Let's make a neck!
Discussion in 'Tele Home Depot' started by guitarbuilder, Aug 2, 2017.
  1. Chordophonic
    Chordophonic Tele-Meister
    232
    Oct 4, 2013
    Isle of Wight UK
    Awesome tutorial -thank you!
    guitarbuilder likes this.
  2. Tezuka27
    Tezuka27 Tele-Meister
    422
    Apr 11, 2011
    Eastern Iowa
    Thanks, Marty! This is really helpful. Maybe I should be, but I'm no longer afraid of tackling a neck. I'm kind of looking forward to it. Would there be any disadvantage to doing a couple of practice necks out of pine before moving up to maple?
  3. papaschtroumpf
    papaschtroumpf Tele-Holic
    510
    Nov 24, 2015
    Colorado
    I have tool called "sureform" it's a frame with a replaceable "mesh blade". I think it should work as a poor man's farrier rasp, it can take off wood in a hurry.
  4. guitarbuilder
    Mar 30, 2003
    Those are new drawings... It was easier to make new ones than to try and find the old ones....
  5. guitarbuilder
    Mar 30, 2003
    No, it makes sense to practice but be aware that pine will probably be easier to work than a denser hardwood.
  6. guitarbuilder
    Mar 30, 2003
    If the sureform tool stays together, it'll work. My cutter/grater/ blade part always fell off when I tried it a few times.
  7. papaschtroumpf
    510
    Nov 24, 2015
    Colorado
    Back to the dots, it looks like the dots are standing slightly proud of the surface of the fretboard. I suppose with the curvature it the fret board the will by definition. I assume you will sand them during the finish stage?
  8. guitarbuilder
    Mar 30, 2003
    They are level now, as I used a file and scraper on them, but were proud when I glued them in. I've tried to cut it too close a few times and the dots were under the plane of the fretboard. Next step is to sand the fretboard down some with the radius beam.
  9. nosmo
    nosmo Friend of Leo's
    Jan 31, 2012
    Lake Jackson, TX
    Great thread Marty. This reminds me of the old threads around here. Solid info & techniques.
  10. guitarbuilder
    Mar 30, 2003
    Sanding....ugh.... anyway. I start with the belt sander sanding block on the neck shaft. That is 50 grit. It is pretty aggressive but does the job. Then I go over the neck with 80 grit. I use ROSS spindles in the transitions and inside curves. I attach some 80 grit sticky back abrasive paper on a flat block and block sand the neck parts. I like to hold the neck vertical and while rotating it with my left hand, I sand up and down with my right. Then I flip it up and down and do the other end. I keep doing this until it's done.
    Barncaster, mkster and John Nicholas like this.
  11. guitarbuilder
    Mar 30, 2003
    I put some sticky back 80 grit on the radius beam. I can't say enough good things about these aluminum radius beams. They are really worth it if you can afford them.
    Barncaster, moosie and John Nicholas like this.
  12. guitarbuilder
    Mar 30, 2003
    Then I take a pencil and make some hash marks on the fretboard surface. This lets me know where the high spots are. The more accurate the fretboard radius jig is the less work you'll have to do here. 80 grit reduces the time it takes to do this task too.
    Barncaster and John Nicholas like this.
  13. guitarbuilder
    Mar 30, 2003
    I mount the radius beam to the workbench with a couple small clamps and move the neck on top of it. I think I like this better than moving the beam on the neck. After a couple of minutes of back and forth.
    Barncaster, richa and John Nicholas like this.
  14. guitarbuilder
    Mar 30, 2003
    After a couple more minutes. I like to hit the fretboard edge with a couple of strokes to ease the edge. It makes it comfy and you don't draw blood there from a razor sharp edge.
  15. guitarbuilder
    Mar 30, 2003
    I'm done with 80 grit on the shaft, fretboard surface, heel, and peghead. It feels really nice now.
    John Nicholas likes this.
  16. cs51762
    cs51762 TDPRI Member
    14
    Jul 11, 2016
    Western North Carolina
    What are the angles of these two secondary facet lines? Thanks.
    Mike Fields
  17. guitarbuilder
    Mar 30, 2003
    Here are the angles. The lines are just tangent to the curve and can vary a little. I just drew and rotated to try and trim off equal amounts of the points of the primary facets. The later sanding and scraping will equalize them.
  18. pagagigi
    pagagigi TDPRI Member
    20
    Aug 13, 2017
    Italy
  19. moosie
    Jul 18, 2010
    Western Connecticut
    Fantastic tutorial. Thanks!
    Details like how you hold the neck while sanding... that stuff is so good. Different for everyone perhaps, but still...
  20. brownale99
    brownale99 TDPRI Member
    47
    Feb 18, 2017
    Newcastle, UK
    Great tutorial, thanks. Just in time for my first neck carve
