Kitchen aluminum foil as cavity shielding ?
Discussion in 'Tele Home Depot' started by littlebadboy, Jul 16, 2017.
  1. littlebadboy
    littlebadboy Tele-Holic
    766
    Jun 25, 2016
    Midwest, USA
    I ordered parts for my project/experiment guitar-bass project. But, I forgot to order copper tape. I also thought that its just an experiment guitar for now and didn't want to spend more. I was thinking of gluing kitchen aluminum foil to the cavity sides and pickguard. Would that work?
    Thanks!
  2. SPUDCASTER
    SPUDCASTER Poster Extraordinaire Platinum Supporter
    Have been using it for years.
    nojazzhere and waltschwarzkopf like this.
  3. JD0x0
    JD0x0 Poster Extraordinaire
    Feb 22, 2009
    New York
    Yup. I usually use it with layers of copper for heavy shielding.
  4. CraigB
    CraigB Tele-Holic
    875
    Nov 6, 2009
    Central Coast of CA
    Aluminum foil works, but get a roll of copper snail and slug tape at your local hardware store. it's got adhesive on one side, so there's no glue to mess with. It's only about 1.5" wide, but you can just slightly overlap it. You can solder to it, unlike aluminum. And if you mess up, it's easy to pull and start over, but once it's in there it stays put nicely. Works great!
    Tony Done, jgriffin and Chicago Matt like this.
  5. waparker4
    Nov 9, 2011
    Philadelphia, PA
    Aluminum foil works for the back of a pickguard but it is a bit annoying to work with for the cavities, because it is hard if not impossible to solder to.
  6. Kojer
    Kojer Tele-Meister
    368
    Sep 11, 2015
    Manila, PH
    Yup, it will work but It will be more finicky to work with.
  7. Zepfan
    Zepfan Poster Extraordinaire
    Nov 30, 2013
    Horn Lake, MS
    I use aluminum tape used in HVAC applications. Get a large roll at the hardware store for less than 3 dollars.
  8. Boomhauer
    Boomhauer Friend of Leo's
    Aug 18, 2013
    Michigan
    They don't sell slug tape around here. :(
  9. jgriffin
    jgriffin TDPRI Member
    60
    Jul 31, 2010
    Cumming, GA, USA
    I'm very glad I looked at this post. I had no idea that the copper tape was used for slugs. It's on Amazon if you can't get it locally and it's cheaper than Stew Mac.
  10. littlebadboy
    766
    Jun 25, 2016
    Midwest, USA
    I read somewhere that the only issue is that the adhesive is not conductive.
  11. Tony Done
    Tony Done Friend of Leo's
    Dec 3, 2014
    Toowoomba, Australia
    That's the first time I've heard of slug tape. A quick search shows I can get it locally, 100 mm wide, apparently.
  12. DavidP
    DavidP Tele-Afflicted
    Mar 16, 2003
    Vancouver, BC
    +1 on this... I use the heavy duty aluminum foil on the back of the pickguard, but go to the local stained glass store & pick up a 1ft sq sheet of copper foil -- that way you can cut to fit the cavity bottom and sides and avoid overlaps. It may take a little longer to measure and cut-fit, but IMHO you end up with a better result. Also, while the adhesive on the copper tape and foil is supposedly conductive I still spot-solder any overlap just in case...
  13. I_build_my_own
    Mar 9, 2012
    New York
    Yep this tends to be a bit thicker than kitchen foil and easier to work with therefore.
    jvin248 likes this.
  14. scooter_trasher
    scooter_trasher Tele-Meister
    359
    Jul 2, 2012
    UTOPIA
    littlebadboy likes this.
  15. Mr. Lumbergh
    Jun 13, 2013
    Initech, Inc.
    jvin248, littlebadboy and kidmo like this.
  16. omahaaudio
    omahaaudio Tele-Afflicted
    Mar 21, 2015
    Omaha
    Make sure that you use the non-stick kind. That way the bad notes will "slide off" the foil and never actually get to your amp. You'll sound 100 percent better.
  17. kidmo
    kidmo Friend of Leo's
    May 25, 2008
    Funkytown
    What does that mean? I'm not getting a clear mental image, can you please clarify, thanks.
  18. Musekatcher
    Musekatcher Tele-Holic
    653
    Jan 15, 2013
    Heart O' Dixie
    I think he means fold a corner over, so the bare side provides continuity.
  19. Mr. Lumbergh
    Jun 13, 2013
    Initech, Inc.
    Yup, this. You can't solder aluminum, and the duct tape won't have a conductive backing, but it isn't hard to get good conductivity across all of it by simply folding a small corner over each when applying it so that you have metal-metal contact across the whole shield.
    kidmo and littlebadboy like this.
  20. kidmo
    May 25, 2008
    Funkytown
    I get it now, just where it overlaps (duh)
