JD Tele Wiring Diagram
Discussion in 'Tele-Technical' started by boymambo, Mar 23, 2003.
  1. boymambo
    boymambo TDPRI Member
    5
    Mar 23, 2003
    Hi,
    I am new to this forum, and was after a little info that I have not been able to find yet.
    I have a MIJ JD Tele that I bought second hand. It is a real player, very nice feel. The original picks sounded great but were very, very noisy, so I have changed the pick ups to Virtual Vintage and an SD Vintage model. I am happy with the sound but have not quite got the wiring right and would like a copy of the original schematic diargram for a JD.
    I am also considering putting a Fishman VT on this and to do this I would need to lose the Tone control. I am thinking of using a new five way with Neck, Neck+Bridge, Bridge, Neck + Capacitor, Bridge + Capacitor. I do not want to lose all the treble, so wanted advice on what capacitor to use.
    Thanks
    David Bullock
  2. bdkphoto
    bdkphoto Tele-Meister
    447
    Mar 16, 2003
    NYC
    Try Fender.com
    Go to fender.com. the Mr. gearhead section and you
    should be able to download a pdf diagram. Good luck.
  3. boymambo
    5
    Mar 23, 2003
    bdkphoto,
    Thanks for the advice, I have already tried Fender.com and MrGearhead. I have a feeling that this may be a little more specialised.
    Thanks again,
    David
  4. steve s
    steve s Tele-Meister
    471
    Atlanta
  5. Michael Murphy
    Michael Murphy Tele-Afflicted
    Here's a link to the JD wiring diagram. At one time (pre-internet) I wrote Fender requesting a copy, and received a reply saying that it was 'prorietary information', and they would not make it available.
    It uses a special Yamaha switch (available from Stew-Mac) rather than a standard 5-way, and as you can see the wiring is fairly complex. I don't think you will be able to retain the JD functions and use the switch in conjunction with the Fishman- you'll probably need a separate mini-switch for it.
    I have seen a pic of a '52RI that was modified w/a Fishman, and had a new pot added between the existing two already on the control plate. It was a little crowded, but do-able. You might consider a mini-pot to give your fingers a little more room.......
    -Michael
    Charter Member S. Texas He-man emoticon-haters Local #316
  6. boymambo
    5
    Mar 23, 2003
    Michael and Steve,
    Thank you very much that has been very helpful. I shall follow this up asap.
    David.
  7. Deaf Eddie
    Deaf Eddie Friend of Leo's Silver Supporter
    JD setup... alternative?
    I JUST had an e-mail from someone who was looking to improve on the JD setup they had, suggested the FIVE-TONE Tele switch scheme I've used a couple of times. No capacitor involved, the stops are bridge, bridge+neck series/out of phase; bridge+neck parallel; bridge+neck series; neck. The series/out of phase has monster BITE if you play it crunchy...
    It uses the SuperSwitch five-way available from Stewmac.com or guitarelectronics.com, or you can get it from me PRE-WIRED - e-mail me for a drawing or more info...
    Deaf Eddie
