MXR Dyna Comp is it worth buying
Discussion in 'The Stomp Box' started by texmck54, Sep 18, 2017.
  1. blille
    blille Tele-Holic
    Lol welcome to the internet!
  2. jenos
    jenos Tele-Meister
    181
    Mar 28, 2012
    Columbia, SC
    +1
    Simple and good effect to have that can be used in different ways to improve your sound. Try all over the signal chain too. Doesn't just have to be Tele->comp->amp.
  3. waparker4
    Nov 9, 2011
    Philadelphia, PA
    Serious answer time - MXR Dyna Comp is it worth buying? Not new @ $79.99, because the Biyang CO-10 is available for $38
  4. blille
    blille Tele-Holic
    Fair. Pretty healthy used market for it though.
  5. waparker4
    Nov 9, 2011
    Philadelphia, PA
    True! But in my opinion, the Biyang is the better unit, and it's priced new near the low end of the MXR's used price range.
  6. bluesky1963
    bluesky1963 Tele-Holic
    849
    Apr 1, 2011
    Glendale, AZ
    Is the Dynacomp worth buying? At the right price, yes. Is it a holy grail pedal? No.
    Teleguy61 likes this.
  7. telemnemonics
    Mar 2, 2010
    The "takes something away" part is the reason one might be better off starting with a more modern comp that allows you to blend some attack back in while keeping the sustain, yet also limiting the dynamic range.
    You can have your polish and some dynamics too.
    Sort of.
    I'm not well schooled on comps but have owned Dyna Comps and Boss comps for more than ten years and never liked them.
    The Pigtronix became useful in two minutes.
    And there are even better modern comps than the oldish Pigtronix line.
    Also worth noting is that some here like their "better" script Dyna Comps, which are probably better than what Dunlop sells today with the MXR brand.
    I have compared other Dunlop MXRs to MXR built MXRs and they were vastly different. There are plenty of places that mod new Dunlop Dyna Comps to MXR script specs.
  8. ukepicker
    ukepicker Tele-Afflicted
    Oct 15, 2013
    East Texas
    A DynaComp is it's own thing. It changes everything and you may like it or you may not. But you can't know until you put it in your rig with your guitar played by your fingers.
    I bought a used one for cheap, loved it until I didn't, then sold it and got my money back. If you can do the same, I'd recommend it.
  9. Martinp
    Martinp Tele-Afflicted
    Westbury, N.Y.
    I've been using one of these since the 70's, works for me on Bass, or with an acoustic.
  10. Endless Mike
    Endless Mike Friend of Leo's
    Nov 2, 2016
    Arlington, Texas
    Buying a dynacomp won't tell the OP if he likes compressors or not. It's only gonna' tell him if he likes that compressor type or style.
    I used a 70's script dynacomp years back. Made me nuts! Even with the sustain set almost off, it was still too much 'pop'.
    Since then, I've tried a whole lot of different compressors. Boss compressors work best for me, you can get a fatter tone, without having your base sound
    buried.
    If I were gonna' have a dynacomp style, I'd go with a super comp, or the Dunlop/MXR bass compressor.
  11. Staypuft1652
    Staypuft1652 Tele-Meister
    321
    Mar 7, 2017
    ND, USA
    I used to have a 78 dyna comp IIRC, its the only compressor I've ever had. It was great for nice sustained lead type stuff. Depends on ones perspective IMO.
  12. Linkslover
    Linkslover Tele-Meister
    105
    Mar 16, 2017
    Chicago
    I had one. Didn't like it.
    To me, it sounded dirty, dark and didn't give me the sustain i was looking for.
    Ended up dumping jut and paying up for a used Wampler Ego. Much more versatile and doesn't effect your tone.
  13. zombiwoof
    zombiwoof Tele-Holic
    722
    Oct 17, 2008
    Tujunga California
    With a Dyna Comp, it has a preset attack, so higher comp levels tend to swell too much. All the old Nashville guys used them with the volume up and the sustain way down, so you got a nice kick to the sound and slight compression, that's how I set mine. I have since gotten a clone (can't remember the brand at the moment) that has a variable attack/release and it is more flexible for higher compression. I think that is what the Super Comp has. Also have a great Ross Comp clone (BBE Bench Press) and their Orange Squeezer clone (Main Squeeze, later called the Orange Squash) that have added attack controls, no longer made but can be found used. Both are great, not expensive at the time, especially the Main Squeeze which sounds great at any compression level.
    Al
  14. MrGibbly
    MrGibbly Tele-Afflicted
    Apr 19, 2014
    SATX
    Obviously, a wide variety of opinions here. My advice would be to try and plug into one at a shop and hear for yourself. The dynacomp does a certain thing really well. If you're trying to get that sound it is a simple, affordable, rugged, plug and play option. If you just want a great compressor you might want to explore some newer circuit designs that are quieter, more tweak-able, and color your sound a little less.
  15. noah330
    noah330 Friend of Leo's
    Feb 10, 2009
    Maryland
    I picked up an old one for $40 (no LED, along with the box and manual).
    I love it.
  16. Platefire
    Platefire Friend of Leo's
    North Louisiana around Many
    Yeah, me too! To me when it comes to squash tone, the dyna comp has it nailed. The pix in the above post is very close to the settings I run mine. Platefire
  17. zombiwoof
    722
    Oct 17, 2008
    Tujunga California
    I read somewhere that the traditional setting for Nashville guys was the two lines on the pots pointing at each other, or close to that. Low Sensitivity, high Output. Nice tonal kick and just a little comp without "pumping". An attack pot added gets more sounds, or buy a similar comp that already has an attack/release (manufacturers use those terms interchangeably) control on it, like the Super Comp or the others I mentioned earlier. The original circuit has basically one usable sound, but it's a nice one IMO.
    Al
