Join TDPRI Today
Learn me about wet-sanding a tru-oil finish...
Discussion in 'Tele Home Depot' started by Jim Beam, Feb 7, 2013.
  1. Jim Beam
    Jim Beam Tele-Meister
    196
    Sep 25, 2012
    New Mexico
    I know, I know, take it to Finely Finished. Frankly, there's just too much contradicting info there in all the past threads I've dug up. I'd like to hear what the frequent fliers here have to say about this.
    I've got about 10 coats of tru oil on my first build. The padouk top is starting to look pretty good, thick and glossy, although the open grain pores are still mostly open. Not too worried about that. That mahogany back needs a lot more coats tho.
    So at some point am I supposed to wet sand the finish? To make it, I don't know, flatter or something? What grits would I work through? Do I use water or mineral spirits to lubricate? Advice on technique here would be most appreciated. Lotso-lube? Or not a lot? With the grain? Or in circles?
    I presume that, after wet-sanding, I should put another one or two or 19 coats of tru oil on?
    Thanks to the Collective for your help!
  2. Tom Pettingill
    Tom Pettingill Tele-Holic
    667
    Sep 5, 2010
    California
    When I'm going for a flat and shiny mirror finish I generally lightly wet sand every 3 - 4 or so coats as I'm in the building the film phase. I find that 1000 grit and a few drops of mineral spirits works well for me. Once you get within the last coat or two, you can move up to 1500 - 2000 before the last glaze coat. Being that you have basically done all the leveling as you go, if you want to polish it out you can go strait to the fine polish when cured. Sand with the grain, and let the Tru Oil cure about a week before you polish.
  3. JustPlay
    JustPlay Tele-Meister
    Wow - that's a really beautiful instrument!
  5. dazzaman
    dazzaman Tele-Afflicted
    Aug 12, 2011
    Scotland, UK
    That is only Tru Oil? Wow, what a fantastic finish. Is your "glaze" coat thinned at all or straight from the bottle. And how are you polishing. If a finish like that is possible with Tru Oil I would be very willing to try and become a convert.
  6. flatfive
    flatfive Friend of Leo's
    Apr 23, 2009
    Monterey, CA
    Be warned: Tom Pettingill is a master at gloss Tru-Oil finishes!
    Tru-Oil is not well-suited to wet sanding because the layers don't
    melt together as they do with lacquer. I guess that's why Tom
    sands with 1000 grit -- so that he doesn't sand through the top
    level and get "boundary lines".
    If you want a perfect mirror finish, it's a lot easier with lacquer.
  7. fretman_2
    fretman_2 Friend of Leo's
    May 9, 2011
    Mobile, AL
    This, as they say, is perfection!
  8. fretman_2
    May 9, 2011
    Mobile, AL
    But Tru Oil, if you do it like Tom laid out, is very well suited to wet sanding!
    Here's a neck I did in Tru Oil...wet sanded then buffed. Not as smooth as Tom's finish, but you can see what you can do with a reasonable effort.
  9. 4string
    4string Friend of Leo's
    Feb 11, 2010
    Central California
    +1. If you expect Tru-oil to look like a lacquer finish and are using Tru-oil because spraying seems like a daunting task, you have it 100% a$$-backwards....
  10. dazzaman
    Aug 12, 2011
    Scotland, UK
    Sorry, my message was unclear. I do not disagree for a second that lacquer is easier. I didn't mean the phrase "a convert" to say that I had a wish to use TO as a replacement for lacquer, but rather an alternative.
    For six months of the year the humidity is too high to shoot lacquer outside, and I don't have the right extraction equipment to do so safely indoors, so either I choose not to finish during those months or I use an alternative. I have had lots of experience with French Polish and plain linseed oil (for different types of end result, obviously). I don't wish to use either of those on guitars, despite FP regularly used on classical instruments, hence looking for an alternative. If an instrument needs or should have a lacquer finish then that is what I will give it.
  11. Keyser Soze
    Keyser Soze Tele-Holic
    948
    Oct 13, 2009
    Johnson City, TN
    The only layer you cannot cut through is the top layer. As you note, cut through that and you will get witness lines that no amount of polishing will erase.
    So, if you do level sand then always plan on one (or two) final coat(s) that you will only sand with the finest papers (think 2000 grit and above - if at all) or that you will only hit with compound and/or polish.
    And, as always, proper surface preparation - level sanding, and level filling, make the finishing process much, much easier, adn the final results that much better.
  12. flatfive
    Apr 23, 2009
    Monterey, CA
    That neck looks great! And I use Tru-Oil for necks myself.
    But to get a mirror finish on a flat surface with Tru-Oil is
    difficult. Besides Tom Pettingill's work I think I've only seen
    a few examples here.
    That's a good way of putting it!
  13. flatfive
    Apr 23, 2009
    Monterey, CA
    Dazzaman, I know exactly where you're coming from. I spent
    months learning to french polish for exactly the same reasons.
    But shellac is not as durable as lacquer. Water-based lacquer
    is another option, but I can't see spraying it inside. I'm thinking
    of trying to brush on water-based lacquer. Some brands
    are supposed to have "full burn-in" like good 'ole nitro lacquer.
  14. flatfive
    Apr 23, 2009
    Monterey, CA
    Good tips!
    Captain Nutslot likes this.
