Modify a Silvertone 1448 amp-in-case
Discussion in 'Amp Central Station' started by dkevin, Jun 24, 2019.
  1. dkevin
    dkevin Tele-Meister
    Seattle, WA
    Let us imagine a world where someone has time on his hands and wants to redesign a Silvertone 1448 amp-in-case. Originally this amp is a transformerless amp using a 12AU6, 50C5 and 35W4 half wave rectifier. If this certain individual wanted to replace these tubes with a 6AT6, 6AQ5 (similar to a 6V6) and a 6X4 full wave rectifier what is the most economical ($) way to power this amp? The original operating voltages seem to be irrelevant for our purposes because the tube lineup has been altered. I...I mean HE would be looking for a modest 250vdc on the output plates. If my math is close, that would require a 230-0-230 PT to provide the plate voltage I need. Anyways, if you have a helpful suggestion, drop a line and I will make sure this guy hears about it.
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    You could back-back two 6.3 volt filament heaters - I did this to create a one tube amp with a 6GW8, which has a triode plus preamp . Use a 6AU6 with your 6AQ5.
    You will easily get a watt or two with that. Don't bother with a rectifier tube, just use a full bridge.
    So you connect the two filament heaters 6.3 to 6.3 volt, and use the HT off the second with a voltage doubler to get you 240 volts which rectified to DC is enough.
    The filament transformers cost almost nothing. If you really want, you can use a little line transformer for the output, pennies.
    Or, get really trick and use two 6AQ5s in push-pull.....
