lawnmower problems
Discussion in 'Bad Dog Cafe' started by guitarmoron, May 18, 2019.
  1. 1293
    1293 Poster Extraordinaire
    My #1 annual service item is removing and cleaning the float bowl before the piston moves in the spring. I drain it in the fall and all of the gas in the tank goes in the log splitter or snow blower.
    guitarmoron and Milspec like this.
  2. Milspec
    Milspec Friend of Leo's
    Nebraska
    Ethanol is just nasty stuff. My Brother is a marine mechanic and I have seen some crazy stuff in boat motors due to using ethanol blended fuels. I don't even burn it in my vehicles, have to drive out of my way to find a pump that isn't blended with ethanol, but it is worth it. I think it was one of the worst scams pulled on the auto market. You get less fuel economy and damage from ethanol blends....how is that a benefit?
  3. Jupiter
    Osaka, Japan
    Out in the yard today I realized I don’t need a lawnmower anymore, cuz there’s no more lawn left.
    Wildcard_35 and guitarmoron like this.
  4. Boubou
    Boubou Doctor of Teleocity Gold Supporter
    Montreal, Quebec
    Just bought a battery powered lawn mower. My 20 year old gas powered worked without ever draining the carburater or fuel thank and with ethanol containing gasoline. Put it in the shed the last day of fall take it out in the spring , crank it, and it’s good to go. I don’t know what kind of engines you guys buy that require so much maintenance.
    stratofortress and guitarmoron like this.
  5. Milspec
    Nebraska
    It's not the engines....it's the blend of fuels in the US
  6. Boubou
    Montreal, Quebec
    Really! That sux
  7. Old Deaf Roadie
    Old Deaf Roadie Tele-Holic
    Oregon
    You have contaminated fuel. Drain the tank & refill with fresh, new fuel. If the problem persists, then you have hard deposits in the cylinder which get hot & cause the engine to misfire as soon as the fuel hits it. Backfire is 100% a product of incorrect timing, and nothing else. It has nothing to do with any leaks or mixture. I do not believe there is enough adjustment play with the magneto on those engines to cause that significant of an issue for it to be timing, especially if it fires and starts. You described the engine as able to start, but not maintain RPM. If it were a carburation, plug, or magneto issue, it likely wouldn't start at all. Me? I have an FAA mechanic certificate with a specialty as an engine machinist, and have seen more than a few filthy engines...
    guitarmoron likes this.
  8. Intubator
    Intubator TDPRI Member
    Bawlmer, MD- Home of the "Mayor Shuffle"...
    Truth is ethanol is bad for all fuel systems for any engine especially the engines made before it was introduced (forced upon consumers), but hard to get around it these days unless you live by a race track or have a way to get private aviation fuel... Some times there are Sunoco stations that have it, maybe others as well. For small engines I have made a habit of always use hi octane fuel like 93 and when the trimming/lawn mowing season ends I add Stabil to a FULL tank of gas, as mentioned. So far this works for me. Prior to that strategy, I used to run each engine dry at the end of the season and that worked but I had encountered a few carb leaks the following spring where the gaskets apparently dried out from the lack of fuel.
    Piggy Stu and guitarmoron like this.
  9. String Tree
    String Tree Doctor of Teleocity
    Up North
    No need to, the Battery is Pan-Pnumaticless.
    guitarmoron and Bones like this.
  10. guitarmoron
    guitarmoron Tele-Meister
    arkansas
    Update, runs better., when it starts to die. I pull out choke a little for 30 seconds and it stops running rough? What does that mean?
  11. bazmusicman
    bazmusicman Tele-Meister
    london England.
    If you have to open the choke when the engine has warmed up it means that the fuel mix is too lean.....you need to open the mixture screw on the carb a LITTLE bit at a time with the HOT engine running (ie warmed up) with no choke.
    This will make the mixture richer and you should hear the revs increase because of the better mixture. Do this SLOWLY until it starts to slow the revs, then SLOWLY screw it back in a little bit (about an 8th of an inch at a time) until it runs sweet. You may have to adjust the slow idle setting for a slower idle.
  12. Piggy Stu
    Piggy Stu Friend of Leo's
    Reminds me of when my carb was dirty and the dirt was slowly cleaning out
    Stp carb spray has been a godsend to me. If you can remove an air filter you can use carb spray
    I also used some Lucas additive that claims it cleans fuel lines. Not sure if it is genuine but seems to clear some gum
    Carb spray has kept a lot of engines in use that could not justify a mechanic's charge
  13. simond
    simond Tele-Meister
    Tasmania
    We bought a ride-on mower when we moved to the country but haven't used it for ten years. These guys do a better job. IMAG0545.jpg
  14. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    Is the gas tank steel? If so, then it could be rust which will be a constant recurrence. Water makes steel tanks rust. Guess what holds a lot of water. Yup, ethanol.
  15. Milspec
    Nebraska
    That would be a plugged jet in the carburetor, don't change the mixture, clean the carb. That restriction is what has been starving your motor of fuel as the volume can't keep up with the demand. As I mentioned before, modern blended fuels start to varnish at 3 weeks and it only takes a little bit to clog a jet. Most carbs never need to be adjusted, just cleaned out. Pull the carb and clean that jet or else keep running a good fuel cleaner (Chevron makes the best one) through it until it clears up.
  16. guitarmoron
    arkansas
    no, its plastic
    I think its OK now, I mowed 2 hrs straight with no hiccups!
    thanks everyone!
  17. telemnemonics
    Was there any evidence that the shop actually did anything when they had it for "service"?
    Why did you put a bunch of seafoam in the tank if it was just serviced?
    Ran badly as soon as you got it home so you dumped in the seafoam?
    At least tell your friends not to use that shop, though maybe give them a chance to explain first, like maybe the new kid did it and they had no idea he sent it out barely running.
  18. ppg677
    ppg677 Tele-Meister
    WI
    Can't decide whether to get a battery mower or not. Took me 45 minutes to mow today and reviews I read say battery times often don't match what's stated
  19. 1293
    I constantly have to remind my wife to check the Johnson rod. She blames her reluctance on mental images of George Costanza.
  20. Toto'sDad
    Toto'sDad Telefied Ad Free Member
    Bakersfield
    If it runs better after you pull the choke, it's definitely running lean, because when you pull the choke part way you are effectively cutting the air mixture, and enriching the fuel mixture. If the carburetor has a fuel mixture adjustment do as bazmusicman says, and adjust the fuel mixture.
    guitarmoron and bazmusicman like this.
