Line Out Clarification
Discussion in 'Shock Brother's DIY Amps' started by Fatknuckle, Jan 23, 2013.
  1. Fatknuckle
    Fatknuckle Tele-Holic
    981
    Jun 28, 2012
    Gainesville FL
    For the Ceriatone Lightning as an example, there is a Line Out jack attached to the 8-ohm lead of the impedance switch. With the addition of 3.3K and 22K resistors to the jack, it can be supposedly be used for recording, output to a PA, yadayadayada...
    My quesiton would be, does this stilll require a speaker load plugged into the output jacks, or can the line out serve as the load (without using a speaker) for such purposes without resulting in a fiery amp death?:?:
  2. Badside
    Badside Tele-Meister
    No. You still need a speaker connected. The line-out is too high an impedance, almost an open circuit as far as the OT sees it.
    You could run the speaker out into a resistive load if you want perfect silence. I've done it with smaller amps (record the line out, use a plug-in for cab sim), but you lose the interaction between the amp and the speakers... unless you can build or buy a reactive load.
    But the short answer is no.
  3. Fatknuckle
    981
    Jun 28, 2012
    Gainesville FL
    Short and to the point works, thanks!
