MIM Strat: Trem arm is loose
Discussion in 'Stratocaster Discussion Forum' started by Grandma's Tele, Dec 10, 2009.
  1. Grandma's Tele
    Grandma's Tele Tele-Meister
    244
    Aug 20, 2009
    Montreal
    My MIM Strat sounds good with Vintage Noiseless pickups, however, the trem arm is always loose and it's very annoying!
    Is there an easy fix for that or would I need to get a new trem? I've seen a few MIM like that.
    Would Teflon tape work and if so, last?
  2. DaleH
    DaleH Tele-Meister
    110
    Jul 10, 2008
    B.C. Canada
    A couple of wraps of teflon tape on the threads is good for a month or so.
  3. Grandma's Tele
    244
    Aug 20, 2009
    Montreal
    Ok! Thank's!
    I guess it means that you tried it too!
    I will start by that then I'll see. Changing the whole trem would make the guitar more expensive though I paid only 345$ CAD for it, brand new, after christmas last year. It's a 08. If the teflon tape works fine, maybe it's not worth the investment.
  4. JimInMO
    JimInMO Tele-Meister
    368
    Jun 26, 2008
    Group W Bench
    I have heard that there is supposed to be spring in the bottom of the hole that puts upward pressure on the arm to keep it tight against the threads. Have never seen one in captivity though. I think they escape when the arm is unscrewed so one can shut the lid on the guitar case. I have used the teflon tape for years.
  5. Weazel
    Weazel Tele-Meister
    325
    Oct 21, 2009
    Norway
    If the spring is gone, you could roll a small ball of cotton to put in the hole. It will compress enough to keep the arm in position. It's still working in my '81.
  6. Thin69
    Thin69 Friend of Leo's
    Oct 28, 2009
    Galveston, TX
    If it just does not stay in position teflon tape on the threads worked good for me also but needs to be redone periodically.
    The springs have never really worked for me. They tend to fall out or get crushed in the bottom of the hole and stuck.
    But if the trem arm rocks in the hole when it is screwed down it would be better to replace the block and or arm depending where the offending threads are. I had this problem on a Squier but never on American made ones.
  7. Grandma's Tele
    244
    Aug 20, 2009
    Montreal
    I doubt the problem is the arm itself. It has more to do with the block being poorly made. Also, I have a USA Tele. I guess they use the same cases for Teles and Strats because there was a trem arm in my Tele hard shell case!
    I tried it and it's loose too.
    The USA Tele neck stays straight and hardly ever needs truss rod adjustments. The MIM Strat neck needs adjustment every season. They both sound very good but the USA one has better craftmanship. We really get what we pay for, me think!
    Now I just need to go get some teflon tape.
  8. Ron Garson
    Ron Garson Friend of Leo's Silver Supporter
    May 18, 2003
  9. Kid Klash
    Kid Klash Tele-Meister
    297
    Oct 16, 2007
    PDX
    I've used teflon tape, and I've used the springs... the tape wears out quickly, and the springs compress. Two cheap ways to keep the trem arm from flopping around :
    1. wrap a small rubber band around the trem arm, just above the treaded area, so tha when you screw in the arm, the rubber band comes into contact between the trem arm and trem plate. It gives you enough tension that the arm won't flop around, but you can still flip it out of the way if you want to, and you can remove it when you put it in the case.
    2. same idea, but use a short piece of rubber tubing... the stuff used for making sling shots. Choose a tubing with an inside diameter that is a bit smaller than the outside diameter of the trem arm. Cut a piece of the tubing, and slide it over and just past the threaded part of the trem arm. Screw the trem arm in, and tighten it until the friction of the tubing keeps the arm from flopping around.
  10. fadingcaptain
    fadingcaptain TDPRI Member
    88
    Aug 4, 2009
    South Saturn Delta
  11. zag1
    zag1 Tele-Meister
    378
    Dec 5, 2009
    Washington, DC
    Best thing I ever did was put a "better" tremolo block in my Strat, and get two advantages, 1) no more of that swingin', loose trem arm, and 2) better sustain! Check out; callahamguitars.com. Better than Fender USA as well.
  12. Grandma's Tele
    244
    Aug 20, 2009
    Montreal
    I'm using teflon for now but I'm still thinking about changing the tremolo if it can make the guitar sounds better.
    I'll take the time to think about it though because I tried a Classic Player 60, (I think it is), the light blue one, almost white and it sounds and plays great... Don't know if I'm gonna upgrade my MIM again or just get another one!
  13. hoops
    hoops TDPRI Member
    23
    Jul 4, 2009
    +1 for the rubber tubing, works perfectly. Arm now sits snugly but still easy to move around, it stays where you leave it, which works well for me.
    I used a very small piece, maybe 1/8", just above where the thread stops so it's not visible when you screw it in.
  14. Steve Z
    Steve Z TDPRI Member
    34
    Mar 4, 2009
    Nashville area
    I am in a similar boat except that the trem arm on my MIJ E series strat is missing. Where to find a trem arm for an E series? So I am looking into just replacing the trem block, which would come with a new arm. As with Grandma's Tele, my E series was is rather inexpensive under $250 so investing in a trem block nearly half that cost seems hard to swallow. Any comments on pros/cons of GFS trem blocks? Perhaps a replacement GFS trem block assembly would solve Grandma's Tele's issue.
    GFS Trem blocks... average cost around $37. for standard strat
    Callaham strat trems... price around $127 for mine... $167 for the MIM strat.
    Seems like investing in a Callaham seems like a poor investment, although they are likely better made.
  15. flyingbanana
    flyingbanana Poster Extraordinaire
    Tin foil I say...tin foil.
  16. voided3
    voided3 Tele-Afflicted
    May 6, 2005
    Earth
    I stuck a 1/2" long piece of skrink tubing over the trem arm right around where the arm contacts the top of the bridge plate.
  17. Kid Klash
    297
    Oct 16, 2007
    PDX
    The GFS trem assemblies with the steel trem blocks are a great deal for the money. I installed one in my '95 MIM Strat, and in a couple of modded Bullets. The trem assembly isn't that much more than just the trem block, plus you get a new trem arm to go with it. With the trem block made of steel, the trem arm doesn't loosen up and flop around like it does in the stock (and much softer) zinc trem block.
  18. Steve Z
    34
    Mar 4, 2009
    Nashville area
    Thanks for the input. Greatly appreciated.
  19. Stratt
    Stratt NEW MEMBER!
    2
    Jun 2, 2012
    Melbourne, Australia
    This works brilliantly and doesn't fall out, just fixed my 18mnth old strat with it. Remove the cotton from end of 1 cotton bud and stuff it down the hole. No need to buy new block or springs that fall out. I gotta say if your listening 'Fender' it shouldn't be necessary on a fairly new guitar. Time to change your crap design!
  20. colchar
    colchar Friend of Leo's
    Nice necropost, this thread was three years old.
