Join TDPRI Today
Looking for advice on filling a trem cavity
Discussion in 'Tele Home Depot' started by soggybag, Dec 2, 2012.
  1. soggybag
    soggybag Tele-Meister
    171
    Oct 20, 2012
    san francisco
    This guitar is a start copy with some sort of terrible no name locking type tremolo. The tremolo doesn't work, and makes the guitar no playable. I'd like to fill the cavity and install a fixed bridge.
    I've never made this type of repair. My thoughts were to either route the cavity into a rectangle, or use hand tools, maybe chisel and sand paper to clean up the cavity.
    Here's a few pictures:
  2. soggybag
    171
    Oct 20, 2012
    san francisco
    In case there's any interest, here's a couple close ups the tremolo. This some weird off brand knock off of a Khaler/Floyd Rose. If it were functioning correctly I don't think it would work very well. As is it doesn't function at all. There two springs connected to the underside of the bridge, these are anchored to a tab of metal at the front coming off the frame. The metal was too soft and over time was pulled toward the springs. This leaves the bridge too far forward all the time, as if you were holding the bar all the time.
  3. Bentley
    Bentley Friend of Leo's
    Jul 25, 2012
    Kelowna B.C, Canada
    Route a mm deeper, and make it into a rectangle.
  5. guitarbuilder
    guitarbuilder Doctor of Teleocity Ad Free Member
    Mar 30, 2003
    Those trems were common on cheaper imports back in the 80's. I have de kahlerized a few bodies over the years. I'd first make a template to rout out a square or rectangle around the trem rout. Using a template bit and the template, I'd clean it out. Then I'd make a plug out of similar wood with grain running in the same direction as the body, that was a hair taller than the rout itself, and I'd glue it in with yellow glue. The only difficult part is sanding the outside radii of the plug by hand to perfectly match the cavity inside corners. After the glue dries, I'd use a small plane and scraper to level the plug down. A good looking decal covered the routs in a many cases. In some cases, I actually routed right into the pickup cavity to have only 3 existing plug glue lines instead of 4.
  6. soggybag
    171
    Oct 20, 2012
    san francisco
    Finally getting back to this project. I routed the cavity, which was easier than I expected. I made a template, used some double sided tape to stick it to the body, and routed with a 1/2" bit.
    I cut a piece of alder a little larger than the cavity, and spent the afternoon slowly sanding it to fit. It's a tight fit. The gap is hair thin. I can snug the plug into the cavity with little pressure.
    Any suggestions on glue? I could use a CA type glue or a tight bond type glue. I feel the wood glue would be a good choice and fill the gaps, but the fit is so tight it might make it hard to get the plug in after spread glue on the edges. I thought about watering the glue down some?
  7. Bentley
    Jul 25, 2012
    Kelowna B.C, Canada
    nononono, just titebond. Studies show it works fine. A tight fit will still work! just A)use your finger or something to put a thin layer of glue on the block, and glue on the sides and bottom of the cavity. It will work great, trust me! Great repair, I may have to do that one day!
  8. guitarbuilder
    Mar 30, 2003
    Yellow is all you need. Then you can use some sort of filler or gap filling superglue on the gap that remains. Then use a peel and stick pin up or STP or Bardahl sticker on top of it if you prefer.
  9. adjason
    adjason Friend of Leo's
    Jan 9, 2010
    virginia
    If its super tight then just sand a bit off the edges before you stick it in. Wood glue is what you want
  10. crazydave911
    Feb 23, 2010
    East Tennessee
    I would use Titebond original................but Titebond does make a white glue that dries clear. Do not use CA or a Gorilla brand glue ;)
  11. mlp-mx6
    mlp-mx6 Tele-Holic
    707
    Jan 20, 2008
    Atlanta
    Listen to guitarbuilder.
  12. whodatpat
    whodatpat Friend of Leo's
    Jul 21, 2007
    College Park MD
    No, listen to Crazydave. :p
  13. crazydave911
    Feb 23, 2010
    East Tennessee
    As if it isn't the same thing :lol:
