Major neck pickup dilemma!
Discussion in 'Just Pickups' started by Yonatan, May 24, 2019.
  1. Yonatan
    Yonatan Tele-Meister
    Israel
    The background is that I'm building my first Tele out of parts. My only other electric is an LP copy with humbuckers. I've been focusing on jazz lately, but not exclusively.
    Anyway, I'm finally at the point in the build where I have the neck and bridge installed and can play it. The plan was always for a set of Pribora Blues Classics. But the "problem" started because the body I purchased came routed to accept a full size neck humbucker, and I happen to have a Mean90 laying around that was meant for the LP copy but never used in the end.
    • The Pribora sounds amazing, it has bell like chime, great note definition, and strangely, to my ears almost some kind of natural chorusing/phasing that I can't really describe. Maybe this is just the normal vibe of a single coil Tele neck pickup? (Again, I don't have another Tele guitar.)
    • The Mean90 on the other hand has a fullness/richness (more bass/mids...) that the single coil doesn't have, while still retaining clarity, and I can always mix in the bridge pickup to get some single coil tones. But..it doesn't have that unique quality that I'm hearing in the single coil Pribora.
    I also have a couple of unused humbuckers, but they're currently not in the running.
    Thoughts?
    One reason that I need to decide is that It will affect how I cut out the opening in the pickguard..
  2. charlie chitlin
    Spring City, Pa
    No matter what you decide, you'll change your mind tomorrow.
    A better dilemma is to have a bunch of guitars with different voices, and try to figure out which one(s) to take to the gig.
  3. FerruleCat
    FerruleCat Tele-Holic
    Tulsa, OK
    I have just one Tele, and my conclusion was to keep it in standard pickup configuration. If I had another, I might consider other options. Everyone's tastes are different, though.
    gtroates and RadioFM74 like this.
  4. jackal
    jackal Tele-Afflicted Gold Supporter
    mojave desert
    Put the single coil in the neck position, P90 in the bridge. Would require routing and a different bridge, so it would be a pain, but sounds like a great combination to me.
  5. LazyBear
    LazyBear TDPRI Member
    New York
    You might want to focus on adjusting pickup height and new pots/caps first. A bit cheaper and might get you the sound you want.
    Solszewski1963 and nojazzhere like this.
  6. Rich_S
    Rich_S Friend of Leo's Gold Supporter
    Potsdam, NY
    One of the best things about having a Tele body routed for a neck humbucker is that you can swap pickups so easily, for the price of a new pickguard (and of course, the pickup.) My blue Tele has had: stock Tele neck, no neck pickup, full-sized Duncan '59 humbucker, Duncan SSL-1 Strat pickup, and now a Duncan SM-3 Firebird pickup. I have a gallon Ziploc bag in the shop full of extra Tele pickguards, so I can swap whenever I feel like it.
    No need to commit.
    Mincer likes this.
  7. RadioFM74
    RadioFM74 Tele-Afflicted
    Italy and Switzerland
    Only you can solve the dilemma, knowing it’s not difficult to take the other road should you so decide. I’m all for standard configuration personally.
  8. el cheapo
    el cheapo Tele-Afflicted
    Southcentral Pa
    Standard tele configuration with vintage wound pickups is the best sounding and most versatile IMHO.
  9. YoGeorge
    YoGeorge Tele-Afflicted
    Michigan
    You seem to be saying that the single coil sounds great, so set it up with the great sounding single coil and play it for a year. If you feel the need for a change down the road, change something. A number of jazz guys play(ed) stock teles and got *their* sound from them.
  10. warrent
    warrent Friend of Leo's
    toronto
    Buy a couple of cheap pickguards from amazon Musiclily ones are under $10 each. One for a tele pickup and one for the mean 90 and try each pickup for awhile to see which works best for you.
    SecretSquirrel likes this.
  11. eclecticsynergy
    eclecticsynergy Tele-Afflicted
    Albany NY
    I'd say if you love the way the Pribora sounds, use it. You can always change your mind later.
  12. SecretSquirrel
    SecretSquirrel Friend of Leo's Ad Free Member
    PNW USA
    I would try them both, and in combinations, wired up without the pickguard; they can be held in place with mounting putty. It can be awkward to test if the guts are hanging out, but you'll know you chose the right pickups. Best to make a recording of each to compare. The P90 is a single coil but I wonder if it would be the better one for jazz.
  13. Yonatan
    Israel
    For testing, I've been holding the different neck pickups in place with a bunch of masking tape beneath them (works o.k.).
    The idea of making a recording of each one is interesting...
    Anyway, thanks all for chiming in. I've thought about just making two pickguards, the problem is that this is a hybrid thinline body (f hole but vertical control plate), and I don't like any of the ready made pickguard shapes for this configuration, so I'm going to be modifying a regular Tele pickguard. I suppose I can do two, one for a SC and one for a full size HB.
    But then how do I avoid having to take off the bridge when I want to change neck pickups? (The neck pickup wires connect to the control plate via the bridge route.)
    Also, I'm surprised that nobody suggested adding another pickup route behind the neck pickup. Or is that madness setting in?
  14. gkterry
    gkterry Tele-Meister
    Paris, IL
    If you change only the neck pickup, it might not be necessary to remove the bridge. Just un-solder the neck pickup wires on the control plate. You can then pull one of the newly un-soldered wires out and the other one can be taped to a super long single small wire and pulled back through the route from the control plate to the neck pickup cavity. Be careful not to pull the wire completely out of the control plate cavity. Then tape the two wires on the new pickup to the long wire end in the neck pickup cavity and (maybe) use it to pull the wires on the new pickup through the bridge cavity to the control plate. Otherwise the bridge plate will need to be removed. If you plan to change the bridge pickup, you will need to remove the bridge too. I would not go the 3 pickup route yet, especially for a jazz guitar. That middle pickup would be 3 or 4 Teles down the road. :)
  15. Yonatan
    Israel
    Thanks, cool idea, like how electricians snake wires through electric conduits!
    By the way, I wrote in my original post that I had a couple of humbuckers but they were out of the running (as not the sound I'm looking for.) Well, I just discovered that, when split, they sound amazing :)
