Join TDPRI Today
Low Pass Capacitors
Discussion in 'Tele-Technical' started by tbaumgartner, May 15, 2008.
  1. tbaumgartner
    tbaumgartner TDPRI Member
    9
    May 15, 2008
    Nashville
    I have thoroughly confused myself on low pass capacitors.
    One of my tele's has no tone knob. On the volume pot there is a tiny little low pass capacitor about the size of this dude :rolleyes: . I don't know what technical size it is. I guy at a local store sent me a 1mf capacitor, but it's huge and doesn't look right. Another dude at a store sent me a new volume pot and said the capacitor is included, but it doesn't look right.
    What I am trying to do is trick out a second tele the same way and am trying to find the right components to do so.
    I am thinking I need a .05 or .047 capacitor, which I can have soldered to the volume pot in the same fashion as the tele I am copying.
    Anybody out there that can help straighten out my thinking?
    Thanks
  2. KokoTele
    KokoTele <img src="http://www.tdpri.com/gifs/vendor.png" /> Vendor Member
    albany, ny [not chicago]
    It's actually a high-pass cap, which helps keep your volume knob from sucking out all the highs as you turn it down.
    The value there is probably something like .001 uf (don't forget the units!).
  3. bradpdx
    bradpdx Friend of Leo's
    Jul 16, 2006
    Portland, OR
    Caps themselves are neither low-pass nor high-pass; that is a function of the circuit they are in, that's all.
    eryque is right, a value of about 0.001mfd will do.
  5. 6x47
    6x47 Tele-Holic
    804
    Mar 28, 2007
    Northern ON
    I found it easier to use that mod credited to Fezz. Instead of hooking the tone pot to the outside lug of the the volume pot where the wire from the switch goes, move tone pot wire to the raker connect, volume output.
