Asher Guitars WD Music Products Amplified Parts Mod Kits DIY Nordstarnd Pickups
Multi-Effects Units; T Rex Soulmate or ???
Discussion in 'The Stomp Box' started by PastorJay, Jun 2, 2014.
  1. PastorJay
    PastorJay Tele-Holic
    Apr 12, 2014
    More good ideas.
    Line 6 M13 with the drive in front of the amp and the other effects in the loop.
    Carl Martin Quattro.
    Vox Multi (actually has a tube). I heard a guy using a Vox recently. It was obviously a good unit.
    Tech 21 Fly Rig 5.
    Thanks again. This is all really helpful.
  2. PastorJay
    Apr 12, 2014
    The Soulmate and the Magnus are similar. The Soulmate can be set up so the overdrive and distortion are in front of the amp, but the delay and reverb are in the effects loop. You can also add other effects to the Soulmate between the distortion and the delay. You can't do that with the Magnus, which is why I didn't already buy a Magnus.
    I also think that on the Soulmate the effects more closely resemble particular T Rex pedals.
  3. telecat33511
    telecat33511 Tele-Holic
    Aug 9, 2005
    Tampa Florida
    I STILL use my digitech GNX2
    just go into the configs, bypass a couple of amps or patches you dont use, save as effects patches -voila ! Save a ton of money
    Buying new I'd go with Tech21 FlyRig
    I have a sans amp tri OD since the 1990 and it Still kills live and in the studio
    So does the GNX2
    Good luck
  4. whiteop
    whiteop Tele-Afflicted
    Nov 11, 2010
    I like the Digitech RP-1000 because you can bypass the amp sims and it's really good for live playing. You can find them used pretty cheap. it also has a built-in looper and send and returns to patch it into your amp's effects loop if you want to use the amp sims.
  5. LordByron
    LordByron Tele-Meister
    Feb 3, 2016
    Atlanta, GA
    I know I'm necro-bumping a thread here, but am curious to see if anyone has more information on the differences or similarities between the SoleMate and the Magnus. In particular, I'm keen to know how similar the OD and the Distortions on each are to one another. (I'm up on the other differences re: FX Loop, aux power, etc.)
    Anybody have any scoop on this?
  6. PastorJay
    Apr 12, 2014
    I never did a comparison except by video demo. But the Soulmate sounds great.
    OD is TubeScreamer based, Dist is Rat-based. I use them very differently depending on whether I'm playing through a Fender/Marshall or Vox style amp. But they both sound incredible.
    Staypuft1652 likes this.
  7. Staypuft1652
    Staypuft1652 Tele-Meister
    Mar 7, 2017
    ND, USA
    That will be 2 demerits....
  8. fretwhizzy
    fretwhizzy TDPRI Member
    Aug 17, 2016
    You might want to investigate Boss' MS-3 . It has three programmable loops for any pedals you might want to add later, or indeed the preamp of your amp if use 4 cable method, plus loads of other internal FX you can place either in front or after the loops. There's also midi outputs and various switching/control in/out that would enable more sophisticated applications if you find you want to be able to do that sort of stuff. What I like about the concept is it not being crazily priced even if just used for its internal FX, but via its other facilities it can incorporate integrating/controlling seamlessly pretty much anything else you might want add if the occasion demands.
    Edit: oh from 2014! I guess you'll have got stuff sorted by now! :)))
    the tool likes this.
