Let's make a neck!
Discussion in 'Tele Home Depot' started by guitarbuilder, Aug 2, 2017.
  1. Daniel94
    Daniel94 Tele-Meister
    144
    Oct 31, 2016
    Odessa, MO
    It's motor_city_tele's builds that you're thinkin of.
    Here's the cherry one: http://www.tdpri.com/threads/motor_...nge-trunk-o-cherry.417037/page-4#post-5199286
    And here's the American flag one: http://www.tdpri.com/threads/motor_...d-challenge-thread.263818/page-4#post-3221342
    He uses Apoxie Sculpt for the bindings and fret markers.
    papaschtroumpf likes this.
  2. guitarbuilder
    Mar 30, 2003
    My drawing program is putting the dimensions out to 4 places. On my machinist's scale, I'm finding a simpler part of an inch that's close to that for instance. .3831 will round down to . 375 or 3/8". The thickness of the pencil line will be enough to see that you want to be close but not anal about it.
    First the two perpendicular lines at the fret positions and then I connect them across the surface.
    Mat UK likes this.
  3. guitarbuilder
    Mar 30, 2003
    Then I find the mid point of that line and draw in the centerline of the neck on that surface.
  4. guitarbuilder
    Mar 30, 2003
    At those locations I measure over the simplified dimensions my drawing shows and put some pencil marks there. cs4.jpg
  5. guitarbuilder
    Mar 30, 2003
    I connect the dots with straight lines. These lines will be the edges of the 45 degree surface called the primary facet.
  6. guitarbuilder
    Mar 30, 2003
    Finally lines for this step are to take a curve and make an end to the facet surface. I used the bottom of a plastic wire spool. Now I will gather up a couple of rasps and files and start the primary facet carves. You can use whatever tools that you like to remove the wood. I like a Farrier's rasp and a half round file for this step. Some folks do it with a spokeshave. Some use a grinder. Some use a surform tool. Probably you could use a draw knife, or belt sander if you felt lucky....:). I like the control of the rasp and file.
  7. papaschtroumpf
    papaschtroumpf Tele-Holic
    530
    Nov 24, 2015
    Colorado
    Very clear, thank you!
    guitarbuilder likes this.
  8. guitarbuilder
    Mar 30, 2003
  9. guitarbuilder
    Mar 30, 2003
  10. guitarbuilder
    Mar 30, 2003
    Rasping and a little filing.... The primary facets are done for now.
  11. moosie
    Jul 18, 2010
    Western Connecticut
    Not to detract from this build thread, or pull him in here, but the fingerboard on TenaciousP's ongoing '59 Les Paul build uses vintage celluloid piano keys, cut into strips, and the butt joints melted together with acetone.
    Anything, indeed.
  12. richa
    richa Tele-Afflicted Ad Free Member
    Apr 23, 2016
    Dang - and here I was using Bondo when I needed extra mojo and all along it was supposed to be Duco.
    Barncaster and guitarbuilder like this.
  13. Captain Nutslot
    Captain Nutslot Friend of Leo's
    May 3, 2012
    Rochester, NY
    i thought u were talking about one of these for a minute there.
  14. guitarbuilder
    Mar 30, 2003
    Secondary Facets. This goes a lot faster because most of the wood has already been removed by the primary facet removal process. On the drawing I want to put a line that knocks off the points of the facets creating more facets. So we are turning a 5 sided shape into a 9 sided shape, which is approaching a semi circle. You can see the smaller dimensions of those surfaces and where they come from from the edges of the primary facets and glue line.
    nickhofen, awasson and John Nicholas like this.
  15. guitarbuilder
    Mar 30, 2003
    Then it is a matter of putting some pencil lines to the wood in those locations.
  16. guitarbuilder
    Mar 30, 2003
    Then you take a rasp or file and file off the wood until you have just the lines left between them. This goes pretty fast. I used the file portion of my farrier's rasp for the edge near the fretboard because I didn't want any chunks coming out there.
    Tezuka27 likes this.
  17. guitarbuilder
    Mar 30, 2003
    Before you know it that is done and you can work on the transitions.
  18. guitarbuilder
    Mar 30, 2003
    Then you use a scraper, sanding block, and files to refine it all and remove any low spots. This feels pretty good right now, but there still are a couple places that need attention.
    That's pretty much how this part is done.
    I like to sand back and forth along the with the belt sanding block. It fits in there nicely and is a coarse abrasive. "Shoe shine sanding style" puts scratches in the wood, and I'm trying to take them out, so I avoid that method.
    Also, remember you have to find out the methods and tools that work for you and what you are comfortable with. This is a hand made neck and there are bound to be some irregularities in it. Things like that used to be celebrated in woodworking.
    At some point in the carving process you need to stop and move on with things. I think it is pretty satisfying to do it by hand and obviously you don't need much in the way of jigs and templates.
  19. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Oct 24, 2009
    Long Island NY
    Nice looking transitions Marty
  20. John Nicholas
    John Nicholas Tele-Afflicted
    Jun 26, 2014
    Poughkeepsie, NY
    I love the addition of photos of each step along with the amazing drawings from your original facet tutorial.
    Thank you so much for sharing this!
