Join TDPRI Today
measurements
Discussion in 'Tele-Technical' started by custom/59, Dec 31, 2012.
  1. custom/59
    custom/59 Banned
    426
    Dec 16, 2012
    kentucky
    I recently built a strat with a 25.5 scale length. when measuring from the nut to the middle of the mounting screws it measured 25.25 for it to come out right for intonation. I am now building a telecaster and I am wondering if the measurements would be the same since it is also a 25.5 scale. I have a joe barden vintage style bridge (3 brass saddles) to go on it. heres a shot of the body so you can see how its been drilled. I believe they call this the modern bridge route since the holes are four mounting screws in front of the string holes. The neck i have coming has not been drilled for mounting so i wanna make sure i get all the measurements proper as to not run into issues later. Thanks.[​IMG][​IMG]
  2. custom/59
    custom/59 Banned
    426
    Dec 16, 2012
    kentucky
    so no one is gonna chime in and answer this question?
  3. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Dec 19, 2011
    Merseyside UK
    Patience is a virtue.
    It's New Years and folk have other things going on. Give it a day or so for the experts to respond.
    My 5 cents are:
    Forget the nut to mounting holes measurement on the Strat, there is a lot of intonation adjustment available on the Tele bridge.
    The bridge mounting holes are predrilled so unless you fill and redrill the bridge placement is fixed. As this is through body you won't have a great deal of adjustment without opening out the through body holes.
    Wait for the neck, fit it and establish a center line which is where I am a bit worried as the wood strip between the two main body timbers which I would expect to be centered is not in the middle of the bridge fixing holes and through body string holes. This could be purely cosmetic but the neck/bridge alignment is critical.
    BTW this bridge drilling is vintage not modern. Modern is 3 or 5 hole.
    Like this
  5. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
    Go to Stewmac: http://www.stewmac.com/
    click on "bridges, tailpieces", click on "non-trem bridges", click on "Traditional bridges for Tele", scroll down to "Positioning the bridge" and click on "Fret position calculator".
    Enter number of frets, scale length and electric guitar. Click on "Calculate". Scroll dow to find the type of bridge you are using and it will show the corresponding distance from the nut to mounting screws.
  6. custom/59
    custom/59 Banned
    426
    Dec 16, 2012
    kentucky
    forgive the impatience wasnt thinking about it being new years thanks glen for the stewmac guide. I had looked at that but didnt scroll down far enough to see it had what i was looking for. The stripe not being centered i believe is primarily cosmetic. if you are looking at the bottom of the guitar you can see where the top slid slightly off center . Im going to guess during the glue stages. wont know for sure til neck is here and on the guitar and looking at the centerline. Looked it up on stewmac and or a vintage style bridge its 25.75. thats interesting. Thanks.
  7. Glen Smith
    Glen Smith RIP
    Aug 20, 2011
    Your measurement would be 25.75" +or- 0.030"
  8. custom/59
    custom/59 Banned
    426
    Dec 16, 2012
    kentucky
    lol thanks Glen we posted that around the same time.
