Loose socket pins
Discussion in 'Amp Tech Center' started by tele_savales, Jun 4, 2019.
  1. tele_savales
    tele_savales Tele-Meister
    Brooklyn, Joey!
    I've been going thru the SF Vibro champ I got while waiting for parts. Glued down some loose tolex, cleaned the pots and jacks, and re-tensioned the pin sockets which were super loose.
    I found out last night that some of the solder tags on the wiring side of the sockets were a bit wiggly as well, even though the re-tensioning worked in getting the rectifier and power tube to stay in nice and tight. Is there an easy fix for this? They don't really seem to cause any noise when I poked around with a chopstick with the amp on, so maybe do nothing?
    Thanks
  2. charlie chitlin
    Spring City, Pa
    Those little sockets float in their seats.
    They're wobbly.
    slider313 and BobbyZ like this.
  3. mherrcat
    mherrcat Tele-Holic
    California
    Replace the tube sockets.
  4. thechad
    thechad Tele-Meister
    Kamloops
    Wiggly with the tubes in or out? They should be tight with the tube in but are generally loose without.
  5. tele_savales
    Brooklyn, Joey!
    Tubes in.
  6. thechad
    Kamloops
    I’d either live with it and hope it doesn’t cause any issues. Otherwise I’d just replace the tube socket. They are cheap. But if you aren’t comfortable soldering the new one in I’d just let’er buck as is.
  7. mherrcat
    mherrcat Tele-Holic
    California
    If you have, or can add, tube retainers, the original sockets shouldn't be a problem. But you will be forever having to re-tension them.
    This is why I replaced the tube sockets on my Twin Reverb.
    Your profile says you are in Brooklyn; you could have Blackie Pagano replace the sockets if you didn't want to do it yourself:
    https://www.blackiepagano.com
  8. corliss1
    Lansing, MI
    The floppiness of the pins in the sockets doesn't matter - they all seem to give a little.
    If the pins are gripping the tube properly after you retensioned them, carry on and enjoy. If it bothers you, replace the sockets.
    D'tar likes this.
  9. tele_savales
    Brooklyn, Joey!
    Yeah, when the caps come in and I get that done I'll see if it's making any noise because of it. I kinda wish I had noticed it beforehand. Thanks!
  10. charlie chitlin
    Spring City, Pa
    If your tubes are in the bottom of your amp when you get to the gig, they're too loose.
    Some mid 70s Fender tube socket connectors are made of an alloy of steel and cheese and they lose their springyness, and can't be re-tensioned.
  11. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    As long as the tube's pins are being gripped tight you're ok. With a tube in if you wiggle it around while watching the wire side the terminals gripping the tube should move right along as you move the tube. The only time I replace a socket is when the metal parts loose their "springyness". If you only have one bad one in a socket, there's often a spare or two in the rectifier socket.
    flyswatter and charlie chitlin like this.
  12. vanr
    vanr Tele-Afflicted
    AZ
    I know at least one amp tech who says if your tube sockets need re-tensiong then they need replacing.
    flyswatter likes this.
