King of Tone Clone
Discussion in 'Burnt Fingers DIY Effects' started by Lars F, Sep 13, 2017.
  1. Lars F
    Lars F Tele-Meister
    103
    Jun 13, 2017
    Denmark
    Nice project, but pretty uncool to offer a prebuilt version imo.
    Regards,
    Lars
  2. Bristlehound
    Bristlehound Tele-Holic
    962
    Jan 4, 2017
    Wales
    Not if you're trying to make a living!
  3. FenderLover
    FenderLover Friend of Leo's
    Jun 11, 2009
    Minnesota
    ...and "KOT type clone with various options" is itself a Bluesbreaker clone with various options...
  4. sliberty
    sliberty Tele-Holic
    909
    Mar 19, 2007
    East Brunswick, NJ
    Today, I removed the 220K resistors from my Double Take (KOT clone), and socketed those positions on my PCB. Then I installed 330K and 470K resistors in place of the original 220K values. I had read that this was a way to increase the output level of these pedals. I didn't like the results - it got much more overdriven and aggressive sounding. All I was looking for was more level, but it didn't achieve that. So 220K resistors went back in.
    There is a PCB called the After Blaster. Its basically a 3PDT switch PCB with a gain stage on board The theory is that you can add an additional transistor based gain stage at the output of your existing pedal to make it louder. I don't know if I have room for the board, but I will probably buy one and check. If I do have room, I'll install it and see how that works out. If it doesn't, I'll save it for some other project.
  5. luckett
    luckett Tele-Afflicted
    Jun 14, 2011
    Just add more diodes if you want a higher output level.
  6. sliberty
    sliberty Tele-Holic
    909
    Mar 19, 2007
    East Brunswick, NJ
    I've never seen that solution mentioned. Please elaborate. A diagram would be great.
  7. luckett
    Jun 14, 2011
    Add an additional diode in series to whatever you already have. In the KOT, 3x3 in the feedback loop and 2x2 to ground with the same polarity as what's already there. That will raise the clipping threshold and let a higher signal voltage thru before clipping.
