't go through and I had to redrill them. Never a problem with a rear mounted chassis like a 5E3! Oh well, lesson learned.
  6. flyswatter
    Jan 12, 2013
    Quebec
    First power-up = Troubleshoot #2. The amp had a massive 60 Hz ground loop hum that took hours to track down. Checked the wiring against the schematic. Checked it against mine and others' layouts. Everything appeared wired "correctly."
    Here's what the output with the hum looked like on the scope. Ouch!
    Here's what the problem was. I'd grounded all 4 filter caps in the doghouse on a single bus running back to the power supply ground star. Big mistake. Cutting the ground for the last (nearest in the picture) filter cap from there and moving it to the preamp ground bus cured the problem.
    Hum completely gone! The amp sounded quiet as a lamb after that.
    [Edited for accuracy]
    Wally likes this.
  7. jsnwhite619
    jsnwhite619 Friend of Leo's Ad Free Member
    Sep 10, 2013
    Georgia
    Congratulations! I got the parts and halfway started my 6g3 last spring/early summer and it's just been on the back burner since then. Got the cab framed out and glue together, but still a ways to go. I need to get it finished!
    flyswatter likes this.
  8. flyswatter
    Jan 12, 2013
    Quebec
    Cabinet time!
    I used solid pine, dovetailed for the shell. A Baltic birch plywood baffle. The baffle mounts from the front in the traditional way. The speaker is a pretty tight fit in the standard-sized 6G3 cab to clear the transformers, but it all worked out.
    For tolexing, I used a latex contact cement by LePage -- my favourite product used on many projects. Tolex is rock solid once the glue sets. Regular contact cement can melt many vinyl coverings and I can't stand the fumes. Unfortunately, the latex stuff is twice the cost... but it works for me.
    Finishing touch is the tube chart, made on Word to look like a vintage one... shellac'ed onto the inside of the cabinet.
  9. flyswatter
    Jan 12, 2013
    Quebec
    Quick video of the finished amp, and we're done!
    Bill Moore, mgwhit, Ricky D. and 3 others like this.
  10. flyswatter
    Jan 12, 2013
    Quebec
    Good luck with your build! You'll be happy as a cat when you finally power the finished thing up! I listened to a ton of early ZZ Top for inspiration... apparently Billy used a brownface on a lot of studio recordings.
    jsnwhite619 likes this.
  11. John How
    John How Tele-Meister
    373
    Mar 22, 2016
    Auburn, Ca
    Awesome...I have collected the parts for a 6g3 build after just finishing the 6g2 a couple months ago...now I’m just awaiting the chassis that my metal working son is building for me...I should have it in a week or so...im gonna do it as a 2x10 combo...thanks for sharing your build...I like your MO, working the layout on paper before firing up the soldering iron...I’ll do that as well...I’m going to be using terminal strips so I don’t have to worry about under the board wiring...I found some really nice military surplus terminal strips a few years back and it’s nice being able to see everything while working problems...
  12. rjp68
    rjp68 TDPRI Member
    37
    Jan 6, 2019
    Central California
    Sounds pretty excellent!! Awesome job..:)
  13. CoyotesGator
    CoyotesGator Tele-Meister
    475
    Jul 12, 2014
    Gulf Coast
    Very Nice!
    Such a great circuit.
    What led you to the Invader and did you try other speakers?
  14. Uncle Daddy
    Uncle Daddy Tele-Holic
    604
    Sep 26, 2015
    Maldon, England
    Does the pulse from the trem creep through on tickover? I had a Vibrolux that I just couldn't cure. I love Brownface trems; Blackface trem always sounds like it needs a vitamin injection.
  15. theprofessor
    theprofessor Friend of Leo's
    Aug 8, 2016
    Chattanooga, TN
    Congratulations, and what a magnificent thread! I love your attention to detail, right down to drawing your own layout on graph paper. Well done! And thanks very much for narrating the build this way for others down the road. Enjoy!
  16. flyswatter
    Jan 12, 2013
    Quebec
    Thanks. A 2X10 cab will make yours like a brownface Super at lower wattage. Should be a great setup. Brave choice to go true P2P on terminal strips. I hope you'll post pictures of that process; I'll follow for sure.
  17. flyswatter
    Jan 12, 2013
    Quebec
    This particular amp was commissioned by a friend who's an SG/ rock n roll type of guy and he provided the Invader. I have an Invader myself, though, in a Traynor YGM-2 so I approved of the choice. I didn't try other speakers in this particular amp, but 2 yrs ago I restored an original brown Super that got an Eminence Cannabis Rex (good for taming brighter amps as that particular one was, but I think it would have dulled the bright channel on the 6G3).
    CoyotesGator likes this.
  18. flyswatter
    Jan 12, 2013
    Quebec
    Yes, a tiny bit on the bright channel. With the blackface Deluxes that have an optoisolator (roach) it is much easier to cure with an extra coupling cap to ground. Lead dress is important, although I was very careful about lead dress in mine and it still ticked a tiny bit. Keeping a footswitch plugged in cures it; however, there are a couple of other options:
    One simple solution is to install an on/ off switch for the tremolo. Rob Robinette has a diagram for that on his site. https://robrobinette.com/Generic_Tube_Amp_Mods.htm#Tremolo_Cut_Switch_
    I adapted that idea to mine by putting a simple on off switch beside the tremolo jack, which basically acts the same as a footswitch when none is plugged in. It works fine. Tick gone.
  19. flyswatter
    Jan 12, 2013
    Quebec
    Thanks, Professor. I find that drawing things out really helps. It kind of forces one to scrutinize the circuit and layout in way that pays off later when it comes to drilling and mounting components (tellingly, the one element not included on the drawing -- hole positions for chassis mounting bolts -- is where I made my biggest screwup). It also helps with lead dress, knowing just how long a particular piece of wire needs to reach and what else it is liable to rub up against on the way.
    Wally likes this.
  20. Wally
    Flyswatter, beautiful job!! Kudos! One minor observation about the grounding for the filters. That cap that you separated from the others is actually the last cap in the power supply chain and not the first, correct??
    Again....nothing but respect for your work!!!!
