Join TDPRI Today
My 3 way switch is different..
Discussion in 'Tele-Technical' started by VeeNeck, Dec 1, 2012.
  1. VeeNeck
    VeeNeck TDPRI Member
    49
    Oct 19, 2012
    Scottsdale, AZ
    ..than the ones in the diagrams I have printed out. Instead of wheel shaped, it is box shaped and has a row of small tabs across the bottom to solder to.
    It has SEON JIN on one side and NP on the other.
    I was intending to install 2 blade type HBs and a push-pull for volume, but now am a bit taken back. I could live without the push-pull, if need be, but wish to continue.
    All of the wires soldered to the switch are white. And some tabs have a tiny jumper between them.
    If I could just get the HB in the neck position tonight, I'd high-5 myself.
    But doing both would be unreal.
    Any diagrams for this type of 3-way?
    Thanks...
  2. Lunchie
    Lunchie Poster Extraordinaire
    Does it look like this?
  3. VeeNeck
    49
    Oct 19, 2012
    Scottsdale, AZ
    Yes, Lunchie, but the 8 soldering tabs are sticking out. Same concept, though.
  5. Lunchie
    It can be done, the picture below is for a 5 Way to import but it should be the same concept. The middle 2 will be common.
    However if you are going through the trouble of replacing the pickup it maybe worth getting rid of the cheap import switch for a Fender switch. They are a whopping $10 at GC.
  6. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
    Lunchie, can you post a larger version of that?
  7. doof
    doof Tele-Holic
  8. VeeNeck
    49
    Oct 19, 2012
    Scottsdale, AZ
    Yeah, Lunchie,
    I ran over to the GC tonight, not quite in time, they close at 7:00, dammit.
    But the tech guy told me they have 'em in stock, on his way out. I'll wait til tomorrow...That way it will look like the plans I printed. Much easier.
    Funny that you said 'it can be done'. I was looking at some old spaghetti western titles today and "It Can Be Done, Amigo" stood out for me.
    Weird.
    Thanks, man. Merry Chistmas.
  9. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
  10. Lunchie
    Much better quality as well. Good luck and let us know how it turns out.
  11. VeeNeck
    49
    Oct 19, 2012
    Scottsdale, AZ
    Will do, Lunchie.
