Long wires?
Discussion in 'Tele-Technical' started by guitarmoron, Apr 15, 2019 at 8:01 PM.
  1. guitarmoron
    guitarmoron TDPRI Member
    arkansas
    is there any harm/negative issue to using longer than normal electrical wires?
    Thanks
  2. RodeoTex
    Nueces Strip
    Probably not, unless they start acting like an antenna or something.
    I never cut off the pickup wires anyway.
    guitarmoron likes this.
  3. guitarmoron
    arkansas
    I read somewhere that they muffled the tone, I didn’t see how that was possible
  4. jimilee
    jimilee Tele-Holic Silver Supporter
    Chattanooga
    In theory, the longer the cable, the more signal loss. In this instance, it’s not a thing. You’ll be fine.
  5. Shuster
    Shuster Friend of Leo's Silver Supporter
    Forth Planet from the Sun
    Depends, the longer they get, the heavier the gauge. Unless we are talking just inches;)
    guitarmoron and 8barlouie like this.
  6. 8barlouie
    8barlouie Friend of Leo's Gold Supporter
    Seekonk, MA
    I agree. Length of wire affects signal loss. I don’t think a few inches will make any appreciable difference in tone. Besides, there are so many more interesting irrelevant things to obsess about.
    Mase, 2 Headed Goat, jimilee and 2 others like this.
  7. Hobs
    Hobs Tele-Meister
    Nashville, TN
    If you're talking about the AC power wires, consider that there are already probably many miles of wire between your amp and the place that power was generated.
  8. dconeill
    dconeill Tele-Afflicted
    arlington, virginia, usa
    From this, I infer that the "electrical wires" you referred to in your first post mean "guitar signal cable".
    Cables have capacitance, the amount per foot depending on what they're made from and how they're made. The total capacitance increases with length of the cable. This capacitance acts as a low-pass filter, decreasing the amount of high frequencies in the signal by the time it gets to the amp.
    nojazzhere and guitarmoron like this.
  9. archetype
    archetype Fiend of Leo's Silver Supporter
    Williamsville NY
    Please define. All wires are electrical wires. "electrical wires" means what? What are they being used for?
  10. Ahryn
    Ahryn TDPRI Member
    Victoria, Canada
    now I'm wondering how long they would have to be to make a difference. like imagine the size of guitar to make a difference from the pickup to the control cavity.
  11. MrCairo46
    MrCairo46 Friend of Leo's
    Baltimore, Maryland Hon!
    Thank you Arch for asking for clarification.
  12. Steveinthesticks
    Steveinthesticks Tele-Meister
    Austin
    If you are super concerned with signal loss on long cables add an on board buffer. Jerry Garcia's guitars had an interesting buffered in& out wiring system
  13. guitarmoron
    arkansas
    Sorry guys, i am the GUITARMORON , i meant the wires inside the guitar, to the pots pups etc.
    I just got home from the hospital and i was a little out of sorts LOL
  14. sjtalon
    sjtalon Doctor of Teleocity
    Upper Peninsula of Michigan
    Run them from point a to point b....................if you go a tad long, o well.
    Electricity travels about the same as light (186,000 mph w/o any attenuation)) so it won't really know the trip is a little longer if the wires are overkill length wise.
    Why do you ask ??
    Here's a good explanation of distance:
  15. guitarmoron
    arkansas
    I am horrible solderer, LOL the extra wire would be for my mistakes LOL
  16. cincyguitarplay
    cincyguitarplay Tele-Meister
    ohio
    Guitarmoron....I feel like your name most of the time..o_O
  17. archetype
    Williamsville NY
    Just route the wires neatly and if there is an extra inch or two, here and there, it makes no practical difference. If you have an extra foot of wire coiled up under the pickguard, that could theoretically cause a problem. Since you're not going to do that it's a waste of brain power to ponder it.
    Practice soldering on something other than your guitar, then wire the guitar, and play on.
  18. guitarmoron
    arkansas
    thanks for the help
  19. beninma
    beninma Tele-Afflicted Silver Supporter
    Massachusetts
    Longer wires make a big difference in the background noise level of the guitar as they can act as antennas.
    I disagree about little bits of extra wire inside the guitar. You can be pretty sloppy in wiring up the pickups to the switches & pots and pay for it.
    When I rewired my Tele I would estimate the reduction in wire inside the guitar was probably measured in feet. My MIM Fender was VERY sloppy. I didn't trim the pickup leads but I used much much much shorter lengths of wire to do the switching, pots, cavity grounds, jack, etc..
    Premier guitar has/had some wiring articles in the past few issues where they talk about this. They mention Strats as more sensitive than Teles, Strats can have a lot of wire inside them.
    As for instrument cables.. I haven't done so but I think in some kind of blind test where I got to use my guitar + amp I could differentiate:
    - 10ft cable from 20ft cable (I can hear the missing treble as the cable length goes up)
    - Presence or absence of a single true-bypass pedal that is turned off. Assuming a test of a) Guitar -> Cable -> Amp b) Guitar -> Cable -> Pedal -> Cable -> Amp.
    Not sure how we ever got to the whole religion about True Bypass being the holy grail of pedals. Maybe if your guitar is excessively bright & you never touch the tone knob that's fine but for me the TB pedal can easily sound like a blanket thrown over the amp.
  20. Telecentric
    Telecentric Tele-Meister
    Boulder Creek, Ca
    It's actually 186,000 mi/sec
    guitarmoron and nojazzhere like this.
