Join TDPRI Today
metric vs imperial pots
Discussion in 'Other Guitars, other instruments' started by Feargal, Feb 13, 2013.
  1. Feargal
    Feargal Tele-Holic
    551
    Feb 21, 2008
    Ireland
    I just got a Korean dearmond M75, and one of the old pots is loose and can't be tightened as the threads are worn.
    I'd imagine the old pots are metric so what I want to know is, if I replace them with CTS pots will the original knobs still fit the slit shaft, or would i be better off going for an alpha pot which is metric.
    I know I may have to enlarge the holes in the body slightly.
  2. KokoTele
    KokoTele <img src="http://www.tdpri.com/gifs/vendor.png" /> Vendor Member
    albany, ny [not chicago]
    The metric shafts are a little smaller than the imperial ones, so the knobs won't fit, unless...
    It's pretty easy to take a pair pliers and squash the halves of the split shaft together, and then the knobs will fit. It's not an elegant solution, but it works.
    Or, you could just install the alpha pots because you *will* have enlarge the holes in the body for imperial pots.
  3. Tom Pettingill
    Tom Pettingill Tele-Holic
    667
    Sep 5, 2010
    California
    Unless your wanting to change knobs, I'd say that its much better to not fight it and go with the Alpha pots.
  5. Feargal
    Feargal Tele-Holic
    551
    Feb 21, 2008
    Ireland
    OK, Alpha it is, thanks.
