Locking tuners for lefty tele
Discussion in 'Tele-Technical' started by Mazian, Sep 6, 2018.
  1. Mazian
    Mazian TDPRI Member
    22
    Aug 24, 2018
    Germany
    Hi everyone,
    I'm putting together a build and I have a question i can't figure out on my own so far.
    Since lefty parts are a PITA to get sometimes, my options are a little limited.
    I need tuners for a lefty tele neck, genuine fender replacement neck, MIM.
    I wanted to go with locking tuners, since I need to buy aftermarket anyway, no fender leftys to order I've seen.
    The Schaller F series would be a drop in for the pre-drilled holes.
    They only sell a staggered set for right handed orientation, which consists of the 21,5 post height tuners and three 19s.
    The way I see it, I would need 6 "right" orientation tuners, which they only sell as single tuners.
    The catch is, as single the tallest post to order is the 19.
    Now I know these fit and are tall enough, since I ordered the 6l inline set by accident ( generous return policy).
    They are tall enough for locking use, could also string them normally, though that would be on the short side.
    Can I do this, or will I run into problems with 6 "shorter" tuners?
    I can provide pictures of the wrong tuners put in if needed, to see the post height.
    Next time I'm slapping a righty neck on and go reverse Hendrix style...
  2. Mazian
    Mazian TDPRI Member
    22
    Aug 24, 2018
    Germany
    Issue resolved itself.
    Shaller has great service, they'll send me a correct staggered set for a lefty neck, even though it's not on their website. No extra charge.
  3. Ira7
    Ira7 Poster Extraordinaire
    Jan 8, 2008
    Coral Springs, FL
    As a user, I can assure you that aside from easier string changes, locking are no big deal.
    Wally likes this.
  4. Mazian
    Mazian TDPRI Member
    22
    Aug 24, 2018
    Germany
    Yeah, I figured, but since I'd have to buy some non-fender tuners anyway and the price difference was minimal, at least for leftys, I thought I might as well get them.
  5. Ira7
    Jan 8, 2008
    Coral Springs, FL
    However, if you're a crazy string changer like me...every two months (even less) with just even moderate play...
    You will ADORE those easy string changes.
  6. Journeyman22
    Journeyman22 Tele-Meister
    414
    Dec 11, 2014
    Piute County, Utah
    I was asked to put together a left handed SX Furrian, work horse, guitar. I do a complete up-grade on parts with a good set up. Sometimes I will level, re-crown/polish, neck frets.
    Anyway, finding locking tuning machines was a bit of a challenge. I settled on trying "Gotoh" penny lockers (what I named them). A little different from the locking tuners I have used in the past. Nothing ventured nothing gained. I will find out how good they are in a while. So far so good.
  7. Mazian
    Mazian TDPRI Member
    22
    Aug 24, 2018
    Germany
    Looking good!
    I could've gone another way, but the fender neck was already drilled for their pin tuners and I didn't necessarily want to add more drilling to my first ever partscaster/self-finished body, enough potential for disaster as is.
    Schaller was the only locking drop-in tuners I found.
    My "special" set arrived today, still pretty impressed with their customer service.
  8. Journeyman22
    414
    Dec 11, 2014
    Piute County, Utah
    This is a guess on how to work them.From what I understand, You first line/index the string hole inline with the strings. Run a the string through the string hole, then take a coin (I am using a penny so far). Insert coin in the top slot. the coin stops the left handed threaded, locking cap from spinning, while cranking the tuner. Now use a hand or electric, machine tuners, speed crank, till the lock stops turning. Check to make sure the string is locked. Done.
