Learning Curve
Discussion in 'Tele Home Depot' started by sosay, Aug 19, 2016.
  1. guitarbuilder
    I would buy the one or two bits you really need made from a decent manufacturer. You get what you pay for with stuff like that.
  2. sosay
    sosay Tele-Afflicted
    IRELAND
    haha i noticed that after,i was lying down and sleepy
  3. sosay
    IRELAND
    ok cheers,
  4. sosay
    IRELAND
    i'm gona come to a halt soon if i don't find my router and falstener bits,i got charged 30 euro from dhl when i ordered my rod, dirty robbing hooligans,just cut the fret blank to rough size to get a good measure where to start my truss rod rout,
  5. sosay
    IRELAND
    yeh i do want to do this,i'll have another look cheers
  6. sosay
    IRELAND
    The round over,i believe that fender used 1/8" round over bit in the 50's and 1/4" or 3/16 bit in the 60's? is this true, i'm thinking of using a 1/4".
  7. NotAnotherHobby
    NotAnotherHobby Tele-Afflicted
    Da' Magic Mittin'
    I have a set of Ryobi forstner bits I got at Home Depot. I use then for everything and have no complaints.
    sosay likes this.
  8. sosay
    IRELAND
    and what do you use for the round over?
  9. NotAnotherHobby
    Da' Magic Mittin'
    I bought a 1/8" roundover bit on Amazon.com. Amana I believe.
    I also have a few other round-overs that I've accumulated from router bit sets that relatives have me over the years. But I prefer the 1/8". I like the sharper edges. Looks cleaner to me.
  10. sosay
    IRELAND
    ok cheers,i will have a look online
  11. Mat UK
    Mat UK Tele-Afflicted Silver Supporter
    London, UK
    Hey Sosay,
    I've bought my router and forstner bits from these two places:
    Axminister tools
    http://www.axminster.co.uk/accessories/power-tool-accessories/routing/router-cutters
    and
    Wealden Tools
    http://www.wealdentool.com/
    I bought this round over bit http://www.axminster.co.uk/axcaliber-ovolo-roundover-cutters-ax807115
    Both companies are of solid quality - Wealden is particularly good for rarer sizes/cut profiles.
    Delivery's not too bad to Ireland £3-4
    Also, if I were you - because I almost did the same thing, I would hold off from buying a cheap drill press and wait to get something a bit more robust/larger. You'll need a certain size throat to drill the ferule's (which is the main thing I wanted the accuracy for), I don't think the press you linked to is deep enough.
    And I bought a cheap set of Forstner bits too and junked them after one use - not worth it.
    Like Guitarbuilder said, buy specific sizes as and when you need them, sets are only economical if they are of good quality and you use all of them...
    sosay likes this.
  12. sosay
    IRELAND
    ok thanks buddy,
  13. sosay
    IRELAND
    how do you get radius beam scratches of pearloid inlays?? some are fine,thinking water and very fine sand paper then just cloth?
  14. budgetbuild
    budgetbuild Tele-Meister
    virginia
    Just work through the grits. What grit did you use to radius the board?
  15. sosay
    IRELAND
    it was a medium grit,the toughest one i had,i will try the milder one and see
  16. guitarbuilder
    The finer you go, the smaller the scratches you sand into the material. That's how they work...:)
  17. sosay
    IRELAND
  18. sosay
    IRELAND
  19. sosay
    IRELAND
    does anyone know what timber this is?thanks
  20. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    Walnut? Not sure..
