Low watt pentode powered amp?
Discussion in 'Shock Brother's DIY Amps' started by JohnnyCrash, May 13, 2019.
  1. JohnnyCrash
    JohnnyCrash Doctor of Teleocity
    Fullerton, CA
    I have some left over parts and I like to challenge myself.
    I’m looking to build a super tiny all tube amp (except rectification) using a capacitor doghouse for a chassis. I built a Firefly once and wasn’t impressed with the triode output stage.
    Any circuit suggestions (and associated schematics) for an amp that uses a single 12AX7 pre and a low watt pentode output?
    I’m aiming for something lower powered than a Champ if possible (I already have two Champs - a tweed I built and a ‘78 VibroChamp :)
  2. scottser
    scottser Tele-Afflicted
    dublin
    Sort of like the zvex nano?
  3. Nickfl
    Nickfl Tele-Afflicted
    Take a look at 6BM8 / ECL82 tubes. They are a pentode and a triode in the same envelope, so they could fill your need with one tube socket. I've used them as the inverter and power section in a push-pull amp and was very pleased with them and I'd definitely use them again. They might be a little higher power than your thinking of though, I believe the pentode is pretty close to being equivalent in output to an el84.
    Snfoilhat likes this.
  4. Finck
    Finck Tele-Afflicted
    São Paulo - Brazil
    There is a fantastic circuit designed by a Brazilian guy that meet your requirements.
    Here's the link (don't worry about instructions in Portuguese, schematics are self explanatory, and I can help you if you need):
    http://www.altanatubes.com.br/downloads/HB-1 V1.1.pdf
    If you really prefer 12AX7 in preamp, look at the schematics below:
    http://www.handmades.com.br/forum/index.php?topic=9592.0
    What's the idea: the guy has designed a circuit that uses tubes whose filaments draw similar current, so it was possible to connect them in series. That allows the use of only a cheap 30+30V tranny (60V with center tap) to feed all the filaments AND B+ (through a voltage multiplier).
    As OT, any SE unit with 1,7kohms (for 25L6 tube) or 2,5kohms (for 25C5 tube) primary impedance will work.
    The 25L6 is a tube that has the same characteristics of a 6V6, only difference is that its filament uses 25V. 25C5 is a bit different, but final result is almost the same. Both are very cheap and easy to find.
    All circuits were tested and work very well. The project with 12AX7 is very crunchy, with a voice that could be described as a mix of Marshall and Vox. Output power is about 2W with any of the power tubes.
    Some guys have built the circuit using a Hammond 1590BB enclosure as chassis, so I guess the caps doghouse could be used with no issues.
  5. TequilaCaster
    TequilaCaster Tele-Holic
    At home, but sometimes out and about.
    What is your definition of low power?
    An EL84 / 6BQ5 pentode sounds great in an AC4 or an AX84.com P1 style build.
  6. Snfoilhat
    Snfoilhat Tele-Holic
    Oakland, CA
    6DL5/EL95 - it's like half of a 6BQ5/EL84, made for car radios. Pentode, 7-pin socket, very low heater current, 6W plate dissipation. My most recent amp used this and I think it came out well.
  7. printer2
  8. dkevin
    dkevin Tele-Meister
    Seattle, WA
    Too big?
  9. printer2
    Actually thought of it, no need for the first mosfet, enough gain for a 6AK6 with two triodes. I put it in because the values of the tone stack works with a lower supply impedance. A Tweed volume and tone control would work well. The splitter mosfet could be an IRF820.
