Jig Madness - Neck Carve - Fretboard Radius - Fret Slotting
Discussion in 'Tele Home Depot' started by PingGuo, Aug 8, 2018.
  1. PingGuo
    PingGuo Tele-Holic Silver Supporter
    North FL
    guitarbuilder likes this.
  2. guitarbuilder
    One thing one should know about my design over some of my competitors' versions that ride over pipes, is that this version stays perpendicular to the fretboard. The pipe designs can twist and rack, which (A) makes it harder to control, and (B) can leave irregularities on the fretboard, since the racking changes the height of the cutter. Those little retainers on the side are quite useful.
  3. PingGuo
    North FL
    Neck Carving Jig Puck Files for the Bill Scheltema neck jig:
    Untested. I just had to spend the time trying to find these... So i thought I'd post em again to keep easy to find.
    Always test before cutting into nice wood!
    Best,
    -Vic
    eallen likes this.
  4. PingGuo
    North FL
    One More puck
    eallen likes this.
  5. Luthi3rz
    Luthi3rz TDPRI Member
    AZ
  6. Luthi3rz
    AZ
    These as well.
  7. mtorn
    mtorn Tele-Holic
    Portland, Oregon
    Thanks! It's just my take on something I found through a google search.
    I didn't use any fancy methods for making the arc - if I remembered it right, I just drew a 10" radius (but i should have made it a little bigger) arc in Photoshop, printed it out on paper, then just transfered it to MDF and sanded to the line. A pencil on a 10" stick would work fine as well.
    This one makes a fixed 10" radius. Since I only make guitars for myself, and 10" is my favorite, that's all I need. But I could totally make more bases for it - 6 small pieces of MDF is all that's needed. The router carriage and the base track could stay the same.
  8. mtorn
    mtorn Tele-Holic
    Portland, Oregon
  9. PingGuo
    North FL
    Lots of progress today!
    This set of pictures details how I made the notched puck holders.
    Let me know your thought/questions.
    IMG_3313.jpg IMG_3314.jpg IMG_3316.jpg IMG_3317.jpg IMG_3319.jpg IMG_3324.jpg IMG_3325.jpg IMG_3327.jpg
  10. PingGuo
    North FL
    Up next was the layout and cutout/cleanup of the neck carving jig neck holder.
    IMG_3329.jpg IMG_3330.jpg IMG_3335.jpg IMG_3338.jpg IMG_3339.jpg IMG_3340.jpg IMG_3342.jpg
  11. PingGuo
    North FL
    two more pictures of the neck holder and the notched puck guides....
  12. PingGuo
    North FL
    Up next came the slot for the router bit that will do the carving for the neck jig.
    I made a stupid mistake when I was trying to start the notch cut...
    IMG_3343.jpg IMG_3349.jpg IMG_3351.jpg IMG_3352.jpg IMG_3359.jpg IMG_3360.jpg IMG_3361.jpg
  13. PingGuo
    North FL
    But fixing it was just a drill press away.
    And the notch turned out great!
    IMG_3362.jpg IMG_3364.jpg IMG_3366.jpg IMG_3369.jpg IMG_3370.jpg IMG_3373.jpg IMG_3374.jpg IMG_3375.jpg IMG_3376.jpg IMG_3377.jpg
  14. PingGuo
    North FL
    It's a little confusing. We had multiple projects going at once today.
    The first set of pucks got finished up. It only took a few times of of having the pucks ripped out of my hand before switching to the orbital sander to do the finessing.
    aIMG_3378.jpg aIMG_3380.jpg aIMG_3381.jpg aIMG_3382.jpg aIMG_3383.jpg aIMG_3386.jpg aIMG_3390.jpg aIMG_3395.jpg
  15. PingGuo
    North FL
    Work on the fretboard radius jig continued at the same time.
    IMG_3384.jpg IMG_3385.jpg IMG_3392.jpg IMG_3397.jpg IMG_3398.jpg IMG_3400.jpg IMG_3402.jpg IMG_3403.jpg IMG_3407.jpg IMG_3409.jpg
  16. PingGuo
    North FL
    It was crazy hot in the garage in north FL today. And there was a Pokemon Go event.
    We got lunch by the ocean. And caught lots of Evee.
    We also found a 3d printed Evee that someone made and left outside. What a cool little treat.
  17. PingGuo
    North FL
    after that we finished the fretboard radius jig.
    As always let me know if you have any questions about how we did anything.
    As a side note... The clouds were beautiful today!
  18. PingGuo
    North FL
    lots of progress on the neck contour jig. + a magnet for my drill press chuck key.
    IMG_3450.jpg IMG_3451.jpg IMG_3452.jpg IMG_3453.jpg IMG_3454.jpg IMG_3455.jpg IMG_3456.jpg IMG_3457.jpg IMG_3458.jpg IMG_3460.jpg
  19. PingGuo
    North FL
    setting up the straps
    IMG_3461.jpg IMG_3462.jpg IMG_3463.jpg IMG_3464.jpg IMG_3465.jpg IMG_3466.jpg IMG_3467.jpg IMG_3468.jpg IMG_3469.jpg
  20. PingGuo
    North FL
    I used threaded inserts on the neck holder side for the pucks.
    they were a major pain to install! They're very brittle and easy to break.
    IMG_3471.jpg IMG_3472.jpg IMG_3473.jpg IMG_3474.jpg IMG_3475.jpg IMG_3476.jpg IMG_3477.jpg IMG_3478.jpg IMG_3479.jpg IMG_3480.jpg
