JTM45 Clone troubleshoot
Discussion in 'Amp Tech Center' started by iSoft, Jun 2, 2019.
  1. iSoft
    iSoft TDPRI Member
    Belgium
    I did it a bit above, desoldered HV1 and HV2 and at this point it doesn't blow the fuse :)
  2. Wally
    My apologies for losing track. Is the bias circuit still connected when the fuse blows with the B+ disconnected?
  3. iSoft
    iSoft TDPRI Member
    Belgium
    If either of both is connected, it blows the fuse (either B+, either Bias or both)
    Wally likes this.
  4. Wally
    At this point, I would suggest disconnecting the bias circuit output from the power tubes’ control grids and disconnecting the filter caps’ connections to the B1/2/3/4 power supply nodes. Then see what happens when you fire the amp up in the ‘either or’ scenarios above.....bias alone, B+ alone and both.
  5. D'tar
    D'tar Tele-Afflicted
    WNY
    I do not design circuits but this looks fishy to me.... There is not a limiting resistor in your bias circuit. No bueno.IMO...
    like this...
  6. peteb
    peteb Friend of Leo's
    Cascadia
    Not sure but I think it looks ok, and the schematic looks like it’s been built many times.
    Bias circuits always seem to need two important resistances, one in series, typically before the diode. I would call this one the limiting resistor because the bigger it is less bias voltsge gets thru. On his px 45 schematic this would be the 150k resistor to the left of the diode, d1. Then there is the resistance to ground, which I would not call a limiting resistor because making this resistor big makes for more bias voltage as less bias voltage goes to ground. Together they make a voltage divider.
    On his circuit, both R106 and trimpot 1 are on the path to ground.
  7. D'tar
    WNY
    @peteb,
    You're right. Disregard my previous post. o_O
  8. robrob
    United States
  9. iSoft
    iSoft TDPRI Member
    Belgium
    Hi everyone !
    Si i found the problem for this, it was actually a faulty rectifier Diode... Replaced it and working now ! But have another problem :/
    The power coming out of the rectifiers is around 530V, but on B1, B2, etc... i only get between 70 and 100V (they all should be between 275 and 475V)
    Any idea of what could case this ? Didn't"t find what was wrong.
    Thanks again :)
  10. Wally
    Bad filter cap? I just recapped a 1991 JTM 45 RI....the first section failed.
